How many miles is on your 2.7?
Discussion in '4 Cylinder' started by sourdough, Feb 8, 2010.
  1. Mar 28, 2018 at 11:18 AM
    #1121
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    I'm already up to almost 48k in my 2016!
    MicComa likes this.
  2. Mar 28, 2018 at 11:22 AM
    #1122
    pepperhead71
    pepperhead71 Well-Known Member
    Cajun County Mire,La
    2015 Tacoma Double Cab SR5,2007 Tacoma Double Cab SR5
    I don't know if I have some kind of odd ball.I hear alot about the 5speeds not too many with the 4spd.
    iamroddy likes this.
  3. Apr 3, 2018 at 7:14 PM
    #1123
    CabinFever47
    CabinFever47 Member
    Blake
    Shreveport, LA
    2004 Lunar Mist Tacoma Prerunner, single cab 2.7L
    Mostly stock except 265/75/16 Yokohama Geolandar A/T's
    My '04 just rolled over to 211,000 miles yesterday. Replaced the idler pulley last week. So far no big repairs have been needed. I've got an issue with the power steering where it works under all conditions except for when there is no acceleration, such as when parked or in crowded parking lots. A mechanic told me to bleed the lines to push any trapped air out.
    Though I am currently saving up for a 2018 SR5 dbl cab Tacoma, I would expect my '04 to easily see 275,000 miles or more before anything major with the engine failed.
    JNG likes this.
  4. Apr 11, 2018 at 6:59 AM
    #1124
    drjenkins
    drjenkins Well-Known Member
    Dave
    Alabama
    2014 SW DCSB
    Just crested 32k on my 2014. Not expecting it to climb too rapidly either since it's a weekend driver, mainly.
  5. Apr 11, 2018 at 9:23 PM
    #1125
    TacOside
    TacOside Well-Known Member
    Dean
    Oceanside, CA SoCal
    03 Double Cab
    3” lift, total chaos uca’s, 33" BFGs
    253,000 on my ‘03 2.7L. No problems all original. Only replaced the water pump and fan/fan clutch due to a accident
    JNG likes this.
  6. Apr 15, 2018 at 9:37 AM
    #1126
    dmoyers
    dmoyers Member
    One owner 2005 Access Cab 4x4 with 145k
    JNG likes this.
  7. Apr 17, 2018 at 1:39 PM
    #1127
    iamroddy
    iamroddy Well-Known Member
    2011 Access Cab, 4X4 automatic...97,000 miles.
    JNG likes this.
  8. Apr 17, 2018 at 1:42 PM
    #1128
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Tacked on another 10k since my last post
    JNG and Hardscrabble like this.
  9. Apr 21, 2018 at 10:02 PM
    #1129
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I'm up to 171,725 on my 2004 RC 4X4 with the 2.7 and 5 speed manual. So far, since it was new? All new OME suspension and Deaver J-59 rear leaf springs. 4 batteries. The first one under warranty. Outer tie rod ends. New belts which it really didn't need at 150,000. One brake job at 60,000 miles. Water pump under warranty at 60,000 miles. New factory headlight housings around 160,000 miles. New polyurethane steering rack bushings around 150,000 miles. Oil and filter were changed every 3000 miles like clockwork.
    I'm not the original owner. My dad was and I have every receipt since it was new. All maintenance was done by a dealer with a service manager that actually cared. He did everything by the book until 119,000 when I bought it from him. I only got it because he hurt his back and couldn't drive a manual anymore. I never would have gotten my hands on one like this for $5000 anywhere else. It had pretty much all highway miles on it and was kept in a garage in Kalifornia for the first 10 years of it's life. I doubt it ever saw even 2500 rpm until I got it. It just sat for over a year before I got it although his wife took it for a spin every now and then. The 4WD was sticky for a while until I worked it on and off.
    I drive 15 miles each way to work every day 5 days a week on the interstate and make sure it is at operating temp before I get on the interstate. Then mild dirt trails for about 15 miles on the weekends to keep the 4WD system lubed. Sometimes much more. Hoping I reach the 500,000 mile club.
    JNG likes this.
  10. Apr 29, 2018 at 8:11 PM
    #1130
    ScooterG
    ScooterG It’s my island.
    Scott
    2012 Tacoma 4x4 2.7L
    Hi everyone. Just picked up a 2012 4x4 2.7 5spd with 57k miles on it. I average 10-12k miles per year. Hoping to be posting about this truck in 15-20 years :thumbsup:
  11. Apr 29, 2018 at 8:19 PM
    #1131
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    Almost 190k on mine
    JNG likes this.
  12. Apr 30, 2018 at 7:16 AM
    #1132
    pepperhead71
    How much did you give for it
  13. May 1, 2018 at 4:19 AM
    #1133
    ScooterG
    Scott
    Found it for $18500 in SoCal.
    pepperhead71[QUOTED] likes this.
  14. May 1, 2018 at 1:12 PM
    #1134
    dillonk1602
    dillonk1602 Well-Known Member
    dillon
    san diego
    tacoma 5 lug
    Vehicle Modifications: TACOMA 2007 FRONT TOTAL CHAOS 5LUG ,LONG TRAVEL KIT 13" OF TRAVEL KING COIL OVER (550 POUND SPRING RATE) (18 INCH COIL) REAR BED CAGE 16" SMOOTH BODY FOX SHOCKS 2.5 2.0 / 2.5 BUMP STOPS FOX ICON ADD LEAF PACK WITH OEM SPRING 11" OF TRAVEL TRUCK COMES SPRING UNDER BY MANUFACTURE TOYOTA REGEAR TO 4.0 WITH AUBURN UNIT ENGINE 2TR-FE WITH AFE COLD AIR IN TAKE DOUG THORLEY HEADER MAGNAFLOW EXHAUST TIRE S NEW KO2 32/11.5 METHOD RIM 15" WITH -20MM OFF SET
    are u running wheel spacers?
  15. May 1, 2018 at 1:32 PM
    #1135
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
    dose the 1.25 pass the studs ? so the rim can sit flush?
  16. Jun 20, 2018 at 4:06 PM
    #1136
    tunabrad
    tunabrad Well-Known Member
    Brad
    California
    2019 White DCSB SR5
    Only 43k on my 2006. Will report back in 15 years to let you know how strong its still runnin
    austin2009, jeff b and dillonk1602 like this.
  17. Jun 20, 2018 at 6:30 PM
    #1137
    IFGD
    IFGD Well-Known Member
    Ian
    Raleigh, NC
    2001 Regular Cab 2.7L
    Up to a whopping 59k on my '01.
    austin2009 and jeff b like this.
  18. Jun 23, 2018 at 7:50 AM
    #1138
    casey2012
    casey2012 Well-Known Member
    mark
    yota
    none
    178000 on a 2012
    JNG likes this.
  19. Jun 23, 2018 at 8:18 AM
    #1139
    casey2012
    mark
    yota
    none
    17300 bought it new
  20. Jun 25, 2018 at 4:26 PM
    #1140
    austin2009
    austin2009 Well-Known Member
    Austin
    Boise, Idaho
    Lifted and Locked 09 2.7L 2TR 4x4 5 Speed
    DRIVETRAIN- -4.56 Nitro gears -ARB rear locker -SPC UCA's -Fox 2.5" RR fronts/650lb coils -Bilstein 5100's rear -1.5" AAL -285 BFG KO2’s -16x8 MK6’s ARMOR- -ABR bumper -BAMF LCA skids -Cali Raised sliders RECOVERY- -Smittybilt XRC 9.5k synthetic winch -ARB OBA -Factor 55 Pro Link, Expert STEREO- -Pioneer head unit -Rockford T series speakers -Rockford 500 watt amp -Rockford P2D4 8" sub LIGHTING- -Calirasied ditch lights -Caliraised amber fogs -Hella Black Magic’s -Blue Seas fuse panel
    You guys need to drive your trucks :rofl:
