How many miles on ur timing belt?
Discussion in '1st Gen. Tacomas (1995-2004)' started by edavidso, Oct 24, 2012.
  1. Oct 24, 2012 at 9:04 AM
    edavidso
    edavidso [OP] Well-Known Member
    Erik
    Colorado
    1997 SR5 3.4L 4x4 & 2011 TRD OR DC SB 6Spd 4x
    3" Toytec Lift, Smitty Roll Bar, Push Bar, Nerf Bars, 7 KC 150W, Viper alarm w/ Remote Start, Pioneer CD/MP3, 6 disc changer, Infiniti Speakers, Rhino Lining.
    I'm one of those weirdos that is pushing the limits of the timing belt. I know if it breaks I'll be stranded. I know it is advised to change it at 90k. I'm curious as to how many people have pushed the limits and by how far...maybe we can see a trend and realize timing belts will last quite a while. So if you care and aren't going to criticize, post how many miles you have on an original timing belt.
    I'm at 247k on the original. :)
    2002Tacoma4x4 likes this.
  2. Oct 24, 2012 at 9:33 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    I'm not surprised actually. I did our old 4Runner at 146k and it looked perfect. All the pulleys were perfect too, water pump wasn't leaking, etc. But it was my wife's truck and she was very pregnant so I changed everything. I never would have heard the end of it had it left her stranded.
  3. Oct 24, 2012 at 10:53 AM
    TACO in SC
    TACO in SC TuRD
    Andrew
    Greenwood, SC
    '03 Tacoma Ex Cab 4x4 V6 5-Speed
    Pretty well stock
    My '03 V6 has 94,000 miles on it now. I think I am supposed to change it out at 110K or something like that.
  4. Oct 24, 2012 at 1:14 PM
    Taylor
    Taylor Check out NASA Spec3!
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Like... 3,000. Hah.
  5. Oct 24, 2012 at 3:24 PM
    tumbleweed40
    tumbleweed40 Member
    karl blackman
    moses lake wash
    2006 trd tundra
    stock
    about 1500,just had it done
  6. Oct 24, 2012 at 3:35 PM
    cbreze
    cbreze Well-Known Member
    Jim
    Bend, Oregon
    '12 T4R, '74 LC, '88,'98 04' pickups.
    Amazing! Risky, but damn amazing non the less. 78k on mine. I may relax a bit;)
  7. Oct 24, 2012 at 3:54 PM
    Buy1Get1Freee
    Buy1Get1Freee HERP DERP
    PEI
    2001 Tacoma TRD
    Grey Wire Mod, Bilstein 5100s, Eibach Coils! 255/85/16 KM2. DDM HID 35W 6000K, Homemade Rear Bumper, Trail Gear Rock Sliders
    335K (KMs) on mine. Pretty sure the 5vzfe is a non interference engine anyways.
  8. Oct 24, 2012 at 5:03 PM
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Indeed it is. No worries if it breaks, just watch out for it slinging around in there. Still recommend regular maintenance of it.
  9. Oct 24, 2012 at 5:42 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    X2... T belt service I believe is listed in the FSM @ 90k
    changed mine at 100k (new idlers/tension'r/belt)
    ^ belt looked fine, could see that going on much longer
    but I think regular service intervals for the other components...
    (ie: water pump, idler's, tension'r, etc,)
    will keep you happier, longer. ;)
  10. Oct 24, 2012 at 9:43 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    I am just changing mine at 120K. HOWEVER, you should be more worried about your water pump leaking.
  11. Oct 24, 2012 at 9:46 PM
    3RZ Taco
    3RZ Taco Well-Known Member
    Austin
    Oregon
    96 3RZ Stock
    K&N air filter, Toolbox, Window Deflectors, Bug Deflector, BFGoodrich A/T's
    i'm at 183,965 miles on my stock belt... The 3RZ isn't a interferance motor is it? My belt is now on its last leg
  12. Oct 24, 2012 at 9:53 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    you have a chain
  13. Oct 25, 2012 at 6:47 AM
    KingToaster
    KingToaster Member
    Alan
    NH
    2002 Tacoma DC 3.4L SR5
    Deck Plate w/ K&N. Grey Wire Mod.
    Have about 165,000 on mine. Changing it this weekend. Will report back on how it looks.
  14. Oct 25, 2012 at 6:50 AM
    teamamerica
    teamamerica Get off your horse and drink your milk.
    Wy
    2009 tacoma
    none yet
    i would say change it when they say, i was supposed to change my alfa romeo belt at 90k or so and at 96 it snapped and locked up the motor.
  15. Oct 25, 2012 at 6:58 AM
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    I don't think it's an interference engine.
  16. Oct 25, 2012 at 7:01 AM
    3RZ Taco
    Austin
    Oregon
    96 3RZ Stock
    You da man! thanks!
  17. Oct 25, 2012 at 7:24 AM
    Swimmerboy2112
    Swimmerboy2112 Well-Known Member
    Brian
    Walnutport, PA
    02 TRD V6 5 Speed X-Cab
    Borla exhaust, K&N intake, ARB bumper, 16x8 Konig Countersteer Offroad wheels, 20% Tint
    Did mine at 110K, has 134K on it now.
  18. Oct 25, 2012 at 12:34 PM
    TACO671
    TACO671 Member
    SPOKANE
    2002 TACOMA SR5 3.4V6
    145K on mine. Water pump starting to seep. Will change as soon as timing belt kit arrives in the mail.
  19. Oct 25, 2012 at 12:49 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    The amazing part for your situation is that your waterpump has lasted this long.
    39K so far on this one.
    cruxofthebisquit likes this.
  20. Oct 25, 2012 at 12:53 PM
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    Almost 88K, since that the ODO reads. Will be getting it done, SOON!
