How many miles on your 2012-2015?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 98_3RZ_NIC, Feb 1, 2021.
  1. Feb 1, 2021 at 8:26 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It’s not my truck.
    I just follow that post.
    My truck is an 07’ with 137k
  2. Feb 1, 2021 at 8:26 PM
    98_3RZ_NIC
    98_3RZ_NIC [OP] Well-Known Member
    1998 white extended cab
    Bilstein 5100’s with ome 881 coils on lowest setting, JBA upper control arms, LCE header, 31x10.5x15 falken wildpeaks.
    thats very low mileage!!
  3. Feb 1, 2021 at 8:31 PM
    timred93
    timred93 Never too old to Tacoma
    Tim
    NW AR
    2013 Spruce Mica TRD Sport
    Predator Tube Steps, Fuel Hardline Wheels, 265/70 R 17 Nitto Ridge Grapplers, 2 inch Rough Country Leveling Struts, Undercover Armour Flex Hard Folding Tonneau Cover, Pop and Lock Tailgate Latch With Key Lock.
    I won't be much help. 38,000 on my 2013. :hattip:
    4x4cajun, JWILL10 and 98_3RZ_NIC[OP] like this.
  4. Feb 1, 2021 at 8:32 PM
    98_3RZ_NIC
    talk about low miles! Wow!
  5. Feb 1, 2021 at 8:32 PM
    Boco10
    Boco10 Well-Known Member
    ADK
    Ya she is running strong. At 230k I had my mechanic go through it and went to the dealer for another. Dealer found my rear license plate bulb was out. I ended up doing new leaf springs,shocks, struts, coils, and upper control arms. It wasnt necessary but man it drives like it came off the lot.
  6. Feb 1, 2021 at 8:35 PM
    13tacosport
    13tacosport Well-Known Member
    Arbi
    818
    13 Trd Sport
    103k, bought July 2019 at 92k. Second owner
    4x4cajun and 98_3RZ_NIC[OP] like this.
  7. Feb 1, 2021 at 8:35 PM
    timred93
    Tim
    NW AR
    During the used Tacoma craze last summer due to covid Carvana quoted me a price that was over $1000 more than I gave for it new in April 2013.
  8. Feb 1, 2021 at 8:54 PM
    DanaPtTaco
    DanaPtTaco Never-ending problems
    Thomas
    Orange County, CA
    07 ACLB Prerunner 4.0 AT
    I'll be the first person here to give a negative response. My 4.0 seized at 197k. However, it was due to the previous owner's negligence with oil changes. As long as you change the oil regularly and do proper maintenance you'll be fine. Make sure you have a mechanic thoroughly check the truck out before you buy it so you don't have the same problem I did.
  9. Feb 1, 2021 at 9:05 PM
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    85k, but only about 7k the last 2 years combined. I hardly drive it anymore since working from home full time (even pre-Covid). Just the occasional road trip.
    Basically just oil changes, and spark plugs. Changed the rear diff fluid at 60k and engine/air filter. That's pretty much it.
    98_3RZ_NIC[OP] likes this.
  10. Feb 1, 2021 at 9:08 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    There were times, after I started running full synthetic, that I waited up to 8,000 miles between oil changes; Before that I got the oil changed every 5K as per the owner’s manual’s recommendation. I’ve been doing every 5K since 110K miles and I’m at almost 124K now; I’m guessing I’m fine?
  11. Feb 1, 2021 at 9:22 PM
    DanaPtTaco
    Thomas
    Orange County, CA
    I'm sure you're fine. Synthetics can usually go 8k without risking it too much. It's just better practice to do 5k intervals. The family friend I bought the truck from had no service records after the free dealership oil changes and maintenance but I didn't think much of it. I have no idea what intervals he did it at or what. I got an oil change done right when I bought it and then 5k later did one myself. When I did that, the oil looked like glitter with all the metal in it and it died not long after. Thats why I recommend getting it checked out before instead of trusting someone like I did. My new engine requires a change every 3-4k to keep the warranty so i'm using dino oil until the warranty is up. Then strictly synthetic every 5k.
  12. Feb 1, 2021 at 9:42 PM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    The 1GR-FE is a port injected dinosaur. You COULD run 10k mile changes with synthetic and never notice any difference.
  13. Feb 1, 2021 at 9:55 PM
    PennSilverTaco
    Charlie
    What's weird is that it was using oil for a bit; I switched from 0W-20 to 5W-20 and it stopped.
  14. Feb 1, 2021 at 10:26 PM
    Gruber1922
    Gruber1922 Well-Known Member
    Tacoma, WA
    2015 Tacoma Sport
  15. Feb 1, 2021 at 10:46 PM
    #35
    Xmplry808
    Xmplry808 Well-Known Member
    2015 BRM Tacoma xrunner
    Engine: -Doug thorely long tube headers -URD dual O2 simulator -Dual 2.5” QTP cut outs -RADS true dual piping -TRD supercharger MP90 -Custom air duct -K&N cold air intake -AFE tb adapter -AFE 76mm throttle body -URD 2.7 supercharger pulley -URD fuel pump/Aeromotive 340 upgrade -URD extension harness -URD maf calibrator w/map sensor -URD 170 thermostat -URD speed unlimiter -Cusco oil catch can -URD fuel rail tap -FPR mod -COUPE oil pan spacer w/baffle -NX wet nitrous kit 50 shot -NX 10 lb bottle -NX purge kit -ZEX rapid fire module -Greddy oil filter relocation adapter -Mishimoto oil cooler -HKS big 3 wire upgrade -Pulley wrap mod Electrical -130amp alternator -Voltage Booster Pro SPARK -Optima yellow top group 27 -1/0 wire upgrade Drivetrain: -B&M short shifter -Detroit tru trac LSD -Competition Clutch stage 4/6 puck clutch kit -Competition Clutch lighten flywheel -URD throw out bearing/sleeve kit -Sprint booster V3 -Remove clutch accumulator Suspension: -Djm front A arms -Djm welded in frame notch -DJM offset bushings -XII Performance front coilovers -XII Performance sway bars Fronts 1 3/8” Rear 1 1/16” -4" Custom Taco drop blocks -QA1 rear shocks -Air Lift air bags -Air compressor -Alignment Cam Gussets -UMI billet front sway bar mounts 1 3/8 Wheels/tires: -HRE wheels 540 step lip Front 20x10 255/35/20 Rear 20x11 305/30/20 Brakes: -Performance Brake Unlimited BBK -4 piston Tundra calipers -360mm ISF drilled brembo rotors -Stop tech stainless steel brake hoses -Brembo brake pads Exterior: -35% ceramic front window tint -Hood spacers 1" -Cut front grill -Cut hood scoop -Strictly Street RACE spec spoiler -Race front and rear tow hooks -Diode Dynamic SS3 yellow pro fogs -Race Louvers Front RSF fender trim Rear FL fender trim Interior: -Lotek dual gauge pillar pods -Ultra gauge Mx 1.3 -TRD shift knob -JunctionProduce pillow cushions (4) -Bellezza leather neck pads (2) -Innovation gauge dual wide band -Innovation boost gauge w/shift light -Air lift dual air pressure gauge -TRD racing pedals -LED lighting Sounds: -Sony XAV-AX8000 -JLaudio (2)13w6v2 subwoofer in isobaric ported box 33hz -JLaudio 1000/1 mono amp -JLaudio Evo C3 6.5 (4)co-axles -JLaudio 300/4 4 ch. amp
    80k just changed my trans oil too
  16. Feb 1, 2021 at 10:48 PM
    #36
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    2015,has 43k on odo.
  17. Feb 1, 2021 at 10:50 PM
    #37
    Mack83
    Mack83 Well-Known Member
    Orlando
    2014 TRD OR DCSB Silver Streak Mica
    114k on my 2014.
  18. Feb 2, 2021 at 1:35 AM
    #38
    justcuz
    justcuz Well-Known Member
    my 2015 has 45,000 kms
    converted it works out to 27961 miles
  19. Feb 2, 2021 at 3:37 AM
    #39
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    100,600 miles
  20. Feb 2, 2021 at 4:35 AM
    #40
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    134,000Mi on my 2013. Has seen signifigant off road use as well as beaches very frequently.
    Replaced CV axle due to torn boot
    blower motor resister and plug
    1 lower ball joint
    serpentine belt
    That's all.
