How many miles on your 3.4 with out
Discussion in '1st Gen. Tacomas (1995-2004)' started by twfsa, Sep 23, 2010.
  1. Sep 23, 2010 at 12:36 PM
    twfsa
    twfsa [OP] Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    replaceing the timing belt, been told its a non interfering engine so unless I take a road trip gona run it till it snaps.
  2. Sep 23, 2010 at 12:46 PM
    Madjik_Man
    Colorado Front Range
    I accidentally let mine go until 125K
  3. Sep 23, 2010 at 1:35 PM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    why so you can get stranded in the middle of no where one night?
  4. Sep 23, 2010 at 1:39 PM
    tacoma92
    tacoma92 Black Hole Sun
    Forrest
    Gulf Shores, Alabama
    09 SR5 Toyota Tacoma
    U r supposed to get it changed out every 80 to 100 thousand miles. I waited til it snapped :D
  5. Sep 23, 2010 at 1:51 PM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    185,000miles on factory original so far bishes
  6. Sep 23, 2010 at 5:29 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    187,554 is whats on my odo right now.. and aint changed it yet
  7. Sep 23, 2010 at 5:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I had one go out at 118k miles....
  8. Sep 23, 2010 at 5:37 PM
    98_Mud_bug
    lucedale Ms.
    i need to replace mine bad.. ha ha
  9. Sep 23, 2010 at 6:44 PM
    EL TACOROJO
    BURRY
    south mills NORCAK
    You too huh.pressin my luck everyday:D
  10. Sep 23, 2010 at 8:48 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Do you guys loose any sleep over worrying if its going to fail? Here's some comfort, usually the water pump starts leaking before the the rubber band breaks. :eek:
    Have you have to add coolant lately?
  11. Sep 23, 2010 at 8:50 PM
    747 function > form
    1st Gen.
    64k (I'll wait 'til I hit 90k on the current one though).
  12. Sep 23, 2010 at 8:50 PM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    San Diego (Spring Valley)
    04 Prerunner
    toytec coil spacers, tokicko struts/dubcab springs, energy suspension rack bushings, bilstien hd shocks, K&N FIPK2, Flowmaster 50DF, ScanGuage2, 5000k HID's, horn mod, other stuff that I forgot to list
    110,000 on mine.
    But I plan on changing it soon, cause my water pump is leaking.
  13. Sep 23, 2010 at 8:56 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    i just changed mine at 128k
  14. Sep 23, 2010 at 8:58 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    That's exactly where I'm at but not by accident. I already have the timing belt & I'll slowly be getting all the other parts together. I'm not worried.
  15. Sep 23, 2010 at 9:03 PM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    04 Prerunner
    Ive seen one pretty badly cracked off a Tundra w/ 3.4 (~95k), but it was an older one (01 or 02)
  16. Sep 23, 2010 at 9:42 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    about to change mine out soon (84k)
  17. Sep 23, 2010 at 10:02 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Do you realize that when timing belt snaps, the camshafts will STOP moving while the pistons still move up & down?? Snapping of timing belt can and most likely WILL result in bent valves in the best case scenario...
    Timing belt should be changed around the 100k mile mark...
  18. Sep 23, 2010 at 10:09 PM
    pittim
    Pennsyltucky
    Boujee Prius
    the 5vzfe (3.4) is a non interference engine. no damage is done to the engine if the belt snaps, but you wont be goin anywhere for awhile.
    if you plan on running it til it snaps, my advice: grab a snickers, put it in the glove box
    tacomakid96 likes this.
  19. Sep 23, 2010 at 10:09 PM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    04 Prerunner
    Do you realize that the 5vz-fe is a NON interference motor?
  20. Sep 23, 2010 at 10:11 PM
    05RedTaco
    Tony
    Scottsdale
    Must be due to low compression of the motor. I am not too familiar with the Toyota engines yet.
    I look like an idiot, should have read the first post to the end, not just the title...LOL
