How many miles on your alternator?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by visionre, Dec 15, 2008.
  1. Dec 15, 2008 at 12:30 PM
    visionre
    visionre [OP] Mayor of snowville
    East Coast
    05 2.7L 5spd base
    First post, 5th day owning a 2nd hand 2005 4cyl taco. Sad to say after only 60k the alternator has handed in its retirement notification. I am somewhat unimpressed being all the older toyota's I and my family have owned have got close to 200k miles before changing an alternator. Hope they're not making them cheaper now.
    How many miles on yours?
  2. Dec 15, 2008 at 12:38 PM
    Walt Corbin
    Walt Corbin Well-Known Member
    Charleston SC
    05 Dble Cab SR5 4x4
    Revtech Lift w 285's
    2005 V6 Taco with about 47,000 miles
  3. Dec 15, 2008 at 12:44 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    That definately sucks. Especially on such a young Toyota. However, I don't think it is common.
  4. Dec 15, 2008 at 12:50 PM
    106Tacoma
    106Tacoma Well-Known Member
    Debadged 06 Black Sand Pearl 4x4 Every option.
    I think the v6 alts are in a horible position, mine sees salt and all the rain water from the wheel well. But still going hard at 21,000.
  5. Dec 15, 2008 at 2:29 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    yeah, i'm not looking forward to replacing it either.. looks like its in a tough area.
  6. Dec 15, 2008 at 3:46 PM
    tgr8st
    tgr8st Member
    I just had to replace mine. Mud caked it while off-roading. I took it to All-Parts, and they could only find one refurbished alt in the whole country (130amp). I put it in and its a lot louder than the stock one was. It whines whenever I gas the truck.
    To switch them out, theres two bolts on the alt you gotta take off. Then a grounding wire and a wire harness. Once the bolts are off the belt slips right off. I squeezed it out through the top by taking the battery out and unbolting the wire harness next tot he battery. Its a tight squeeze but it will go through. To put the belt back on, I had my brother hold a socket wrench on the torsion pulley and the belt slipped on easily.
  7. Dec 15, 2008 at 3:52 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    ah good to know its easy to pull out. I figured the battery would have to come out. I was wondering if itd be easier to go from under.. but good to know.
  8. Dec 15, 2008 at 3:58 PM
    sonjay
    sonjay Well-Known Member
    visionre, get your battery tested as well. I've seen batteries kill alternators.
  9. Dec 16, 2008 at 2:12 AM
    visionre
    East Coast
    05 2.7L 5spd base
    BTDT, true. I took it to toyota for the full ivr test (only $20 worth it). Battery is good, diagnosis was alt not charging as much as it should. I heard some of the 2nd gens needed an ecu flash so I thought dealership would be aware of particulars like that.
  10. Dec 16, 2008 at 3:26 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What's wrong with it?
    I'm not familiar with the 05+ alternators - but don't they have brushes? Did you check the brushes? Are the bearings bad ? Bearings can be replaced.
    Take it to battery/alternator shop and they might be able to clean it up & rebuild whatever it needs and it'll be good as new (just depends on how much they'll charge you to do all that).
    On my 96 - I had it cleaned, bearings/brushes replaced and it was good as new. Mine was all smeared in mud.
  11. Dec 16, 2008 at 3:32 AM
    visionre
    East Coast
    05 2.7L 5spd base
    Doing that today. Suspects it just needs a cleaning or maybe a new regulator. It's not making noise though, so I don't think it's a bearing.
    Back to the subject of the post though....
  12. Dec 16, 2008 at 6:25 AM
    Janster
    Jandy
    Lancaster, PA
    I had a 96 with 110k miles on it when I sold it. Original Alternator.
    The reason it needed bearings & brushes is because I offroaded/mudded with it for 3 years. Mud is evil.
