How many miles on your clutch before replacement?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mgord, Dec 16, 2014.
  1. Feb 1, 2017 at 4:18 PM
    WineDrinker
    WineDrinker New Member
    Rob
    TACO
    NONE all standard
    Well, I'm on a truck I gently use, no hauling much and mine is going out pre-mature at 264K, I say this because - I've been use to my other TACO's getting about 380K and replaced the clutch because it was thin and because I had almost always to go in because of the bearings. I've got over 5 million miles experience, and it usually follows Alternator at about 240K, Starter about 270K and Bearings in clutch at about 360-380K every time. Those previous trucks I worked them very hard and hauled a lot of things having to replace my front end sway bar with shocks etc. This truck I have now, the alternator went out exactly like the others at 240K, I'm not sure if I will have the starter go out at 270 on this one because I do not stop and start 50-100 times a day any more, only a few to a dozen times... but it shocked me to have my clutch loose all it's pressure today, and barely travels, it's almost like I can't feel it. I've had one truck built in 1979 that I had a million miles on replaced clutch twice (both times the clutch over bearings first) and I raced that truck and hauled often overloaded often - I got in the high 400K on those clutches and the clutch went out for the third time and I just sold it because I was tired of looking at her.
    THAT SAID, I have known a lot of people who either get 60-100K out of their clutches because they don't know how to use them, or get 250-300 on the low side and 350-380K on the high side. I always thought that if someone could not get 300K out of a clutch they lacked knowledge on using one... I guess every automobile has it's weaknesses regardless of user.
  2. Feb 2, 2017 at 2:40 PM
    81shark
    81shark Well-Known Member
    interesting..
    up to 128500 on mine... we'll see....
  3. Feb 2, 2017 at 3:10 PM
    badger
    badger Well-Known Member
    07 SR5
    I've got over 150K on mine with no issues, except for the taco chirp. I've done lots of towing, and off-road stuff.
  4. Feb 2, 2017 at 3:17 PM
    moweryaviation
    moweryaviation Life begins, where the pavement ends!
    Dixon, California
    2011 Tacoma, 4x4, manual, access cab
    3" (or so) lift, Dakar leafs & 886 up front.OME Sport shocks, Pro-Crap struts up front, SPC UCA's, Brute Force Fab front and rear, super winch 9500, KM2 255/85, Holly Brakes, SS Brake lines, DOT 4 Fluid, Custom bed system, independent bed LEDs, black head lights, Mag Grey grill, DIY 50$ roof tie down system, On Board Air, DIY spare tire swing arm, DIY painted rims, Energy bushings, camp lights, independant power system, BAMF Bolt on Sliders, DIY IFS Skid, DIY Roof Rack, Bad ass additude, one old smart dog, one young dumb dog, and one hot Burnett!
    380K on a clutch? Must not be a 2nd gen. My first gen had 231,000 on it and still tight, that was before the frame cracked in half. My 2 2nd gen tacomas have the worst clutch I have ever driven. Im at 125,000 now and considering my options!
  5. Feb 2, 2019 at 4:32 PM
    RDC
    RDC Member
    15 AC TRDOR 4x4 Manual
    None yet
    Dealer just recommended new clutch at 67k. Took it in to confirm throw out bearing noise. My first Taco (‘15 TRDOR) is the bearing noise normal?
  6. Feb 2, 2019 at 4:59 PM
    81shark
    144,400. Still going.
  7. Feb 2, 2019 at 4:59 PM
    Boilerman
    Boilerman Well-Known Member
    Brian
    Texas, northwest of the Big Pond
    2010 Prerunner SR5 Magnetic Gray 2.7L
    128,000 miles and still the original clutch.
  8. Feb 2, 2019 at 6:27 PM
    offgrid taco
    offgrid taco Well-Known Member
    ned
    mass
    24 trd off road bronze oxide
    For reference my 05 made the bearing noise from around 60k mi till I replaced the original clutch at 280k mi. When I replaced the clutch the throw out bearing was still functional and I still had lots of friction material left. My problem was the friction plate springs broke.
    Ned
    RDC[QUOTED] likes this.
  9. Feb 2, 2019 at 6:29 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I replaced my clutch on my 04 because the throwout bearing was chirping, but the clutch itself had plenty of life left. Only time I've had to replace a clutch on a vehicle because it went bad was on my Scion tC back in the day, had about 95k on it. It was my first manual trans car though so it had a rough start to life, lol.
    I've seen and heard of Tacomas getting upwards of 150k or more on the stock clutch. If you offroad a lot especially on rocks and such, or do a lot of towing, you'll probably be lucky to see anywhere near that.
  10. Feb 2, 2019 at 6:50 PM
    Pigpen
    Dan
    Northwest Montana
    I'm at 120K. I've smoked it numerous times where there was actually smoke coming out from under the truck. Total user error in all cases - should've been in 4 low instead of 4 high. I used to tow heavy loads a lot, not as much these days. I use 2 wheel drive low when backing up the trailer, since installing it. The 2 Low mod from @Up2NoGood is one of my favorites. It's a real clutch saver.
    BassAckwards likes this.
  11. Feb 2, 2019 at 7:06 PM
    JRVfromDVT
    JRVfromDVT Well-Known Member
    Southern Vermont
    2006 Tacoma Access Cab
    156k on my 2nd gen and the clutch is still holding strong. 2 of the last 3 owners did not baby the truck but as far as I can tell there's no signs of it letting go. No noise, no smoke, no slipping.
    My fathers 2nd gen has similar mileage and that one is nowhere near needing to be replaced. His 1st gen had 190k when he traded it in on the original clutch.
    Its all a matter of how you drive. I have friends who grenaded their clutches at 50k. On the other hand my stepmom had over 300k on her civic with the original clutch and my previous car, a VW Passat had 205k on the clutch when other things went wrong and put the car out of commission.
  12. Feb 3, 2019 at 9:09 AM
    RDC
    RDC Member
    None yet
    Thank you. Makes me feel a lot better knowing the noise doesn’t necessarily mean it’s time to replace. I’m used to my old Dodge Ram- if it made a noise, something had already fallen apart.
  13. Feb 6, 2019 at 11:44 AM
    Plucky was his name
    Plucky was his name Well-Known Member
    Carl
    Central East Texas
    2007 Reg Cab Taco 4x4 5-speed manual
    ARB Front Bumper, Wet Oakle Seat Covers, Aftermarket Stereo, OME suspension with Heavy Duty Dakar Leaf Springs
    My original clutch lasted 220,000 miles. Would have gone further, but replaced the 5-speed transmission at 220K, and since it was all right there just decided to do everything in one swoop.
  14. Feb 6, 2019 at 11:50 AM
    nh_yota
    nh_yota Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    60K miles.
    Three weeks after I had the throwout bearing replaced under warranty, one of the springs in the clutch disc popped out and wedged itself in between the clutch and the pressure plate so I couldn't disengage the clutch. Dealer swore it had nothing to do with the work they did but I argued it was one hell of a coincidence that it happened three weeks later.
  15. Feb 6, 2019 at 12:51 PM
    #35
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    I had a similar story. Factory clutch was right near the very top of the pedal travel and was super tight. Put in a new clutch at 175k and it was a dream for a couple thousand miles now it's right back where it was before. High and tight. Kind of annoying but I don't know what to do about it.
    Also my throwout bearing squeaks now too despite having greased it up during install. In other cars I've had some success shooting 30 weight oil from an oil can (the kind with spout and trigger that can shoot like a 10 foot stream if you really squeeze it) through the clutch fork hole onto the bearing to shut it up for awhile, we'll see if that works on the Taco. Maybe 90W will last longer, idk.
  16. Feb 6, 2019 at 1:38 PM
    #36
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    173k still going.
    I’ve been pretty much the only driver since 40k.
    Did try teaching my daughter to drive manual a few times.
  17. Feb 6, 2019 at 6:48 PM
    #37
    Bluebaron7
    Bluebaron7 Well-Known Member
    Augusta, GA
    2009 Tacoma Double Cab TRD Off-Road(Sold)/2024 4Runner ORP
    3 Inch Lift, Leaf spring pack, SPC UCA's, Bilsteins 5100's, AFE CAI, ECGS Needle Bearing, CVJ Axles, Under seat Infinity Sub & 4 channel amp, softtopper, decked system, prinsu roof rack, Kenwood deck & Infinity speakers all around with door matting, taco sauce only sticker, steering wheel leather wrap and dash cam.
    127,000 on my original clutch and she is doing just fine.
    I taught my girlfriend how to drive a stick with it so.....129K was my number; my clutch just went out.
  18. Feb 6, 2019 at 8:51 PM
    #38
    JSB10
    JSB10 Well-Known Member
    2005 Tacoma
    203000 on my original clutch. I have thought about replacing it but right now it works fine so I will just go with it.
  19. Feb 6, 2019 at 8:59 PM
    #39
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    If you know how to rev match / float the gears without using the clutch your clutch will last a long time
    Larzzzz likes this.
  20. Feb 6, 2019 at 9:15 PM
    #40
    joes06tacoma
    Joe
    Central Coast, CA
    My original clutch was replaced around 50K due to chirping throwout bearing. Otherwise it all looked perfect. I do wonder what would have happened if I had just ignored it, but Toyota paid for it, so why not.
    8 years and 45K later (don't drive much), I had to have it replaced again because it was not wanting to fully release when cold. Again, visually it all looked great. A shame, but I don't think mechanical things are supposed to sit as much as this truck does.
