How many miles over needing an oil change?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ASUAviator, Jul 30, 2014.
How many miles over?
  1. Never have let it happen
    19 vote(s)
    32.8%
  2. 250+
    11 vote(s)
    19.0%
  3. 500+
    6 vote(s)
    10.3%
  4. 750+
    3 vote(s)
    5.2%
  5. 1000+
    5 vote(s)
    8.6%
  6. 1500+
    4 vote(s)
    6.9%
  7. You dont want to know
    10 vote(s)
    17.2%
  1. Jul 31, 2014 at 7:17 AM
    XRedJar
    XRedJar Member
    Laurel, MD
    2014 Tacoma 4x4 TRD
    The additive package in the oil is usually "wears" out faster than the base oil itself. From what I've seen, just about any "good" oil will get you to 5,000 to 7,500 miles with no problems. On my WRX, I changed every 4k just because of it being a turbo. I plan on changing at my first 1,000 miles, and every 5k after.
    I'll probably just run Mobil 1 like most of my other vehicles. Seems to have done well so far.
  2. Jul 31, 2014 at 7:51 AM
    jharkin
    jharkin Well-Known Member
    Jeremy
    Massachusetts
    14 DCSB TRD OR
    12volt/20amp bed outlet access tonneau
    I just recently read the full "motor oil 101" on bitog and learned a lot from that. One thing I didnt realize... the big difference in extended life is that eventually the viscosity modifiers in conventional oil wear out and it looses the multi-viscosity property and starts to thicken up; whereas in synthetics the multi-viscosity trait is designed into hte base stock and never wears out. Also apparently synthetics run a bit thinner when cold even at the same weight grade as a comparable conventional which helps to reduce start up wear.
    My last couple vehicles Ive run Mobil 1 at 5k intervals (conservative but fits the warranty req) and plan to do the same on my Taco :)
  3. Jul 31, 2014 at 8:21 AM
    Yota64
    Yota64 Professional Threadjacker
    Yep, I use Mobil1 everything.
  4. Jul 31, 2014 at 8:24 AM
    TuckGraham
    TuckGraham Keep it straight
    Tg
    Montana
    I went over by 2000 miles. the sticker had ripped off. When i went in, they said i was still good. I drive it everyday and in the snow most of the time.
  5. Jul 31, 2014 at 8:30 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    This summons up me too :thumbsup:
