How many miles since tsb 0062-18 and tsb 0058-18
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ChickoSM1808, Aug 1, 2018.
  1. Aug 6, 2018 at 7:20 AM
    DuraTaco
    DuraTaco Active Member
    Bryce
    Austin, Tx
    I only have 300 miles on mine since I had both updates done. The difference is night and day. It honestly feels like I'm driving a different truck. I reaaalllllyyy hope it stays this way.
    Taco16LB and bshammer0 like this.
  2. Aug 6, 2018 at 9:06 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    I have about 300 miles on the new ECU version and have not yet noticed any significant regression in shifting as with prior versions. With the prior ECU version I couldn't get more than a day or 2 in before it would learn to race to 6th at slow speeds or under acceleration which made it necessary to use things like S-4 + ECT around town.
    Taco16LB likes this.
  3. Aug 6, 2018 at 6:03 PM
    ChickoSM1808
    ChickoSM1808 [OP] Well-Known Member
    Michael
    2018 dcsb TRD Sport (OVTuned)
    OVTuned, TRD Pro grille, 32's and many more
    Ya so far the lugging on the highway in sixth then down shifting to fourth instead of 5th seems to be gone. Also the 6th gear at 48 mph seems to be non existent. Clearing the tranny computer can only be done with Techstream software on a lap top using an obd2 wire that connects to usb port.
  4. Aug 15, 2018 at 4:41 PM
    Ljid13
    Ljid13 Well-Known Member
    2018 TRDOR 4x4
    Anyone else?
  5. Aug 15, 2018 at 4:43 PM
    bshammer0
    Brandon
    Nashville, TN
    I have 1,000 on the update and have noticed little to no degradation in shifting behavior and prior versions had me pulling my hair out within 200 as the learning set in.
  6. Aug 15, 2018 at 4:47 PM
    ChickoSM1808
    Michael
    Same here. 1,000 miles in still consistent shifting and good power. No complaints.
  7. Aug 15, 2018 at 8:46 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    So what’s the ecu calibration version we need to look for?
  8. Aug 15, 2018 at 8:51 PM
    ChickoSM1808
    Michael
    Last 4 digits are 4100 and 6100 for the 2018 model year.
    khouan likes this.
  9. Aug 15, 2018 at 8:59 PM
    Flash1034
    N/W Montana
    4100 and 6100 are the last four of the good and updated ecu calibration after the tsb?
  10. Aug 15, 2018 at 9:03 PM
    ChickoSM1808
    Michael
    That's correct
    Flash1034 likes this.
  11. Aug 15, 2018 at 9:05 PM
    tow-coma
    tow-coma Well-Known Member
    What mileage is this covered under warranty? I have almost 50k. Will it be free? until 60k?
  12. Aug 15, 2018 at 9:06 PM
    ChickoSM1808
    Michael
    Yes it is covered under emission warranty.
  13. Aug 15, 2018 at 9:15 PM
    Bubba503
    Bubba503 Well-Known Member
    PNW
    2022 Tacoma TRD ORP Lunar Rock
    Can anyone confirm if these tsbs are the same? I took mine to the dealer and they did 0058-18 and the truck still likes to sit at 3-3500 rpms when I have reached 60-70mph even when I take my foot off the gas
  14. Aug 15, 2018 at 9:23 PM
    ChickoSM1808
    Michael
    From what I've gathered from data on my Techstream is that one is for the engine ecu and one is for the transmission. I clearned the learning computer after the tsb's were done. Since then no issues yet.
  15. Aug 15, 2018 at 9:29 PM
    #35
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    500 miles since 0058-18 was done for me and I have seen an improvement. It's not 100%, but it shifts much better. The dealer said give it a few thousand miles to learn before bringing it back it, but imunless it gets worse I will leave it alone. It's good enough to satisfy me
    ChickoSM1808[OP] likes this.
  16. Aug 15, 2018 at 10:13 PM
    #36
    Mountain2018
    Mountain2018 Well-Known Member
    Harpers Ferry/Leesburg VA
    2018 4x4 SB gray
    I have about 675+ since the update and still runs like the new truck I had when the updates were done. I live in a fairly hilly area with a few poor mans mountains. The truck does not search for a gear like it did but seems to acelerate as one would expect. Most interesting is i had become used to reaching for the ECT 80% of my rides. Think I used it once since updated when carrying 600 pounds in the bed. Fingers crossed this stays the norm.
  17. Aug 16, 2018 at 4:20 AM
    #37
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    I've put about 600 miles on my truck since the update. I'm extremely happy with it, the truck feels much more crisp in response and all sluggishness is gone. My MPG has notably increased as well. My daily commute to work has no highway driving and involves lots of red lights, hills and speeds of 35-50mph. Prior to the update, I was consistently getting 18.5-19.8mpg. Currently, I'm getting 20.8-21.5mpg for the exact same trip at the same time of day with no change other than the calibration update. Now that the truck doesn't lug around in 6th gear until it has to jump to 4th or 3rd it is much more efficient.
  18. Nov 3, 2018 at 12:52 PM
    #38
    Amanelot
    Amanelot Member
    Texas
    Anyone know if you can check what tsbs have been done with techstream?
    Edit: I found it, is the calibration Id different on the 2016s?
    Mine lists
    Engine: 8966304B0400
    Trans: 896650401400
  19. Nov 3, 2018 at 12:56 PM
    #39
    JimmySport
    JimmySport Well-Known Member
    I have about 4,000 miles on mine since having the TSB done. truck still runs like it did the day they did it. way better than the night I took delivery. I have noticed an average of about .5 mile better fuel mileage as well, nothing great but it is an improvement.
  20. Nov 3, 2018 at 1:06 PM
    #40
    nvnv
    nvnv Stop geotagging
    Connor
    2016 Tacoma TRD OFF ROAD
    I have 2-3k on mine since it was done. Shifts better and the stumble is gone and I haven’t noticed it getting worse. Of course the way it shifted before didn’t really bother me, but I can definitely tell there’s an improvement.
