how many mpg am I losing?
Discussion in '4 Cylinder' started by taxidermist, Dec 23, 2013.
  1. Dec 23, 2013 at 7:24 PM
    taxidermist
    taxidermist [OP] Member
    north Carolina
    12 access cab 4x4 5spd base
    Today I purchased a 2012 Tacoma 2.7l 5spd 4x4 access cab.
    Love it so far. But the manual calls for 245 tires and it has 265 on it. I'm wondering how much performance I'm losing and especial how many mpg.
    Thanks
  2. Dec 23, 2013 at 9:44 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    Hi tax, and welcome to TW. :wave:
    Your tire diameter difference from stock effects your odometer's accuracy. So add 4% to whatever gas mileage you're calculating because you're actually travelling about 4% farther than your odometer is indicating.
    Greg
  3. Dec 24, 2013 at 3:07 AM
    DPR921
    DPR921 Well-Known Member
    Dylan
    Cheshire, MA
    08 SR5 4x4 2.7
    are the 265 70 or 75? 70's none.. I dropped maybe 2 mpg when i went to 265 75's
  4. Dec 24, 2013 at 9:29 AM
    taxidermist
    north Carolina
    It calls for 245-75r16
    It has on it 265-70r16
  5. Dec 24, 2013 at 11:46 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    Unless I miscalculated, the diameters of both sizes are nearly the same. The only likely effect on gas mileage is probably due to any difference in weight, and that would be minimal.
  6. Dec 24, 2013 at 1:23 PM
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    http://www.tacomaworld.com/forum/tirecalc.php
    Like others have said, they are nearly identical. It will all come down to weight and the type of tire A/T, All season, P trim, LT trim etc etc...I got the M/S2 all season P265/70/16 and see no difference in MPG ftom the 245/75/16 Dunlop at20, just overall better driving experience
    ms2 are 20lbs heavier than the dunlops.
  7. Dec 24, 2013 at 1:30 PM
    tooter
    Greg
    Los Angeles
    Within .4% of each other.
    That's a pretty close match. :)
  8. Dec 24, 2013 at 6:14 PM
    taxidermist
    north Carolina
    Thanks guys. I don't knew much about tires.I usually just replace the old ones with what's on the sticker.
