How many mpg for my 03 Tacoma TRD 6 cyl
Discussion in '1st Gen. Tacomas (1995-2004)' started by seanmichaels, Jan 20, 2011.
  1. Jan 22, 2011 at 7:57 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    Pulled out my sticker......for my Manual transmission it is 17city 20highway.
    The best I have ever seen was 20.1 mpg on a trip from Flagstaff, AZ to Gallup NM; empty trip. At the time I had 285/75/16 with 3" fagtech lift. Since then, I have added campershell with roof rack, lowered the truck to a 2" lift (OME), and down sized to 265/75/16 (E-RATED :mad:). The best I have seen with this setup is 19.3mpg hwy, though I had 300lbs of hunting gear in truck. In town I average 17-18 empty truck.
  2. Jan 22, 2011 at 8:00 PM
    NegroTundra
    Land of Enchantment
    Awesome app! Thats the only useful smartphone feature I've ever seen! Maybe I do need one:rolleyes:
  3. Jan 22, 2011 at 9:15 PM
    coehorn1
    coehorn1 Well-Known Member
    '03 4x4 2.7I4 5sp "beast"
    I would think twice about a smartphone. Neither Apple or the android phones gives a flying flip about your privacy. Worse still -- they absolutely do not believe you have a right to privacy.
    Caveat emptor.
  4. Jan 23, 2011 at 12:03 PM
    NegroTundra
    Land of Enchantment
    ^Hehe....same attitude that I have and my wife says I'm paranoid =)
  5. May 14, 2013 at 7:21 PM
    ChanhDoan
    ChanhDoan Member
    C DOAN
    TEMPE, AZ.USA
    2001 Tacoma SR5 PreRunner, 98 4Runner, XD
    PLANNING lift 4" on 15LT tires, but only 2WD with TRD rear diff lock, THEN ?? worth or not?
    I got 25MPG easy on freeway with Mobil 1 0w-30 synthetic oil with 35PSI for 4 tires and driving with cruise control 65 mph....keep PCV valve clean and air box +air filter clean...all that keep clean ..You will get like me....and do not forget to change spark plugs..When did the last time you change? I did every year + Fuel filter ...good luck
  6. May 14, 2013 at 7:21 PM
    ChanhDoan
    ChanhDoan Member
    C DOAN
    TEMPE, AZ.USA
  7. May 14, 2013 at 7:30 PM
    ChanhDoan
    ChanhDoan Member
    C DOAN
    TEMPE, AZ.USA
  8. Aug 4, 2013 at 1:38 AM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    25.3mpg is my record :D
    95.5 V6 Manual 212k
    Pretty much stock (AKA, not 400lbs worth of aftermarket armor; no lift, etc.)
    Got Redline Oil/Fluid in everything; OEM Oil Filter / Air Filter
    I use Chevron w/Techron 92
    When I drive my truck on the freeway at 70mph, I get right around 20-21mpg
    When I take the scenic route; with a max speed of 45mph, is when I'll get 24-25mpg
    And I don't mean I once saw that # randomly on a scangauge while going down a hill in gale force winds while in neutral;
    This what I'll get on a tank I put 220-something miles on (I usually refill when the needle hits a half-tank)
    My goal is 26mpg... I may have to drive at 40mph with people furiously honking and passing me
    But, I think I can do it
