How many MPGs could I gain (realistically) going back to stock tires??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by vrsantana, May 19, 2022.
  1. May 19, 2022 at 3:54 PM
    vrsantana
    vrsantana [OP] Active Member
    Victor
    Mount Dora, FL. Lake County
    2018 Tacoma TRD Sport
    Leveling Kit, 285 70 17 BFG K02 All Terrain Tires, Black rear bumper covers.
    I currently drive on BFG K02 285/70/17 on my stock TRD Sport wheels. I have a leveling kit and 1.25" spacers.
    My issue is that I am driving like 100+ miles/day for work and I'm getting like 17-18MPGs combined hwy/city driving.
    Could buying OEM tires give me a significant improvement in my fuel efficiency? I'd totally keep my K02's and put them back on once gas goes back down (fingers crossed) or when I don't have to drive so much for work.
    Any and all input is welcome...as long as you're not an a**hole telling me to go get a Prius. If that's your input, keep scrolling.
    Thanks!
  2. May 19, 2022 at 3:58 PM
    Dubiousveracity
    Dubiousveracity Well-Known Member
    2018 TRDOR DCSB MT
    none
    Depends a lot on what kind of driving you do. Lots of stop and go and a light tire will help a fair bit. Go back to stock, limit your top speed to 65ish, and drive so you don't have to touch the brakes and that's about as good as you'll be able to do. You could get into the low 20s.
    If you really want to get crazy make an aerodynamic "fastback" topper.
    Key-Rei likes this.
  3. May 19, 2022 at 3:59 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    What ply tires are your BFGs? E rated?
    Since you're in Florida (flat land) with an automatic transmission you should be able to get >21.5 mpg with stock tires and relatively gentle driving style**.
    Unless you're hitting several dozen stoplights or are in constant stop and go traffic.
    Did you not have the stock tires on long enough to get a feel for how they performed?
  4. May 19, 2022 at 3:59 PM
    AxisCab
    AxisCab Well-Known Member
    Dave
    Bumville, or some dam place
    2018 2.7L 2WD Auto6, utility Axis Cab
    firewood scratches, Labrador hair/slobber, American flag sticker, Total Chaos bed stiffener, Scepter H20 can, onboard air
    Stock configuration returns stock MPG numbers.
    I am stock tire size, no lift, no racks, no armor and easily get the sticker 23mpg, in mixed driving.
    Straight highway driving, I easily get 25
  5. May 19, 2022 at 4:16 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Light tires would help but you also got to do the math on how much gas money you would save on stock tires vs the cost of those tires for buying lighter tires to be cost effective
    Junkhead, usmc2msu and Tocamo like this.
  6. May 19, 2022 at 4:18 PM
    BIGW0RM
    BIGW0RM Well-Known Member
    I get like 14-15 with stock tires and my new 275/60/17 tires. My taco just sucks it down! Best Ive ever seen was 22 on the highway for an hour. Im in socal so lots of suburbia driving, stop n go I guess. But nothing like LA traffic.
    vivid02 likes this.
  7. May 19, 2022 at 5:18 PM
    vrsantana
    Victor
    I was unable to know what type of MPGs the original tires got me since I put the BFGs on the day I got the truck (used) since the old stock ones were nearly bald. The BFGs are an E rated 10 ply tires. I know they're heavy as well as being oversized for the truck.
  8. May 19, 2022 at 5:53 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Around 2 mpg gain.
    Let's do math .. it's fun.
    That would take you to around 20mpg or a 10% gain.
    If you can go 350 miles before filling up then you will gain 35 miles per tank or about 1 and 3/4 of a gallon per fill up. If gas costs $4.50 a gallon, that would equate to a saving of $7.87 per fill up.
    So to make things easy let's say your new set of tires costs $787 for four tires and mounting. This means you need 100 tanks of gas before you recoup your money.
    If the new tires have a 50K tread life, you will end up paying for the tires through gas savings with about 15K miles left in the tires.
    If you drive 500 miles a week, it will take you 70 weeks to pay for your tires.
    Good luck!
  9. May 19, 2022 at 6:11 PM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    Why bring reality into the equation?
    Junkhead, AxisCab, usmc2msu and 9 others like this.
  10. May 19, 2022 at 6:16 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Not enough to pay for the tires.
    wilcam47, HBMurphy and vivid02 like this.
  11. May 19, 2022 at 6:18 PM
    MTB_Tacoma
    MTB_Tacoma Well-Known Member
    2022 Electric Lime Tacoma TRD Pro MT
    At the moment, I’m getting 19MPG on brand spanking new TRD Pro (stock). If it can help. That’s daily driving on rural roads (20/30 miles per day).
    WoodsGhost and vrsantana[OP] like this.
  12. May 19, 2022 at 6:19 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Do the math man!!! Mazel Tov brother, that made my fucking day!
    Malvolio and hiPSI[QUOTED] like this.
  13. May 19, 2022 at 6:22 PM
    BuddyS
    BuddyS Well-Known Member
    Maryland
    2013 TRD Sport 4x4 MT
    I lost about 1.5 mpg going from the stock tires on my 2013 (V6 MT 4x4 Access Cab) to more aggressive Coopers. It's not worth it to change them out just to chase the MPGs, but when it comes time -- when the tires are worn out -- I'm going to go back to stock or even more eco-optimized tires.
  14. May 19, 2022 at 6:25 PM
    DJR81
    DJR81 Well-Known Member
    2013 5 lug 4 speed auto
    all true stuff
    hiPSI[QUOTED] likes this.
  15. May 19, 2022 at 6:37 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    And *poof* now op is gone. And people wonder why some of us get bitchy.
  16. May 19, 2022 at 6:44 PM
    DJR81
    17-18 sounds good for that setup
    2wdSR52022 likes this.
  17. May 19, 2022 at 6:46 PM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    You must be coasting down hill with a tailwind both ways.
    ToyoTaco25, 2wdSR52022 and vivid02 like this.
  18. May 19, 2022 at 7:09 PM
    The_vue's
    The_vue's Well-Known Member
    18 cement
    2018 do the latest tsb update. That will help. Don't even bother with a tune. I'm back to stock tune with better mpgs. I'm looking for stock tire too for that very same reason.
    AODRN and vrsantana[OP] like this.
  19. May 19, 2022 at 7:11 PM
    Bishop84
    Bishop84 Well-Known Member
    Im in the same boat, I've dialed up my heavy tires to 44psi warm, and its been much better.
    The ride is worse and tread is wearing in the center, but right now fuel is king.
    If you do go back to stock, go 245/70R17 Skinnier with a highway tread for ultra milage.
    vrsantana[OP] and 9th like this.
  20. May 19, 2022 at 7:17 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Prices won't go down much. Barring another scenario where nobody is driving and oil is selling for $1.00 a barrel.
    I remember food prices going up because of the so-called fuel surcharges a while back, but they never went down when gas was at an all time low.
    Oil companies are making a killing and they could care less about you and me, prices may drop but a bit but I suspect $4.00~$4.50 will be the new norm.
    Memorial day weekend is upon us, I saw prices jump .20 a gallon over a few hours. Should have filled up at $4.60.
    ps: I don't like it either.
    Greg-tacoma likes this.
