How many MPGs could I gain (realistically) going back to stock tires??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by vrsantana, May 19, 2022.
  1. May 19, 2022 at 7:19 PM
    111R
    111R Well-Known Member
    Try using premium gas for a tank and see if it improves. Cost difference might be 10% but increase I’m gas mileage could be more than that according to some on this forum.
  2. May 19, 2022 at 7:31 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Um...no. Those on the forum saying "yes" are Ill
    informed.
  3. May 19, 2022 at 7:38 PM
    Gamma11
    Gamma11 ((‘)) yea, i like the taste
    Andrew
    Northeast
    2024 DCLB OR Bronze Oxide, 2022 T4R ORP Super White
    I did this recently only because they were doing maintenance on the regular pump at Costco and charging the same price for premium. No change
    vrsantana[OP] likes this.
  4. May 19, 2022 at 7:39 PM
    111R
    I haven’t tried it so no opinion either way. Just what others have suggested.
    hiPSI[QUOTED] likes this.
  5. May 19, 2022 at 7:41 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I tried it a few years ago. It was a wash.
  6. May 19, 2022 at 8:02 PM
    vrsantana
    vrsantana [OP] Active Member
    Victor
    Mount Dora, FL. Lake County
    2018 Tacoma TRD Sport
    Leveling Kit, 285 70 17 BFG K02 All Terrain Tires, Black rear bumper covers.
    That was my thought. I calculated that IF I can get an extra 5 MPGs out of stock tires, it would be worth about an extra 100 miles/tank of gas.
    This was pretty much my calculation but I was assuming getting like 22 or 23MPGs since I currently get 18MPGs. So it would be more like a 20% gain. So I would go from 350 miles per tank to 420 miles per tank. That makes it like 3.25 gallons per fill up. Same calculation $4.50/gal would equate to around $15.40 per fill up.
    If I'm driving 500 miles/week or 2000 miles/month, that would mean that I would go from 5.7 fill ups per month to 4.7 fill ups per month. 20 gal tank at $4.50/gal is about $90/tank of gas. So I would be saving about $90/month.
    Nearly same calculation as yours, but I adjusted the MPGs to reflect what I'm currently experiencing with my big tires.
    Did I get it about right?
    I appreciate you walking through the math. It was quite enjoyable working through it.
  7. May 19, 2022 at 8:03 PM
    vrsantana
    Victor
    I've been running my tires at 40 psi and it got a little better, but I think I want more.
  8. May 19, 2022 at 8:06 PM
    vrsantana
    Victor
    Also, another variable here is the ability to find a set of stock tires as "take offs" from people changing out their rims and tires. I've seen a few sets online in "like new" condition for about $500 or less. Finding some at a good deal will definitely be key.
    Gen3TacomaOBX and ToyoTaco25 like this.
  9. May 20, 2022 at 4:23 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Tires alone will absolutely not give you a 20% efficiency gain. And, if you did the math, why ask the question?
    wilcam47 likes this.
  10. May 20, 2022 at 5:30 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    I said this before about the 90 Billion profit last year for the oil company’s, they charge what the market will support. Expect $6.00+. Before it starts to level. On mileage I believe a light bed cover helps to reduce drag. Is the air dam in the front still in place? You must remember it’s a truck not expected to get 30 mpg. Best of luck
  11. May 20, 2022 at 6:01 AM
    vorkuta775
    vorkuta775 Well-Known Member
    Texas
    tesla truck
    Not even worth the money to buy new tires just to save a few mpg, math doesnt add up. It will cost you the exact same maybe a bit more since rubber went up too.
  12. May 20, 2022 at 6:08 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    That would probably be your best bet if you wanted to try it and see what the real world numbers are for you. Then sell them if you don't like the results
  13. May 20, 2022 at 6:10 AM
    JWestie
    JWestie Well-Known Member
    2019 Tacoma DCLB-OR Mag gray
    You could game 23+ MPG going with a lighter HWY tire (stock size) with less rolling resistance. I had notable MPG gains going from Wrangler/OR Wheels to Defender/Pro wheels, which saved ~ 7lbs per corner in addition to less rolling resistance. You will save some $$$ at the pump and maybe some psychological relief knowing you're running as efficiently as you can.
  14. May 20, 2022 at 6:14 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    You have any friends with stock tacomas? Swap wheels and tires with them for 1 week and prove to yourself if it will or won't be worth it at the pump. My vote is absolutely not. 5 mpg is extremely unrealistic. I've gotta ask bc no one else has, how do you calculate your gas mileage? Going off the dash display?
  15. May 20, 2022 at 6:36 AM
    #35
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    OP, your tires weigh ~58 lbs. The stock highway tires that come on the SR/SR5 weigh ~36 lbs.
    That's 22 lbs and something close to a 40% increase in weight per corner.
    Additionally unless you're re-geared the tire diameter also works against the torque that our trucks generate low in the rpm range.
    Tires alone won't net you 5 mpg BUT driving/accelerating slowly AND the lighter tires could since you drive around relatively flat terrain.
    If you lived in mountainous terrain then stretching the miles in a Tacoma is pretty much impossible... kinda similarly to driving around with large and heavy tires.
  16. May 20, 2022 at 6:45 AM
    #36
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    He didn’t, obviously, because he didn’t include the therapist’s bills for helping cope with the loss of badassery that come with the KO2s
    AxisCab and hiPSI like this.
  17. May 20, 2022 at 6:46 AM
    #37
    Malvolio
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    No we don’t! Happy Friday, peeps!
    AxisCab and hiPSI[QUOTED] like this.
  18. May 20, 2022 at 6:47 AM
    #38
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    When i changed the the tires on my stock sr5 i weighed the firestones...33 lbs and change. I replaced them with goodyear adventure 265/70 16's. They weighed almost 40 lbs. I might have lost 1 mph, about the same as removing the chin spoiler.
    Gen3TacomaOBX[QUOTED] likes this.
  19. May 20, 2022 at 6:54 AM
    #39
    Gen3TacomaOBX
    S
    That is interesting that the stock tire diameter and simply adding ~7 lbs per tire knocked off a whole mpg.
  20. May 20, 2022 at 6:54 AM
    #40
    vorkuta775
    Texas
    tesla truck
    hard facts!
