How many MPGs will I lose if I get larger tires?
Discussion in '1st Gen. Tacomas (1995-2004)' started by willc984x4, Jan 1, 2017.
  1. Jan 1, 2017 at 6:04 PM
    willc984x4
    willc984x4 [OP] New Member
    William
    White 1998 2.7l 4x4
    Thrush Muffler
    I drive a 1998 2.7l sr5 4x4 extra cab. I have stock size tires on it now, no lift. I'm wanting to get some 31x10.50x15 soon and I've read that they'll fit but I haven't been able to find much about how many MPGs I'm going to have to sacrifice. Thanks
  2. Jan 1, 2017 at 6:11 PM
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    Depends on how you drive. Drive like your in NASCAR or Grandmother? It all depends
  3. Jan 1, 2017 at 6:14 PM
    willc984x4
    William
    White 1998 2.7l 4x4
    Thrush Muffler
    I'm usually pretty easy on it.
  4. Jan 1, 2017 at 6:15 PM
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
  5. Jan 1, 2017 at 6:15 PM
    Wolftaco0503
    Adam
    Chicago
    Probably 2-10 depending on use
  6. Jan 1, 2017 at 6:16 PM
    herbertgerg
    herbertgerg Well-Known Member
    Gary
    1999 SR5 4x4 5spd Access Cab
    I have a 99 SR5 5spd 4.30 rear. Running a 265/75r16(31.6x10.4). I usually carry around 300lbs of tools and shite. TG low pro front bumper, not very aerodynamic up front. If I keep my foot out of it I can average around 20 mpg highway. More like 14-16 sitting through traffic, it will drop off after 65+ mph(hand calc) Try to keep your momentum, shift at 2500 rpm and accelerate as slowly as the traffic behind you will tolerate.
  7. Jan 1, 2017 at 6:20 PM
    Wolftaco0503
    Adam
    Chicago
  8. Jan 1, 2017 at 6:30 PM
    Clearwater Bill
    Billy
    Largo Florida
    You'll lose about the % of the size difference.
    Take a look at the Tire calculator
    DustStorm4x4 likes this.
  9. Jan 1, 2017 at 6:33 PM
    Taco Addiction
    Houston, TX
    I have 265/75/16s and have noted the below (estimates only)
    1-50 MPH: fine
    50-60 MPH: shows +~2 MPH
    60-70 MPH: shows +~4MPH
    70+ MPH: shows +~6MPH
    this done unscientifically with a GPS unit while driving. I see where my speedometer becoming more inaccurate during highway driving. The effect is clearly not linear and there is more to all this I am certain elsewhere but wanted to share my experiences.
    I am very aware of the delta on the highway and have no plans to correct.
  10. Jan 1, 2017 at 6:42 PM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Not knowing this has saved me lots of tickets I am sure. I drove my last truck for probably 5 years before I finally realized my speedo was not accurate. At about 30 mph it started to be off. Just a mile or two, but up around 70 it was more like 6 to 8.
  11. Jan 1, 2017 at 6:42 PM
    shawnster88
    shawnster88 Well-Known Member
    Shawn
    Defuniak Springs, FL
    96 Tacoma Reg cab 2.7 5 speed
    OME 881 coil springs, OME nitrocharger sport shocks front and rear. Nitro 4:56 gears. ARB rear locker. Shrockworks front bumper with Warn M8000S winch. 17x9 SCS Ray 10 wheels w/ 285/70/17 Toyo Open Country RT Trail tires. Corbeau Trailcat bucket seats. Go Rhino roll bar w/ KC Daymaker lights. GMRS Radio. Ham Radio.
    I got 265/75/16 and here's about how mine is...I checked with a gps.
    1-30 is ok.
    30-50 speedometer is about 5 slow.
    50-65 speedometer is 8 slow.
    65-up speedometer is 10 slow.
    So if I'm driving 60, speedometer shows 52. I've checked this against two different gps units.
    Spare Parts likes this.
  12. Jan 1, 2017 at 7:23 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Shouldn't be much loss with 31"s. I have 33x10.50s on my 97 2.7 5spd 4x4 and I still average low 20s for daily driving mpgs.(during the summer, it drops to high teens with winter blends and cold weather)
  13. Jan 1, 2017 at 7:25 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    At least 1. Everything I've done has knocked off 1 at a time.
  14. Jan 2, 2017 at 12:22 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Keep in mind you're running more miles than usual with those tires. More than is spooling up on your odometer, thus making the mpg's lower than you would think by a bit...not by much though i guess, if you're only jumping to 31's...
  15. Jan 2, 2017 at 4:57 AM
    Indy
    Indy Master of all I survey.
    You'll also be turning more mass with larger tires. Some models are heavier than others. You have mass, rolling resistance, decreased torque.... it ads up. I went from low 20 to mid high teens. I worry more about getting going than mpg.
    Speedo and odo will be off by a %. If your new tire is 10% larger in circumference you need to adjust everything else 10% as well. Thats why low speed the speedo ks almost correct and the error appears larger the faster you go. Regearing can fix most of the above.
  16. Jan 2, 2017 at 5:22 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    What is your gear ratio? That will make a difference
  17. Jan 2, 2017 at 8:19 AM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    I figure my mileage by hand taking the % change into account. Going up a size dropped me a MPG, lifting dropped me another. I got 16. Threw some stock 31's back on and went back to 17. Just saving up for another set of 265/75's E-rated though just because I like the idea of not getting flats on the beach (hard head catfish spines). I'm sure all kinds of things play a part but if you don't want to sacrifice mileage, keep it stock.
  18. Jan 2, 2017 at 10:15 AM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Depends on what your stock tire size was
    Don't forget the weight of tires which truck owners ignore
    My truck OeM came with 29inch 225 series
    If I put 265/70/16 which most are almost 48lb I am adding 12lb per corner
    Of course there will be mpg loss
    Most BRO have no idea how to do math and how much loss will be not to mention unless you regear will be slow as heck
    Good luck
  19. Jan 2, 2017 at 11:16 AM
    vern650
    brandon
    hyrum, ut
    That's what I expected, but my speedo was actually off when I had smaller tires and going up to the 33"s brought it back to where it's almost dead on with the GPS on my phone.
  20. Jan 2, 2017 at 11:28 AM
    3rYODA
    3rYODA Don’t sell to me, I don’t pay.
    Santa Clarita, CA
    2015 white 4x4 TRD
    Fox 2.5’s up front, icon 2.0 rear shocks, stock leafs, !Meso map and dome lights make all the difference in the world!
    I count my tuck and put the tires and Rims on the nect day, I wonder if I would feel a different my mpg is 25mpg if I keep the foot of the gas, I can get a solid 21 if I keep it at 80mph
