How many of you have brake pad slap?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by js312, May 22, 2015.
Do you have brake pad slap?
  1. Yes
    124 vote(s)
    79.5%
  2. No
    32 vote(s)
    20.5%
  1. May 22, 2015 at 1:23 PM
    js312
    js312 [OP] Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    I'm sort of curious about this. Mine was totally silent until I changed them (w/ new OEM pads) and now I have it. I have taken them out a few times and added more caliper grease around the edges but it always comes back eventually. It's not really a "problem", just annoying to me.
    It'd be interesting to see if there's a trend based on the specific pads we're using.
    What pads do you use and do you/don't you have this occurring?
    So to start:
    Toyota OEM; Yes
  2. May 22, 2015 at 1:51 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Define " Brake Pad Slap ". I don't know what that is.
    81shark, 1bad2k, ManBeast and 2 others like this.
  3. May 22, 2015 at 2:03 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Did you replace the rotors or have them machined? If you just replace the pads alone it can cause noises. Also, did you make sure all brake pad shims are properly in place?
  4. May 22, 2015 at 2:07 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    My 08 had it and new brake pads solved the issue. It's an annoying trait of this brake design, but it's harmless. So far my 14 has not developed the issue, but I only have 7000 miles.
  5. May 22, 2015 at 2:21 PM
    Pigpen
    Dan
    Northwest Montana
    My '12 has it, even with the second spring installed. It's more subtle since adding the spring.
    txtaco87 likes this.
  6. May 22, 2015 at 3:19 PM
    js312
    Joe
    New England
    A "clunk" when starting or stopping just after applying or letting off the brakes. Caused because the pads"float" within the caliper and will knock on either side.
    Brand new Toyota OEM rotors and yes, the shims are there. I do agree with you on not just replacing pads. I've always done rotors at the same time whenever I've done brakes on any vehicle.
    Second spring? I've only got one on each side of my '11.
    Kolter45 likes this.
  7. May 22, 2015 at 3:29 PM
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    18 DCSB 4X4 SR5 Silver Sky Metallic V6 AT
    My 12 does it too. I replace both springs I purchased from Napa, it quieted it down very little but still have it. Just annoying when reversing then going forward again after braking.
  8. May 22, 2015 at 3:31 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    proper springs and greasing them helps..............Its common
  9. May 22, 2015 at 3:35 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Mine is doing it too, needs nee pads, I'm hoping it'll go away after replacing them. Haven't decided what brand I'll go with.
  10. May 22, 2015 at 3:44 PM
    Cjd
    Cjd Member
    East Tx
    2011 4.0 TRD OR 4x4
    Stock except for some small stuff: Diff breather mod, fog lights anytime, interior LED's, hose clamp mod, ultraguage, locking console, stealth mode mod, disable seat belt beep, Hellwig 550 helpers
    I had it until I put on new brake pads and rotors. Went with duralast gold replacements. Installed them around 10,000 miles ago, no complaints.
    BUZZCUT likes this.
  11. May 22, 2015 at 3:53 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    Duralast rotors as well?? I'll look them up.
  12. May 22, 2015 at 3:54 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    2yrs on EBC stage 5 setup......no noise at all.....tho I just started feeling a pulse
  13. May 22, 2015 at 5:58 PM
    gearcruncher
    Canadain bumper technician
    Mine still clicks . Just swapped out the winter tires for the summer rubber and added the second spring on each side . Took the caliper pins out and lubed them up . You could see signs of wear on the caliper pins and where the brake pads meet the caliper housing . My pads were still in great shape as far as pad thickness . Too bad they are worn out where the metal brake pad meets the caliper . It wasnt worth replacing the pads and rotors yet .Gonna live with the " clunk or clack " until the lining on the pads is wore out. I may be one of the few fellas that are out of the ordinary , but I use my ebrake every day and I have an auto transmission . Using the ebrake keeps your rear shoes adjusted prolonging the life of your front brakes . You can read more about why I highly suggest using the e-brake here https://www.tacomaworld.com/threads...sions-write-up-your-4-speed-automatic.325531/
    Here is the link to the brake click fix . In my opinion , the " Click Fix " will only work on low mileage brake pads .The problem with adding the second spring in the link , some guys are adding new pads with the spring , some guys are replacing the pads and adding the additional spring but not replacing the pins , some guys are lubing the calipers , some are not . Some guys are removing the pins and lubing them up , some are not , some are adding new disk quiet to the pads , some are not .Some guys are simply installing the spring without doing or looking at anything else . The end result is a mixed bag of yah it worked for me or is was a waste of my time pulling the tires off
    https://www.tacomaworld.com/threads/brake-click-fix.157684/
    If you have high mileage on your brake pads but the brake lining still looks good , chances are the only way the noise is going to go away is if you replace the pads .
    With this said , I havnt seen a detailed video of a fellow TW member,s truck showing the wear points on the brake pads in comparison to a brand new set of pads .
    If you got a brake job planned , please do some videos or pics with arrows showing us where to look for the play .
    It wouldnt take much once the truck is off the ground with the front tires off . Run it in 4x4 and go from forward to reverse a couple times while you record the movement with your camera
    spitdog likes this.
  14. May 22, 2015 at 6:03 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    As long as the caliper works and durability is not affected, I don't care about the sound. Thinking about leaving out the anti-rattle clip the next time I replace my pads, too. Race calipers are built this way:
  15. May 22, 2015 at 6:29 PM
    Cjd
    Cjd Member
    East Tx
    2011 4.0 TRD OR 4x4
    Yeah I went with duralast gold for pads and rotors. No complaints what so ever. Been quiet ever since
  16. May 22, 2015 at 6:37 PM
    Boilerman
    Boilerman Well-Known Member
    Brian
    Texas, northwest of the Big Pond
    2010 Prerunner SR5 Magnetic Gray 2.7L
    Guess I have the brake slap too. When I barely apply the breaks, I hear a clunk.
  17. May 22, 2015 at 6:52 PM
    Pigpen
    Dan
    Northwest Montana
    Before adding the second spring, mine was crazy loud. It sounded like something was badly broken and I'd get funny looks from across the parking lot or wherever.
  18. May 22, 2015 at 8:30 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Interesting. Not sure that I have this. But every now and then I hear a distinct "thud" under my front left wheel well. Considering how many rocks get stuck in my tire tread I always assumed it was a rock throwing loose. Only seems to happen when I make a turn from a stop sign. There are ALWAYS small rocks on the roads here in Montana - even in city limits.
    Otherwise I don't recall ever hearing anything when braking.
  19. May 23, 2015 at 7:29 AM
    js312
    Joe
    New England
    Looks like I'm going to have to buy a couple more springs.
    Mine is usually pretty tame when it does make noise, but sometimes it's a very big bang. Usually happens if I've been driving a while in hot weather where I've been braking a lot then back out of a parking spot or some other slow maneuver where I'm changing direction. I can only think that something somewhere expands in the heat and makes it worse.
  20. May 23, 2015 at 7:32 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    x2??? is it the same as Bitch slap?:smack:
    igno1tus likes this.
