How many of you have radiation detectors ?
Discussion in 'Hawaii' started by 127.0.0.1, Apr 5, 2013.
  1. Apr 5, 2013 at 9:24 AM
    127.0.0.1 [OP] AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    I am not trying to stir paranoia, and I don't really have a bug-out bag, but
    I have been collecting supplies and this is one item I now have for playing around
    if anything nuclear happens west, are you going to be sure of local areas
    that may have increasing levels of ionizing radiation ?
    As a hobby, (and after Fukushima) I got a little Geiger tube and amplifier
    for myself, and it is interesting to check out background radiation and
    whatnot...also rocks and materials (thorium, tritium tubes...)
    but
    If an ill wind blows, can you expect to always be told what areas are
    safe ? or do you want to be able to inform yourself if there is an
    increase in background radiation that might be worth having officials
    take a deeper look ? or allow you to decide..'gee I need to move away
    from this area or thing making my Geiger tube scream at me' ?
    anyhow, I got one of these and it is a neat device.
    http://www.gqelectronicsllc.com/comersus/store/comersus_viewItem.asp?idProduct=4542
    GQ-GMC-300 (this as well as others allows you to replace the tube with something
    more or less advanced, like a mica window for alpha radiation)
    this is basic and only counts ionizing radiation, beta or gamma...
    [to fully determine health dangers, you need far more expensive detectors and know what
    material you are detecting...these will give you a much better actual human hazard estimate]
    but this little GMC-300 will detect ionizing radiation (beta and gamma) which
    are the harmful types...and it definitely will tell you if background radiation is increasing or decreasing...
    uses an M4011 tube, which is extremely sensitive. You can put a different tube in
    with a mica window (or use a probe) for alpha detection. the difference in quality
    of any detector are the tubes, period. the rest of the device is a simple amplifier
    circuit and logic to make counts, clicks, and graphs...but all of them require a good tube
    and this one has an awesome one....
    FYI I am not trying to sell these things, I just use that link above to show you
    one type of detector that absolutely works, but doesn't cost much at all...
    most cost 400 and up
    anyone else have or play with radiation detector of some type ?
  2. Apr 5, 2013 at 9:51 AM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    Interesting toy.
    We have a CST-WMD(Civil Support Team- Weapons of Mass Destruction) unit here so i'm sure they monitor all of the stuff. Most regions/states have a team and they're on call 24/7.
    I know there are a bunch of old bunkers and stuff here too, but I doubt it's enough for the population. If something big happened, we'd pretty much be SOL unless the winds and waves take the bulk of it.
    Unless I could find a correlation to using that as a tool on my truck, I wouldn't have much intrest in learning more about it.
    I think using that in geothermal areas might be fun though, i'm sure it would pick up something from the rocks.
  3. Apr 5, 2013 at 9:55 AM
    /etc/hosts
    yeah It may be more meaningful to west coast conus, not a set of islands....
  4. Apr 5, 2013 at 9:59 AM
    luka
    Kailua, HI
    did you post this is the right page? :anonymous:
  5. Apr 5, 2013 at 10:02 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    I work with radiation gear all the time with work. You are aware of the ionization effects of background radiation on your meter correct? Also the time required to take a proper reading and that they should be calibrated every year.
  6. Apr 5, 2013 at 10:04 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Hahaha no sooner do I open this thread and "Radioactive" by imagine dragons starts playing :laugh:
  7. Apr 5, 2013 at 11:08 AM
    /etc/hosts
    well, Hi is gonna get hit with radiation first if NK or another
    reactor goes TU
  8. Apr 5, 2013 at 6:04 PM
    Kala
    Kala Well-Known Member
    BigIsland
    05 PreRunner SR5
    i think there was reports of radiation found in tuna several hundred miles off the coast. I think there was found in tuna that was fished off the coast of japan but those tuna also migrated here. I dont think ill post anymore info cause it could be marked as political and theres too much crybabies on this site. Its something that we have to watch for but no doubt, but the US government doesnt care. :p
  9. Apr 5, 2013 at 8:16 PM
    Vigo
    Vigo WFO
    On a rock in the pacific
    '12 4 door
    stuff...
    Saw an interview with Enson Inouye, he was using a meter while helping in Japan after the tsunami. He said that experienced as much radiation on a flight from Hawaii to New York as his stint in Japan. Good thing to have as most people don't know what they're exposed to.
  10. Apr 5, 2013 at 9:05 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Actually due to the amount of solar radiation bombarding the upper atmospheres. A commercial pilots occupation exposure to radiation is on average higher than a nuclear power plant operators yearly dosage.
  11. Apr 5, 2013 at 9:08 PM
    teamamerica
    teamamerica Get off your horse and drink your milk.
    Wy
    2009 tacoma
    none yet
    if it ever came down to it, you're screwed anyways if there was ever a need for the meter. it's like all the crazies with their gas masks. it's not doing you any good. what no one realizes is that most canisters are only good for tear gas, especially if they are opened already, and if you do manage to get some that are sealed and you're exposed to mustard gas or something you have a few hours it's going to work before it ends. and any nerve agent that touches your skin will absorb anyways. save your money.
  12. Apr 5, 2013 at 9:12 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    i work with nuclear quite often, and tbh I am exposed to it alot more than a nuclear worker ;) Ive hit my max dosage rate for the year, sucks but you just have to step back for the rest of the year :p
    big thing to remember
    S.T.D.
    Shielding
    Time
    Distance ;)
  13. Apr 6, 2013 at 12:21 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
  14. Apr 11, 2013 at 9:43 PM
    battleyota
    battleyota Well-Known Member
    David
    Oahu, HI
    Beast of Destruction
    OME suspension, All-Pro UCA, rear locker, 4.56 gears front and rear diffs, rear dif locker, 32x11.5 BF Goodrich Mud Terrians KM2, 15x8 Mickey Thompson classic lock, ARB bumper, K&N Air filter. Safari Snorkel.
    I've got my MOPP-4 gear easily accessible just in case. :D
