How many quarts of engine oil did your dealer fill?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 80sforlife, Jan 18, 2017.
  1. Jan 18, 2017 at 10:23 AM
    80sforlife
    80sforlife [OP] Well-Known Member
    2017 Toyota Tacoma DC TRDOR 4x4
    Based on the provided invoice/ write-up, how many quarts of engine oil did your dealer fill?
  2. Jan 18, 2017 at 10:28 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    What's your real question?
  3. Jan 18, 2017 at 10:33 AM
    Outlier
    Outlier I get around...
    Dallas GA
    2016 Tacoma AC TRD OR 4x4 V6 Slushbox
    No BRO-ness to speak of... Well, except Kbro2's
    Yeah.... what's up? The invoice always says 7. Holds like 6.5 i think.
  4. Jan 18, 2017 at 10:37 AM
    gpb
    Atlanta
    Spec is 6.2qt with filter change.
    Not sure if they're using bottles or a bulk supply for the 0W20. I'm sure they'll still round up even if bulk.
  5. Jan 18, 2017 at 10:43 AM
    Outlier
    Dallas GA
    I am sure they do. Sorry, my "what's up" was meant for the OP, Meaning... "What are you getting at"? Sorry for the confusion!... o_O
  6. Jan 18, 2017 at 10:45 AM
    gpb
    Atlanta
    No worries.
    Funny how they wouldn't sell me 0.2qt of oil at the parts counter. Had to buy seven bottles when I did my (probably unnecessary but it was worth it for peace of mind) early oil change at 1600mi. :D
  7. Jan 18, 2017 at 11:45 AM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Typically, the amount on the invoice is basically for internal purposes only to keep some kind of inventory of what's in the oil tank. 5/6/7L or whatever is no indication of what is actually used. Unless they have a system that bills out the oil on the RO based on the metering system. It's possible, but rarely done from what I've seen.
    Jeff
  8. Jan 21, 2017 at 6:00 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    If you are letting a Toyota dealer change your oil, I would focus on what the dipstick says more than the invoice.
    outlawtacoma, 1bad2k and Herniator like this.
  9. Jan 21, 2017 at 6:04 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    My service tech put 6 quarts in mine. It showed the level at about a toothpick width below the full dot on the dipstick.
  10. Jan 21, 2017 at 6:06 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    7 quarts of bulk Mobil 0W-20.
  11. Jan 21, 2017 at 6:18 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    after getting my 1 year oil change at the dealer (truck only had little over 5k miles on it) i checked the dipstick when i got home and the oil looked a little dirty. work order says changed oil but i have my doubts. lazy tec, saw 5K miles figured it had another 5K to go?????
  12. Jan 21, 2017 at 6:20 PM
    Manvan
    Manvan Well-Known Member
    Paul
    2016 SR5 double cab
    Just let them put in whatever they wAnt. It's all good
    CusterFan likes this.
  13. Jan 21, 2017 at 10:41 PM
    TA2016
    Oregon
    I let Toyota change my oil at 10k and 20k. I do it myself at 5k and 15k just to be safe.
  14. Jan 21, 2017 at 10:54 PM
    the_dau
    the_dau Well-Known Member
    Vancouver BC
    2017 Inferno TRD OR DCSB
    how did you expect to give you the 0.2qt?
    Modesto Tacoma and outlawtacoma like this.
  15. Jan 22, 2017 at 12:05 AM
    JoshyP
    JoshyP Well-Known Member
    Josh
    Northern California
    2016 TRD OR 4x4 DCSB MT
    Does your oil seem a bit high when you look at the dip stick?
  16. Jan 22, 2017 at 4:10 AM
    Outlier
    Dallas GA
    Don't you just love when some ass hat asks a question and then disappears never to be heard from again?? I think all posts should be deleted if the OP doesn't respond to his fellow post replies within 24 hrs.
  17. Jan 22, 2017 at 5:18 AM
    gpb
    Atlanta
    Do you know what a :D means?
    Outlier likes this.
  18. Jan 22, 2017 at 12:31 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    i do the 6 month and 18 month myself. so when i did the 6 month i slightly over filled a bit. when i checked the oil after my 12 month service found it to be slightly dark and slightly over filled that's why i have my doubts if they even changed it.
  19. Jan 22, 2017 at 12:39 PM
    FiaCobra
    FiaCobra Well-Known Member
    The dealer should have put in the correct amount of oil in the truck but....but could bill you for a full 7qts.
    An old trick would be to make a mark on your oil filter like a date, or mileage with a marker. After the dealer oil change, take a peek at the oil filter. I know I know, these trucks now have paper filters within a housing but, you can make a mark on the housing, and where it screws into the block to see if it's been removed.
  20. Jan 22, 2017 at 1:41 PM
    gpb
    Atlanta
    Yep, never hurts to index the key bolts/items with a grease pencil before service.
    FiaCobra likes this.
