how many quarts?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JM76, Apr 19, 2008.
  1. Apr 19, 2008 at 6:24 PM
    JM76
    JM76 [OP] Ride On
    Jon
    SC
    2016 AC SR 4x4
    bone stock save for the block lift that came on it with the open country m/t.
    of oil for an oil change in an 06 trd taco? may be a dumb question but hey, I've got to do it soon and well, I just don't know. thanks.
  2. Apr 19, 2008 at 7:06 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Put in 4.5 qrts, check level, might go to 5 qrts. I know it seems weird but mine bounced between these two amounts ? Also I found it very helpful to get a hose that is 36-38 inches long to drain the oil filter, I do this first and then the engine oil. Be mindful of which plug you unscrew, engine oil V.S. automatic transmission, many people have made this mistake. :D
  3. Apr 19, 2008 at 7:43 PM
    klown
    klown Tacoma World Ring Leader
    Lynchburg, VA
    2008 TRD sport 4x4 double cab 6-speed
    Black, leather and heated seats, borla sport exhaust, side curtain airbags, daytime running lights, all weather mats, JBL premium 6 disk changer system, stainless step tubes, window tint, tow package
    I got a V6 and my first oil change took 5 quarts. You can get 5 qrts of mobil1 5W30 at wal mart for like $23. If you go to wal mart and buy this oil for this price can you come back to this post and gimme some rep?
    --klown
  4. Apr 20, 2008 at 12:35 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    5.5 quarts for your v6(4.0).....and jedi is talking about the nipple under the bottom part of the filter housing....i usually just use an old gatorade bottle to catch any old oil that drains out when i remove the filter.
  5. Apr 20, 2008 at 5:19 AM
    centurion
    centurion Well-Known Member
    Northern New Jersey
    2006 Tacoma TRD Sport,double cab, 4X4, auto, speedway blue
    Air-Raid air filter, de-badged,custom grill,hood and tailgate struts
    If you have the towing option it will take 5.5 quarts, dont know about the 4.0 without it.
  6. Apr 20, 2008 at 6:08 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Look in your owners manual.
    I've got a 4.0L and the manual states 5.5qts. I have an oversized oil filter and the oil level appears low (dip stick sucks!!) - so I actually have about 6qts in it.
  7. Apr 20, 2008 at 8:06 AM
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    i dont know were u guys get your info if u actually read the owners manual it says with filter 5.2 quarts. thats what i did on mine and it is right at the full line.
  8. Apr 20, 2008 at 8:55 AM
    klown
    Lynchburg, VA
    I've got the TRD sport V6 with tow package, 6 speed manual. When I did my last oil change. To get the oil right at the full mark on the diptick it took 5 qts of oil. I put on the standard oil filter though.
  9. Apr 20, 2008 at 10:04 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you gotta read in the parenthesis man......you are looking at liters. in parenthesis, it shows quarts and imp. quarts.
    1grfe......4 wheel drive and prerunner
    5.5quarts with filter for the 4.0...without filter 5.2
    fir the "mini's"(2 wheel drive,except prerunner)....1grfe....with filter 4.8 quarts, without filter 4.4 quarts.
    2trfe.....with filter 6.1 quarts, without filter 5.4 quarts.
  10. Apr 21, 2008 at 4:18 PM
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    I have the V6 with tow package (coolers and all). I just changed mine at 5K about a month ago. I put back in 5.5 quarts as I use the taller OEM filter. Couldn't tell nothing when the oil was first changed it was so clean but now I can see it is leveling out right at the top "hole" location. Dipstick does suck for sure. :)
  11. Apr 21, 2008 at 6:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    take a small piece of sandpaper to the dipstick, it will hold the oil a bit better.
