How many retaining wall blocks should I load?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hillbillynwv, May 27, 2010.
  1. May 27, 2010 at 9:56 AM
    hillbillynwv
    hillbillynwv [OP] Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    After work today I'm going to Lowe's and buying 65 retaining wall blocks. They weigh approximately 30 pounds each. If I take 1/2 of them home today that will be 960 pounds. I have never carried anything in the back over 600 pounds. What's everyones opinion here. These blocks are 4"x8"x12".
  2. May 27, 2010 at 10:00 AM
    hillbillynwv
    Fairmont, WV
    I have the TSB 4 leaf pack.
  3. May 27, 2010 at 10:01 AM
    2009Silver
    2009Silver Well-Known Member
    Wisconsin
    2009 Silver 4x4 DC TRD Sport
    WeatherTechs Bed Extender Bed Mat 3" Lift Spidertrax Clarion DVD HU Overhead Monitor
    Payload capacity is ~ 1280LB's
    So I would imagine you plus the 960lb's would still be under. I see you have the TSB - I'd say you'd be OK...
  4. May 27, 2010 at 10:03 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    Id do two trips 30 each about 1000lbs to be safe, if not too far, You may be pushing a bit with all 2000lbs.
  5. May 27, 2010 at 10:04 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Why not load out to GVWR? (check the data plate on driver's door pillar)
    Then you'll be able to drop by your Toyota dealer on the way home and have 'em order the TSB springs for you if you hadn't done it yet.
  6. May 27, 2010 at 10:10 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    Note that the 1280 LB's is TOTAL payload! including weight of driver, passengers and the accumulation of miscellaneous stuff that finds it's way into the cab, underseat and in the tool box!
  7. May 27, 2010 at 10:22 AM
    RogueLeader
    RogueLeader Well-Known Member
    Rod
    Las Vegas, NV
    2011 Tacoma Double Cab SR5 TRD
    If you want them all at once, find out how much it is to have them delivered and save the wear and tear. Shouldn't be that much.
  8. May 27, 2010 at 10:38 AM
    hillbillynwv
    Fairmont, WV
    I'm only 16 miles away from Lowe's.....so, doing it in two trips won't be that big of a deal. If the total payload is 1280 pounds.......32 Blocks @ 30# = 960# + Myself @ 197# = 1157 pounds. At the time I do not have any other extra weight from any other items in the truck.
  9. May 27, 2010 at 10:42 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    That is your safest bet right there...Throw a few more in the first load or whatever...but a little under weight gives you that safety buffer. And if you haven't driven with this much stuff before- It'll give you a feel for it.
  10. May 27, 2010 at 11:13 AM
    el_smurfo
    el_smurfo Well-Known Member
    I did about 1000 lbs of topsoil with my stock springs. It was a bit rough on the bumpstops, but didn't seem to handle too dangerously...I'd skip the freeways and take it slow on the back roads...
