How Many Smiles Per Gallon: 265/75r16?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DaddyMasterTech, Dec 12, 2022.
  1. Dec 12, 2022 at 8:42 AM
    DaddyMasterTech
    DaddyMasterTech [OP] Well-Known Member
    Union County, NJ
    ‘22 TRD Sport DCSB MT (MGM)
    Miles per gallon went down, but smiles per gallon went up!
    Not something I’m crying about, but I do think it’s pretty wild I went from 22-23mpg to 15-16mpg, based on the fact most people claim only 1-2mpg loss.
    I had stock Sport wheels, 265/65r17 Firestone. Now 16” Trail Edition wheels with 265/75r16 Wildpeaks (SL). I’m at 32psi. And I did not have an alignment done. It feels as though it drives perfectly fine, doesn’t feel like I’m pushing the gas pedal any harder than I was to go the same speed, but I can see the mpg indicator is MUCH lower than where it was with the old tires. Is it possible an alignment will improve anything significantly with the larger tires / different offset?
    Tocamo, Moose4x4 and hafjell like this.
  2. Dec 12, 2022 at 8:53 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    An alignment can't hurt, but that much difference is odd.
    At 25k, I went from stock Toyos to 265/70R17 SL WPs and saw a very small hit to the MPGs, mainly on the highway. I also got a Softopper at about the same time. Swapped to Nokian Outpost SLs 55k later. No real change in MPGs. Then added -10mm offset wheels of the same weight (about 24lb). No real change there. Still average about 20mpg overall.
    The extra 1/2in of clearance was actually noticeable and appreciated. The increased track width made a noticeable difference in handling also.
  3. Dec 12, 2022 at 9:01 AM
    Kilo Charlie
    Kilo Charlie Disruptor
    Iowa
    2017 Inferno Off Road
  4. Dec 12, 2022 at 9:03 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    thats a jump, i have a lift, prinsu rack, and the same tires and replica wheels and im getting high 15 to 20 on the interstate
  5. Dec 12, 2022 at 9:09 AM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Is this per mpg indicator, or calculated?
    hafjell likes this.
  6. Dec 12, 2022 at 9:32 AM
    DaddyMasterTech
    Union County, NJ
    Take your FS and :jerkoff:
    Notice I said the car drives fine, thus concluding my alignment was accurate …and I’m well aware of the increased tire size. I found it odd SOLELY in comparison to the reports from others with the same tires. Jeez hardo over here
    Clearstrm and Tocamo like this.
  7. Dec 12, 2022 at 9:33 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    If the computer's MPG info was in the ballpark to start with, the change would max out at about 5% or +1mpg at 20 average.
  8. Dec 12, 2022 at 9:34 AM
    JackJoachim
    JackJoachim Well-Known Member
    Jack
    North MS/Memphis
    ‘22 Barca Red TRD Off Road 6MT
    I did 16x8 ET0 wheels with 265/75/16 Wildpeaks and I get 17-18mpg combined.
  9. Dec 12, 2022 at 9:57 AM
    JWally
    JWally Active Member
    Ohio
    2020 DCSB TRD OR
    I took a good hit when I first upgraded to 33’s, but seems like once the transmission spent some time relearning, it recovered a lot. Also don’t forget that with the larger tire circumference, you travel farther with each rotation than before, so you need to multiply by the percentage increase to compare apples to apples.
    cryptolime likes this.
  10. Dec 12, 2022 at 10:01 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    17 to 18 mpg with 265/75/16 duratrac on stock off-road long bed 2017 taco normal driving. Can get 19 mpg if I want to but where’s the fun in that. 20mpg on long drive below 70 mph . Mpg indicated not calculated
  11. Dec 12, 2022 at 10:12 AM
    DaddyMasterTech
    Union County, NJ
    For the first 9k miles on the truck I wrote down mileage at each fill up, and divided how many miles since last fill up / how many gallons to fill up again. ODO was pretty spot on in comparison to the mile markers on the highway. And the mpg indicator was always pretty spot on with my calculations.
    So now, thanks to @Kilo Charlie , with the fancy online calculator, I know the circumference of the new tires is 3.41 inches larger. Which means my tires are spinning about 32 fewer times per mile than the ODO/computer thinks (Original 265/65)
    Again, just bizarre the hit I took was 6-8mpg rather than 1-2 people were claiming - which is why I posted this in the first place.
  12. Dec 12, 2022 at 10:14 AM
    BraskaTaco
    BraskaTaco Well-Known Member
    Midwest
    2013 Tacoma TRD OR
    Maybe the quality of gas you put into the truck changed?
    MR E30 likes this.
  13. Dec 12, 2022 at 10:44 AM
    kiki111
    kiki111 MENTALLY DISTURBED MEMBER
    Tacoma 2.7L SR
    I have a 2022 2.7L ACLB that came with dunlop H/T tires 245/75R16 and switched to cooper A/T 265/75R16 At 300 miles on ODO And went from 19 mpg to 16 mpg.
  14. Dec 12, 2022 at 12:22 PM
    2wdSR52022
    2wdSR52022 Well-Known Member
    Jc
    Expensive SR5
    That’s too much of a diff for it to be solely on tires. I moved to that size too and the mpg change was minimal.
  15. Dec 12, 2022 at 12:25 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    That mpg sucks, I do better with my 2013 on 285s C load 51lbs. Your prob driving 75mph often or something like that.
    Junkhead likes this.
  16. Dec 12, 2022 at 3:10 PM
    DaddyMasterTech
    Union County, NJ
    Not at all, in my ST yes, but in this my wife yells at me for going 60 in the right lane in a 65, not passing the slow cars.
    DavesTaco68[QUOTED] likes this.
  17. Dec 12, 2022 at 3:15 PM
    DaddyMasterTech
    Union County, NJ
    BP, same station I always use. And the MPG was fine on the way to the tire shop, immediately changed on the way home.
    BraskaTaco[QUOTED] likes this.
  18. Dec 12, 2022 at 3:18 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Does it really matter, assuming the same method is used for both MPGs?
  19. Dec 12, 2022 at 3:23 PM
    eurowner
    eurowner Duke Sky
    Scoty
    What Firestone tire? There are a lot of versions out there in that size.
    Falken says your tire is 43.9 lbs
  20. Dec 12, 2022 at 3:28 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    i get great MPG on the stock firestone destinations.
