how many times can hubs be pressed?
Discussion in 'Technical Chat' started by dirty TaTer, May 9, 2011.
  1. May 9, 2011 at 9:06 AM
    dirty TaTer
    dirty TaTer [OP] Ruts are the enemy
    Kevin
    Pasco Florida
    96 2.7 3rz taco
    Doorman OEM rear leaf packs, dynomax thrush glasspack, and cool milk crates in the back B)
    is there a limit to how many times they can be pressed? i know once you press them that the bearings are junk, but do the hubs or knuckles get messed up in the process of pressing them out to be put in to a different truck?
  2. May 9, 2011 at 9:19 AM
    dirty TaTer
    Kevin
    Pasco Florida
    96 2.7 3rz taco
    lol i know someone who owns a shop with a press that'll let me use it. is it something i can do myself?
  3. May 9, 2011 at 11:36 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    With the proper sleeve, which only contacts the outer race of the bearing, you can press bearings indefinetly. When the bearing no longer needs to be pressed in(since the hub is worn), it's usually time to retire the truck.
