How many wheel spacers?
Discussion in 'Wheels & Tires' started by tomwilson74, Aug 1, 2012.
  1. Aug 1, 2012 at 12:01 PM
    tomwilson74
    tomwilson74 [OP] Well-Known Member
    Tom
    West Virginia
    2012 TRD double cab
    ARE topper LED light bar Spidertrax
    Crazy question I guess, I think I may have to run wheel spacers if I buy Mickey Thompson Classic II for my '12 Tacoma. Do I run the spacers only on the front? And how thick should they be, would 3/4" work? I have 16 inch wheels (factory) and am wanting to get a set of aftermarket black wheels. I like the Pacer 164B and the Mickey Thompson Classic II.
  2. Aug 1, 2012 at 12:03 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    The issues are with the calipers, so you would only need fronts. However, the fitment of mickeys is really hit or miss. Some folks on here don't need spacers, some do, and some don't even fit with spacers.
  3. Aug 1, 2012 at 12:12 PM
    tomwilson74
    Tom
    West Virginia
    2012 TRD double cab
    I have already test fit one and it would need at least a 3/4" spacer. I am worrying about rubbing though. Don't really want to do a lot of cutting.
  4. Aug 1, 2012 at 12:26 PM
    KPT
    09 Prerunner
    What's the width and backspacing of the wheels? Pushing them out another 3/4" will probably make rubbing worse.
  5. Aug 1, 2012 at 12:26 PM
    tomwilson74
    Tom
    West Virginia
    2012 TRD double cab
    16 x 8 with 3 5/8 backspacing.
  6. Aug 1, 2012 at 12:31 PM
    tomwilson74
    Tom
    West Virginia
    2012 TRD double cab
    I am getting an OME 3" lift kit installed on Friday, don't know if that changes the rubbing issue or not.
  7. Aug 1, 2012 at 12:55 PM
    KPT
    09 Prerunner
    3 5/8" backspacing is far too little for a 2nd gen. Those wheels are designed for 1st gens.
    You should be in the range of 4.75"-4.25" backspacing range. You are going to have some serious rubbing with those even before the spacers. Adding spacers will push them out to 2 7/8" backspacing. You won't even be able to turn without getting fiberglass fenders, unless you are running really tiny tires.
    Do not buy those wheels!
  8. Aug 1, 2012 at 3:34 PM
    tomwilson74
    Tom
    West Virginia
    2012 TRD double cab
    I have saw the MT Classic II on several trucks on this forum, what are they doing to make them fit? What are my options in a black wheel similar to the MT Classic II without trimming then?
  9. Aug 1, 2012 at 6:19 PM
    KPT
    09 Prerunner
    Like I said earlier they are hit and miss on the fitting. But you at least need to get wheels with the right specs (~4.5") to even have a chance of them fitting. No brand of wheel with work on a 2nd gen with the specs you posted above.
    My suggestion would be to find folks who are running them and PM them to ask them how they got them to fit.
  10. Aug 1, 2012 at 6:26 PM
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
    I was about to say I am running them but just realized your weren't talking about Mickey Thompson Classic Lock II....
    The ones I have are pretty close to what you are looking for and I had no issues with them before or after my spindle install.....
  11. Aug 1, 2012 at 6:28 PM
    KPT
    09 Prerunner
    And what were the specs on them? Offset, width, backspacing, tire size.
  12. Aug 1, 2012 at 6:31 PM
    sfcadams
    Dan
    Elizabeth, Indiana
    KPT,
    I thought he was talking about the wheels I have. I edited my post above...
  13. Aug 1, 2012 at 6:34 PM
    KPT
    09 Prerunner
    No problem, I just wanted him to see that you can't run 3 5/8 backspaced wheels on a 2nd gen with stock fenders.
  14. Aug 1, 2012 at 6:54 PM
    tomwilson74
    Tom
    West Virginia
    2012 TRD double cab
    I had looked at the MT Classic Lock also, they were a bit more expensive. If they work, then I would probably get them. What are the offset and backspacing on them?
  15. Aug 1, 2012 at 7:24 PM
    KPT
    09 Prerunner
    They come in multiple different sets of specs, as do the classic IIs.
  16. Aug 1, 2012 at 7:29 PM
    sfcadams
    Dan
    Elizabeth, Indiana
    Mine are 4" backspace with a -12mm offset (16x8)
  17. Aug 1, 2012 at 8:03 PM
    tomwilson74
    Tom
    West Virginia
    2012 TRD double cab
    What size tires are you running? Did you have to trim anything? And, are you running spacers? Thanks!
  18. Aug 1, 2012 at 9:04 PM
    sfcadams
    Dan
    Elizabeth, Indiana
    I am running 285/75/16s. I originally had 5100s with Eibachs and a top plate spacer for a true 3" of lift. No trimming. Never had to run a spacer. I am now running Maxtrac spindles and my stock shocks/coils, with no spacer. The lift spindles inherently push the front wheels out a little so I did VERY LITTLE trimming insides the wheel well and you would never know if I didn't point it out to you. My best recommendation to you as far as lifts go is the Maxtrac spindles if you have a prerunner....
