How many??
Discussion in 'Lighting' started by Blackdawg, May 29, 2011.
  1. May 29, 2011 at 10:07 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Hey all i just put two Hella 500 lights with 55w DDM HIDs in them and love them :D
    My question is how much power do they draw? i am curious because i just put two on a 12v 40amp relay and am wonder if i can put two more on the same relay...or should i get another one?? because i have two more hellas wanting on my truck ... :)
  2. May 29, 2011 at 10:12 PM
    GEARAHOLIC
    GEARAHOLIC Well-Known Member
    KELLEN
    PASO ROBLES, CA
    07 Black on Black BEAST
    watts divided by voltage = amp draw....means with two lights ur sucking about 9 amps through the relay assuming you dont have corroded wires or other ressistance causing issues
  3. May 29, 2011 at 10:45 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thanks man! looks like ill be hookin up two more lights tomorrow :p
  4. May 30, 2011 at 1:54 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Boston, MA
    2019 TRD Sport, White Double Cab "Yeti"
    Current: DR750S-2CH Dash Cam, USB Fast Charger in stock blank, Hondo Garage phone mount Previous: 2006 Black 2.7L 5-spd SR5 4x4 Access Cab - K&N Cold Air Intake, Modified Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars, DIY Bed Lights, DIY Ground Lights, DIY Tailgate Electrical Box, Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    x2...you should be ok...worst case scenario 2 lights will pull about 10A max, therefore 4 will pull about 20 max. Just be sure to keep the wiring and fuses separate, or ensure you get the proper guage to handle all 4. Check out my electrical basics thread (link in sig).
  5. Jul 23, 2011 at 12:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea i tried wiring them up yesterday...went bad. The drew to much through the wire i have threw the switch in the cable. was smoking just a bit lol was scary. so now i think ill just put in a second switch and stuff. be nice to have control of the 4300k and the 6000k, narrow/wide lights separately.
