How much air in the tires????
Discussion in 'Wheels & Tires' started by Ricky B, Jul 1, 2008.
  1. Jul 1, 2008 at 8:10 AM
    Ricky B
    Ricky B [OP] Well-Known Member
    Arkansas
    1998 XCAB
    I know to look on drivers door for air pressure. The drivers door show 235/70/r15 32 psi. I run 265/70/r16 and all it shows on the tire is max 80psi cold. A'm I missing something? Rick
  2. Jul 1, 2008 at 8:14 AM
    bigguy78619
    bigguy78619 Well-Known Member
    san diego, ca
    07 TRD Off-Road PreRunner DC
    check your tires, some manufacturers have the recommended psi on the tire itself
  3. Jul 1, 2008 at 8:29 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Never ever air your tires up to the MAX pressure that's on the sidewall of your tires, you're just asking for trouble. 34 PSI should suffice.
  4. Jul 1, 2008 at 5:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Put a chaulk line on your tire and drive around. You want to adjust your air psi until you can see about 1/8" of chaulk at the edge of your tread. :)
  5. Feb 11, 2009 at 8:41 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    thats a motorcycle thing because when were riding we lean and use the side of the tire. I'm not so sure thats correct with truck tires...
  6. Feb 11, 2009 at 8:45 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    on 1rst gens its 29 I believe
  7. Feb 11, 2009 at 8:50 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    i keep mine on 20 psi
    but thats cuz i like my itres to roar going down the road
  8. Feb 11, 2009 at 9:19 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    20... you must not even get 1 mpg. i'm sure it's tire and load dependant, i just aired up to 40 up front and 38 in the back. 265 75 16 bfg a/t's
    we'll see how that works, the ride is still nice.
  9. Feb 12, 2009 at 4:15 AM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    no it still gets pretty decent gas milage
    considered on how i drive it:D im 16:thumbsup:
  10. Feb 12, 2009 at 4:27 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    The chalk methond is the best as every vehicle is different this will ensure the life of the tires. You will have more psi in fron than in the rear, as the psi is determined by how mush weight the tire needs to support.
  11. Feb 12, 2009 at 11:02 AM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    well, i'll stick with using the chalk method on my bike. what do you guys run thought?!?!
