how much air pressure for air bag suspension?
Discussion in 'Suspension' started by cd2cd2, Sep 25, 2011.
  1. Sep 25, 2011 at 3:49 PM
    cd2cd2
    cd2cd2 [OP] Member
    C.D.
    va
    2005 tacoma 4x4 v6
    I just purchased a 05 tacoma v6 with air bag suspension. It has an valve stem behind rear lic. plate. How much air pressure should I keep [max]-[min]?
  2. Sep 25, 2011 at 3:53 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Morty
    Outer Space
    I would think you only put air in them if you have a heavy load.
  3. Sep 25, 2011 at 3:59 PM
    trd sport
    trd sport Well-Known Member
    queens,ny
    07 double cab trd sport
    Must have minimum of 5 lbs. of air press. if you have firestone air bags.
  4. Sep 25, 2011 at 3:59 PM
    cd2cd2
    cd2cd2 [OP] Member
    C.D.
    va
    2005 tacoma 4x4 v6
    much?
  5. Sep 25, 2011 at 4:03 PM
    cd2cd2
    cd2cd2 [OP] Member
    C.D.
    va
    2005 tacoma 4x4 v6
    whats max i can have?
  6. Sep 29, 2011 at 11:01 PM
    kendj
    kendj New Member
    Ken
    Calgary
    05 PreRunner
    I installed Firestone Ride Rite air bags on rear suspension and it is the best suspension upgrade one can do. Works fantastic and can now actually haul a load without having the truck bottoming out. Bags need minimum of 5 psi, max is 100 psi but you will never need more than 30 psi for a heavy load.
