How much brake fluid is required for flushing/replacing lines?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jross20, Mar 2, 2019.
  1. Mar 2, 2019 at 5:45 AM
    jross20
    jross20 [OP] Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    So I've got my front and rear extended lines from Marie at headstrong.
    The next thing I wanted to do was get enough brake fluid because when I swap the lines I want to do a flush as well. Anyone know how much I'll need?
    And I believe I need to use Dot 3? Is that correct? Is there any kind of TW preferred brand?
  2. Mar 2, 2019 at 5:57 AM
    jross20
    Georgia
    Okay so I think I'll go ahead and get like five containers, that way I have some in the garage in case I need it.
    I haven't looked at brake fluid in a while, so I did some research and I see that now they have 5.1 fluid.
    Assuming there is not a massive price difference, would there be any reason to not just say screw it and go straight to do 5.1?
  3. Mar 2, 2019 at 6:14 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  4. Mar 2, 2019 at 6:25 AM
    BillsSR5
    bill
    2014 SR5
    yea I put that in favorites, looks like LUCAS DOT3 in a very good over the counter DOT3, basically the best wet boiling point is best
  5. Mar 2, 2019 at 6:38 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Just make sure you only break the seal on one bottle at a time. Brake fluid has a short shelf life when its not sealed. I used 2 small jugs from Advance when I flushed my 1st gen. IMO, really no need to upgrade anthing or buy a specific brand.
    jross20[QUOTED][OP] likes this.
  6. Mar 2, 2019 at 6:39 AM
    jross20
    Georgia
    DOT 5 is silicone based and was made for/by the military as it does not draw in water and has an absurdly high boiling point. At least that is what I've read.
    It looks like 5.1 is close in price and is the "best". So I think I'll roll with that after reading more of that link above
