How much can you lift with stock shocks?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UofA Taco, Jun 12, 2010.
  1. Jun 12, 2010 at 10:04 PM
    UofA Taco
    UofA Taco [OP] Well-Known Member
    Blake
    Auburn, Alabama
    2010 Double Cab 4x4
    K&N filter 3" Toytec lift
    I currently have the 3" spacer kit from toytec with the aal, tsb, and LR ucas. My question is how much lift can you go with stock shocks? Truck has a little rake to it and was thinking of getting the Eibach coils or 884s from toytec but didnt know if i would have to change shocks out also..or anything else in that case. One more thing.. how much can you lift the rear with stock shocks? I have a 1" block sitting around in the garage and thought about putting it on as well... ooooooorrrrr I'd sell it if anyone is interested :D 1" block from ToyTec with new U-bolts.
    Thanks, Blake
  2. Jun 12, 2010 at 10:16 PM
    UofA Taco
    Blake
    Auburn, Alabama
    2010 Double Cab 4x4
    Oh yea...and I also have a Diff drop.
  3. Jun 12, 2010 at 10:50 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    I think your problem will be downtravel from the shock. With the spacer on, your shocks can only go down like 1" right now, add anymore and your shocks will be maxed out and a make for a VERY crappy harsh ride.
  4. Jun 13, 2010 at 9:45 AM
    Bamahoyt
    Bamahoyt Well-Known Member
    Ted
    NorCal
    2001 TRD 4x4 Xtra Cab
    Tires- 31x15x10.5 Cooper Discovery AT3
    Could you run stock shocks on 884's alone with no spacer and be fine?
  5. Jun 13, 2010 at 10:04 AM
    toku58
    toku58 Well-Known Member
    HAWAII
    4x4 Beast!
    6" Fabtech Stage II, 17x9" Centerline Eclipse rims, with 12.5x35x17" BFG KM2's. On board air system,Toyota skid plate, spidertrax wheel spacers, TRD CAI w/AFE ProDry filter (21-90045),Flowmaster Dual exhaust, GrillCraft grill w/custom emblem, Custom Shifter, BushWacker fender flares, Hood struts, Underhood lights, TW driveshaft, Wet Okole seat covers, Dashlight mod, Many other little things to make the truck complete!
    No matter what! Even if you can get longer shocks, or get creative and stack lifts??
    Don't go any higher than 3" on a stock suspension!! (Stock LCA's, and spindles)
    You'll only be asking for a lot of trouble, and expense!
    If you want more lift buy a Fabtech, Procomp, or an LT set up!
    Don't do the "Getto Fabulous" route! You'll be sorry in the long run!
