How much cargo (weight) can my Tacoma carry?
Discussion in '1st Gen. Tacomas (1995-2004)' started by seanmichaels, May 20, 2010.
  1. May 20, 2010 at 7:26 AM
    seanmichaels
    seanmichaels [OP] Member
    Florida
    03 Tacoma TRD V6
    How much cargo (weight) can my Tacoma handle? My 03 Tacoma TRD has a V 6 I believe and I am trying to figure out how much weight it can carry in the bed. The manual is quite vague and covers so many different versions of the Tacoma. Ie. Pre-runner, single, double cab, etc….I know mine is the pre-runner but then they ask for engine specs which I know nothing about. I wish they had a manual for each specific Tacoma so when you bought it you would only have information relating to your Tacoma and not about four or five other models.
    Thanks.
  2. May 20, 2010 at 7:30 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    may be stated on the decal in the driver door jam.. I would look there first.
  3. May 20, 2010 at 7:33 AM
    Kevlar1267
    Kevlar1267 Well-Known Member
    Kevin
    Minneapolis
    2002 Tacoma SR5 4x4 2.7
    Magnaflow exhaust,K & N filter,Bilstein Shocks
    I think about 1,500 pounds. I know mine with the 2.7 and automatic says like 1,700 something. Alot i'm guessing is to have to do with what motor and transmission you have. I have a brochure at home from when I bought my 2002 I could look. Kevin
    Bobbytoy1 likes this.
  4. May 20, 2010 at 7:36 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    :confused:
    Yota4Life89 and GreenheadKiller like this.
  5. May 20, 2010 at 7:37 AM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
  6. May 20, 2010 at 9:03 AM
    gobias
    gobias as in Gobias some coffee
    02 Dbl TRD
    Don't quote me on this but I believe you take your GVWR and subtract the curb weight of the vehicle. Then add passenger weight and whatever leftover is how much you can safely carry.
  7. May 20, 2010 at 9:05 AM
    gobias
    02 Dbl TRD
    3500 is how much you can tow using bumper pull.
    5000 is with a hitch.
  8. May 20, 2010 at 9:06 AM
    AlexanderD
    AlexanderD Well-Known Member
    Alex
    whitby Ontario
    03' tacoma 4x4 trd step-side
    thats towing capacity not cargo capacity.
    its about 1500 pounds. it does say in your owner's manual. just gotta figure out which combination of engine and body you have.
  9. May 20, 2010 at 3:03 PM
    Kevlar1267
    Kevin
    Minneapolis
    Brochure say 1,745 for prerunner extracab with V6 and auto. Extracab prerunner with 2.7 I-4 and auto is 1,830 pounds . 4x4 extracab with 2.7 is 1,630 pounds manual and auto is 1,600 pounds. 4x4 extracab with V6 manual is 1,585 and auto is 1,560 pounds
    This is coming from the info in a brochure from 2002 Toyota Tacoma should be the same for 2003 .
    weight includes passengers,equipment and cargo..
    Truckstop13 likes this.
