How much caster can I get on stock UCAs with a 2 inch lift?
Discussion in 'Suspension' started by junkyarddogg, Feb 20, 2023.
  1. Feb 23, 2023 at 11:41 AM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    If I measure it, it might have a bit of difference, but not noticeable to the naked eye.
    my previous 2017 Taco had a Toytec lift, and I had to adjust one side a bit more to get it in line.
    From what I can tell with my TRD lift is that it is pretty even, as I think Toyota at the factory set the springs up for that purpose. The stock springs are set up to handle the difference.
    on my 2007 I had new shocks and lift springs, and had to add a small plate to account for the Taco lean.
  2. Feb 23, 2023 at 5:10 PM
    junkyarddogg
    junkyarddogg [OP] Well-Known Member
    New Jersey
    2021 TRD Off Road
    that’s weird, I have the same lift but with .5 inch lean in the front and .75 inches in the rear. I ordered a top spacer and rear shim to correct this.
  3. Feb 23, 2023 at 5:11 PM
    junkyarddogg
    New Jersey
    2021 TRD Off Road
  4. Feb 23, 2023 at 6:56 PM
    Gutentight
    Gutentight Well-Known Member
    IL
    2021 Cement Off-Road 4x4 DCSB 3.5L AT
    Quick search I see only one side on rockauto, maybe a supply thing right now. If you can wait or find them somewhere they are SPC at a lot lower cost per my later posts on that thread.
  5. Mar 8, 2023 at 11:44 AM
    junkyarddogg
    New Jersey
    2021 TRD Off Road
    I just called a shop and they are out of SPC's but they have dobinsons and ironman. Does anyone know if these uca's with built in caster will cause more tire rub?
