How much cutting??
Discussion in 'Wheels & Tires' started by mrsarcastic79, Mar 12, 2010.
  1. Mar 12, 2010 at 10:48 AM
    mrsarcastic79
    mrsarcastic79 [OP] Well-Known Member
    Jayson
    Fairfield, CA
    TRD Offroad 4X4 SW
    OME 885 Coils, OME shocks and struts w/TSB rear leafs, AVIC x930bt
    Hi guys I have been searching and have found no for sure answer so here it goes. I have a 2009 Double Cab with the OME 885 Coils and struts with NO top spacer and the rear TSB also stock UCA's which yields about 2.5" of lift in the front. I just purchased the Pro Comp 7089 in a 17x8 and am wondering if I should go with 285/70/17 or 265/70/17. The tire in question is the Firestone Destination A/T. Will I need to cut a lot to prevent rubbing and if so will it only be the front inner liner or will I need to do a lot of trimming and should just go with the 265/70/17?
    TIA guys for all of your help
  2. Mar 12, 2010 at 11:22 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What backspacing are you getting?
  3. Mar 12, 2010 at 11:53 AM
    mrsarcastic79
    Jayson
    Fairfield, CA
    TRD Offroad 4X4 SW
    4.5" backspacing
