How much did you pay for your 30,000 mile service?
Discussion in 'Performance and Tuning' started by fivejmpchmp, Nov 14, 2008.
  1. Nov 14, 2008 at 7:41 PM
    fivejmpchmp
    fivejmpchmp [OP] Well-Known Member
    Dan
    Garden Ridge, TX
    '17 Tacoma DC TRD OR
    Stock!
    I just hit 30,000 miles and when I went to schedule the service online, I found out it was going to cost around $450. So, I wanted to check with everyone to see if that's about right. The service lists a whole bunch of inspections to go along with the oil change. Are they all neccessary? I'm holding off to see what the norm is, thanks for your help.
  2. Nov 14, 2008 at 7:44 PM
    fivejmpchmp
    Dan
    Garden Ridge, TX
    Stock!
    Here's what I was talking about...
    30,000 Mile Service [Tacoma 2004 and newer] (also at 60K, 90K)
    Replace engine oil and oil filter
    Replace engine air filter
    Replace spark plugs (std. type)
    Rotate and balance tires, inspect condition and
    Fuel induction service
    Transmission service (drain & refill)
    Test battery and clean battery terminals
    Lube lock, latches and hinges
    Top off under-hood fluid levels
    Inspect the following:
    - Automatic transmission fluid
    - Ball joints and dust covers
    - Brake lines and hoses
    - Brake linings/drums and brake pads/discs
    - Drive shaft boots
    - Engine coolant
    - Exhaust pipes and mountings
    - Front differential oil (all 4WD models)
    - Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
    - Fuel tank cap gasket
    - Manual transmission oil
    - Radiator core and condenser
    - Rear differential oil (All 4WD models)
    - Steering gear box
    - Steering linkage and boots
    - Transfer case oil (all 4WD models)
    The cost was $440.34.
  3. Nov 14, 2008 at 8:12 PM
    05 X-Runner
    05 X-Runner Murdered X
    Brett
    Napa, Nor-Cal. Whine Country U.S.A
    BSP 05 X-Runner, 07 TRD Sport Super White
    HVM C/F X-Runner badge 1 of 6 made,P/C'ed black rims,Blacked out Billet Grill,BLHM,HID's,Tinted tail covers, Fog light mod,BFLM,C2C Black eyelids,,C2C 1.75" Front drop 2" rear,C2C Hoodstruts,URD Shortshifter,URD T-CAI.Custom Coupe shiftball, NST Manifold Spacer.. 07 TRD Sport Super White,De-badged,White headlight Mod,Fog light mod,White tail light mod,C2C white eyelids, C2C hood struts
    Mine was about $300, I had it done at a shop here in town. They got all the fluids and parts from the stealership
  4. Nov 14, 2008 at 8:26 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    My total was a little less than $300. But with the help of TW I am able to do most of the maintenance myself. Helps save a buck.
  5. Oct 25, 2010 at 7:44 AM
    dgalleon
    dgalleon Well-Known Member
    Central Florida
    09 TRD Sport 4x4 Dbl Cab LB
    TRD CAI, Flowmaster 40 series, 6" Fabtech Lift, Dirt Logic rear shocks
    is the fuel induction service at 30,000 miles worth it?
  6. Oct 25, 2010 at 7:50 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I got quoted $350 for mine. I didn't get too far into asking what was included. I ended up only getting an oil change from the dealership. I changed the front end, rear end and transfer case fluid on my own and rotate my own tires.
  7. Oct 25, 2010 at 7:58 AM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    I did the engine, rear diff, front diff, xfer case oils and rotated the tires along with cabin and engine air filter replacement myself. Only thing missing now is the spark plugs and automatic transmission fluid. Not sure if I really need to do those yet. xfer case oil looked pretty clean.
  8. Oct 25, 2010 at 8:01 AM
    pebbles
    pebbles Active Member
    2000 2WD Tacoma w/3" Lift
    Antioch ( California ) Toyota charged me $369.95 for 30,000 mile service ( replaced sparks plugs & oil change & replaced engine coolant & replaced air filter & etc ) last month.My 2000 Tacoma had 201,000 on it when I took it in.
    Never had my truck serviced at any independent shop ( at a cheaper price ) in the past 10 years,didn't want to risk the chance of some unethnical mechanic jerk purposely mess up my vehicle.
  9. Oct 25, 2010 at 8:24 AM
    senna
    senna Well-Known Member
    San Jose CA.
    09 DBL CAB TRD-OR OME shocks 885 and AAL
    Yea, cause the dealership sets the ethical bar so high :confused:.
  10. Oct 25, 2010 at 8:28 AM
    Pugga
    Massachusetts
    Hey, maybe he prefers the higher priced unethical treatment...:D
    The dealerships usually aren't smart enough to cover their tracks if they cut corners and their easier to argue with and get it fixed. At least that's been my experience but I always test them like mark the oil filter to make sure I have a new one when I get it back, chaulk or ink pen the drain plug to make sure it was actually removed, etc. Not that I don't trust them, it's just that I don't trust them...
  11. Oct 25, 2010 at 10:38 AM
    senna
    San Jose CA.
    I am with you on that. Make sure you get what you pay for.
  12. Oct 25, 2010 at 2:09 PM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    The only thing I did was change the engine oil. I'm at 43k and still havent done anything except oil changes. The price places charge is insane to me.
  13. Dec 1, 2010 at 3:34 PM
    rjreynolds
    rjreynolds Active Member
    2wd 2.7l
    I agree. Prices are insane, and you never know if they are going to do something bad to your ride, whether you know them or not ( I am referring to a shop). I have mechanic friend do most of my work. For example we just did the front brakes yesterday. It cost me $38 for ceramic pads. He did a great job. Cleaned and used proper gels for all parts. He even smoothed out the rotors with a air gun disc. The stealership here in S. Florida wanted $220.00 for front brake pad replacement.
  14. Dec 1, 2010 at 3:45 PM
    deadbolt
    deadbolt do w3rk!
    Socal
    08 Dbl Cab 6spd 4x4 TRD Off Road
    Black Headlights, HIDs, Tinted Fogs, Powdercoated Black Wheels, 5100s @ 2.5", Diff drop, AFE Exhaust, AFE Stage 2 Intake, Black Emblems/Grille, LED Tail lights, 265/75/16s Good Year Duratracs
    DIY for ~150 bucks
    (50) Changed Front/Rear Diff - Mobil 1 Fully Synth
    (30) Changed Oil w/ Filter - Mobil 1 Fully Synth
    (30) Changed Tranny/Transfer Case - Redline Fully Synth
    (25) Changed Spark Plugs - OEM Denso
    (10) Replaced Cabin Filter
    Cleaned Air Filter
    Wash taco
    your done!
  15. Dec 3, 2010 at 7:25 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Damn, I'm about to hit 30k. Ummm is the sparks plugs change really needed?
  16. Dec 3, 2010 at 7:33 PM
    Huskerjim
    Huskerjim You gotta love your brother inlaw!
    Jim
    Fleming Island, Florida
    4x4 TRD Sport
    Ballistic Wheels Nitto Tires Extang Cover Exhaust Duel Leather Interior OEM Bug Shield Bullet Grill and Ect. Bed Mat
    Let me tell you from experience they do half what the list says they do, I had one done that said the the cabin filter good, guess what it didnt even have one in it, second it said the air filter for the intake was good it was way dirty, 3rd the brakes was in specs the the frt was warped the rotors that is I complained they fixed it. tell me they really do it....:rolleyes: just a way to get money into the service department:cool: Oh by the way the transmission is totally sealed come on!!!! SCAM
  17. Dec 3, 2010 at 7:44 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    Damn!
  18. Dec 8, 2010 at 12:05 AM
    yotaman3130
    yotaman3130 Well-Known Member
    Ms
    08 TRD Offroad
    Kobalt low profile tool box, Toyota Roof Rack, K&N drop in air filter, Blue sea fuse panel, Streamlight mounted in glove box, NFAB step bars, FJ offrad rims
    im with deadbolt taco man, DIY!
    ive done oil and filter, sparks, cabin air and engine air and ive spent about 100$, used mobile 1 syn. bout to do diff's thursday and ill be done and for a fraction of the cost and peace of mind in knowing i did the stuff the right way all the way
    :woot:
