How much did your AAL settle?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by flightcancled, Apr 17, 2010.
  1. Apr 17, 2010 at 9:12 PM
    flightcancled
    flightcancled [OP] Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    Just dropped in my AAL. Well to be honest it is a modified bottom leaf from a TRD OR leaf pack. I was hoping for maybe 1" of lift, trying to go for around stock height. The dam thing gave me 2.5" of lift.:eek:
    How much lift did you loose after installing your AAL?
  2. Apr 17, 2010 at 9:18 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    It'll probably settle to 2.25" of lift... maybe 2" if you're lucky... It will be back down to .25" of lift in about 20 years.
  3. Apr 18, 2010 at 6:17 AM
    PreRunner
    PreRunner Well-Known Member
    yeh just hang in there. patience is key.
  4. Apr 18, 2010 at 7:37 AM
    flightcancled
    Just trying to figure out my next move. Have everything I need to install 3" spacers and upgrade to TRD shocks. That would level the rig out after some sag (rear is at 39.25" front 35.25").
    After reading around I'm worried about crappy ride quality with the spacers. I will be trail riding all summer for work and play as well as riding around on rough cobblestone roads so the last thing I need is reduced travel. At the same time I'm not having any luck finding cheap front 5100s or OME lift springs. (PM me if you do though)
  5. Apr 18, 2010 at 9:13 AM
    w8n4mud
    w8n4mud There's a mod for that!
    Albert
    San Diego, CA
    2015 Subaru WRX
    Bilsteins 5100's (Front & Rear), GrillCraft, Line-X'ed Skid Plate & Bumper Valence, Blacked out hood scoop, Avid Light Bar and much more.
    Sorry to hear. If its any consolation, I had Toyota do the rear TSB a couple years back. It looked good for a while. Eventually, I noticed a sag in the rear. I just added an AAL in the rear no more than 2 months ago and love it. I think it has settled some already. I to made the upgrade to 5100's in all corners. The front is set at 2.5.
    I know this may seem a little odd to mention, but I was feeling that thump many tacomians were experiencing while waiting at a stop. Right before they were to pull forward, they would feel something in the rear as if being tapped by another driver. Low & behold, I haven't felt that thump since I added the AAL. Don't ask me why. I'm just glad its gone.
    Good Luck man. I wouldn't worry too much about the stance. I will settle.
  6. Apr 18, 2010 at 9:19 AM
    28Gauge
    28Gauge Well-Known Member
    Brian
    Grapevine, TX
    06 PreRunner SR5
    Sockmonkey Graphics, K&N Drop In Air Filter, 265/75/16 Bridgestone Dueler A/T's, Weathertech Digital Fit Floor Mats, Dee Zee Bed Mat, Map Light/Dome Light LED's, Flo-Pro Muffler w/Stainless Steel Tip, Dome Light/Map Light Mod, Mobil 1 Synthetic Motor Oil, LED Cupholder Mod, Grillcraft with TOYOTA emblem, Vision 375 Warrior Wheels, Extra Bed D Ring Mod, TRD Skidplate, Bilstein 5100's on all four corners, Front 5100's set at zero with Eibach springs, Toytec 1.5" rear TSB add-a-leaf springs, Toytec swaybar relocate kit, Katzkin Leather Seating, Front Window Tint
    That "thump" is axle wrap I believe. It was very common with the 1st generations.
  7. Apr 18, 2010 at 9:26 AM
    flightcancled
    Had to move it accross the street so I took a second to measure the height of the rear. As of right now the rear has settled by nearly an inch after 14 hours and maybe 15 miles. :thumbsup:
    Here it is as of now:
  8. Apr 18, 2010 at 10:23 AM
    PreRunner
    i wouldn't mess with it at all. looks good.
  9. Apr 18, 2010 at 10:58 AM
    nvdeserted
    Reno, NV
    yeah, looks close enough to me
  10. Apr 18, 2010 at 7:07 PM
    flightcancled
    I'm not feeling the rake. Still think I might do a small top plate lift or lift springs.
  11. Apr 18, 2010 at 7:13 PM
    flightcancled
    I have a set of 3" toyotatec spacers I could add, but I am worried about the reduced travel and ride quality.
  12. Apr 18, 2010 at 7:38 PM
    glandnut
    glandnut Grease Monkey
    Florida
    09' MGM TRD DC Sport LB(gone), 16' 4Runner Trail
    secret stuff.
    I would just give it a bit more time. I really think with the added weight of the topper, you will settle just right within a small time...
  13. Apr 19, 2010 at 9:00 AM
    flightcancled
    Hmm found some 5100s that I can actually afford. Guessing I'll set them at 1.75 If the rig does settle I will just lower the setting.
