How much do I need to drive?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sinister184, Nov 28, 2022.
  1. Nov 28, 2022 at 12:57 PM
    Sinister184
    Sinister184 [OP] Well-Known Member
    23 Tacoma TRD OR 4x4
    I don't currently drive very much, and I live in close proximity to most of the places need to go (less than 5 miles and also commonly bike). As such, the truck could sit for extended period of time if I don't make an effort to drive it. Case in point, I bought the truck in early September and it barely has 300 miles on it. I try to go out on country roads on 10-20 mile trips at least once a week, one just to get out, but two to run the truck out a bit.
    My question is, I know vehicles don't like to sit, so is what i'm doing enough? I plan on keeping the truck for a good while, so I want to keep it up properly. I always hit time intervals over miles, so I'm aware of that aspect of less frequent use.
    Kahpo and Slick Taco like this.
  2. Nov 28, 2022 at 12:59 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Drive it enough to get all the fluids to temp, stay on top of oil changes, minimum of once per year. As far as frequency, I go based on battery. My battery likes to stop cranking after about 2-3 weeks of sitting (1st gen).
  3. Nov 28, 2022 at 1:08 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    The manual says to exercise 4x4 10 miles per month. Also be mindful of rodents eating the soy wires.
    Slick Taco and Malvolio like this.
  4. Nov 28, 2022 at 1:52 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    10-20 miles per week should be good. Your battery might not last as long, but not terribly short, you could put on a battery tender if you’re wanting to get max life out of it.
  5. Nov 28, 2022 at 2:01 PM
    stftaco
    stftaco Well-Known Member
    22 MGM DCSB Tacoma TRD Sport
    pltommyo and Sinister184[OP] like this.
  6. Nov 28, 2022 at 2:25 PM
    Quien es?
    Quien es? Well-Known Member
    Central TX
    2020 DCSB SR 4x4
    Armrest cushion, Glovebox divider, Toolbox
    I’ve parked vehicles for anywhere from 8 to 15 months at a time, with only a monthly startup and allow to come to temperature. You’ll be fine if you are doing it as you’ve written. The biggest problem I have run into was when my tires developed flat spots that took miles of driving to get rounded back out…
    Sinister184[OP], Kahpo and Slick Taco like this.
  7. Nov 28, 2022 at 2:52 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    THERE ARE NO SOY WIRES! QUIT SPREADING MYTH! Wow.
  8. Nov 28, 2022 at 2:59 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I don't know what the insulation is made of, but rodents will chew the insulation off wires. BTDT 3 times. Twice on a Honda Fit, once on a Honda Rancher.
    Slick Taco likes this.
  9. Nov 28, 2022 at 3:09 PM
    Old goat1914
    Old goat1914 Well-Known Member
    Chicagoland, Indiana
    2016 TRD Sport DCLB 4x4
    I hit 20,000 miles on my 2016 a couple of weeks ago. I drive a minimum of 3 miles and less than 10 miles per trip. Sometimes in the winter I only drive it once in ten days and then it is around 6 or 7 miles. I replaced the battery in 2021 when it failed to start the truck.
  10. Nov 28, 2022 at 3:32 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Just passed 34,000 miles with my 2007... comes out to an average of 6.29 miles a day over the last 15 years. A lot of time the truck sits for a week at a time. I get the tow package battery replaced with a Les Schawb extreme power every 7 years... never had an issue.
    Sinister184[OP] and Slick Taco like this.
  11. Nov 28, 2022 at 3:33 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    You’re fine. Driven once a week for 10 miles works.
    Sinister184[OP] likes this.
  12. Nov 28, 2022 at 3:33 PM
    ttl85
    ttl85 Well-Known Member
    2020 TRD Off Road
    I drive short distances and warm it up first like remote start it. You want the engine warmed up to temp or issues can happen, they need to evaporate the moisture whether it be inside the engine, exhaust ect.
  13. Nov 28, 2022 at 3:35 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Just let someone else drive it
    JustJon likes this.
  14. Nov 28, 2022 at 3:44 PM
    Crusher69
    Crusher69 Well-Known Member
    Sean
    Denver
    '05 Built
    Remote start it from the window now and then.
    Take some Sunday drives.
    Maybe let a bum or two overnight in it when it gets really cold, but no soup kitchens. Charity is good. But there is a line.
    Check under the hood and the undercarriage for signs of mice nests.
  15. Nov 28, 2022 at 3:44 PM
    Forestryguy
    Forestryguy Well-Known Member
    2022 SR5 Access Cab 4x4
    Peanut Butter
  16. Nov 28, 2022 at 4:38 PM
    Quien es?
    Central TX
    2020 DCSB SR 4x4
    Dirty Mike disagrees- there are no limits.
    TexasWhiteIce likes this.
  17. Nov 28, 2022 at 5:10 PM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Geeze,
    Where do you live?
    I'm in Suburban/Rural Delaware and live 4.7 miles (one-way) from work--There is no way I'm riding a push-bike at 5am on Highway 13! lol
    My daily driving M-F is roughly 10 miles per day/50 miles per week. I have just over 15K miles on my Sport since May 2021.
    But back to you and the dilemma about your truck...
    What was your intended purpose for buying the Tacoma? (I don't mean to pry but trying to understand why this situation now exists)
    You intend on keeping the truck for a while and are aware of the intervals over miles so why aren't you driving it even for less that 5 miles?
    Lately, after work I've been taking long routes home to keep up with mileage/usage.
    Maybe you can do the same? I don't know if you're still working or retired so please don't take my line of questions in the wrong tone.
    Toycoma2021 likes this.
  18. Nov 28, 2022 at 5:25 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    That should be enough, unless you park in direct outside sun, or outside in the cold winter. Worse case scenario, you need a new Battery, but the truck will be fine.
    JustJon likes this.
  19. Nov 28, 2022 at 5:25 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    They chew metal too. Your point?
  20. Nov 28, 2022 at 6:45 PM
    vnix
    vnix Well-Known Member
    2021 white Tacoma DCSB XP Predator
    blind spot mirrors, center tray, bedrug, more to come
    That's probably good enough to be honest though I usually take mine for a good hour long drive at 60+ once a month and and also put it into 4 hi once a month for about 10 miles down a dirt road but not the same weekend. That's usually enough to keep it happy. I've done it for years ever since I noticed my Z was rocking the daily drives at 75+ every day to work. Guy who bought is a master mechanic for Nissan. He tells me it's still throwing down like it was a new car after a proper break in.
