How much do I need to drive?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sinister184, Nov 28, 2022.
  1. Nov 29, 2022 at 5:02 AM
    #41
    Sinister184
    Sinister184 [OP] Well-Known Member
    23 Tacoma TRD OR 4x4
    Thanks everyone for the feedback. I'll keep doing what I'm doing.
  2. Nov 29, 2022 at 5:10 AM
    #42
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Sub'd just for the outcome of that :D
    Heard lots of arguments, but never seen any 'proof'.
    davidstacoma[QUOTED] likes this.
  3. Nov 29, 2022 at 5:22 AM
    #43
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    The worst thing you can do is just start it without doing at least a full warm up drive cycle. Better to let it sit than to just start it and not drive it.
    BkerChuck likes this.
  4. Nov 29, 2022 at 6:13 AM
    #44
    stftaco
    stftaco Well-Known Member
    22 MGM DCSB Tacoma TRD Sport
    Wow. That's a very (very) long time. Web resources suggest anywhere from 2weeks to 4weeks for a battery to dip to a very depleted level where the processes of sulfation will result in permanent damage. That's damage that cannot be undone with charging from an AC charger placed on the battery, or via the alternator through driving. Don't forget the stress that is placed on an alternator in that scenario.
    Discharge times will depend on the source(s) and extent of parasitic drain on the battery which should be considered to vary from vehicle to vehicle. The 2-4week rule-of-thumb recommendation may or may not be conservative. YMMV
    After jump-starting one of my vehicles, I've always driven at highway speeds for an hour... Some might suggest 30minutes is sufficient, but I'd personally take that as an absolute minimum not knowing how much longer it is going to sit without being driven again.
    FWIW: I also have one of those Li-Ion jump packs available. Well worth the cost, and really convenient not to have to have another vehicle and jumper cables! Saved me and my family a number of times. Also handy if you can't get the car started and your phone has no charge left. :eek:
    Quien es?[QUOTED] and 22Coma6MT like this.
  5. Nov 29, 2022 at 6:18 AM
    #45
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I probably need to qualify my statement. There are "bio" based mixtures in all kinds of car parts. They are mixed with synthetic compounds to form a lot of different car parts. I should have said "RATS ARE NOT CHEWING YOUR WIRES BECAUSE THERE IS SOME BIO BASED COMPOUND IN THE WIRE COATING." Lol. Outside plastic parts, carpet, seat foam, the plastic cowlings, the plastic engine cover all contain bio based compounds yet rodents only chew the wires? I used to work on cars for a living and replaced a lot of wiring harness damage from rodents...way back when they were made strictly from man made products like vinyl. Rats still chewed them up.https://bioplasticsnews.com/2019/11/26/history-bioplastics-automotive-car-industry/
    Here is a good link:
  6. Nov 29, 2022 at 6:23 AM
    #46
    BkerChuck
    BkerChuck Well-Known Member
    Chuck
    Etters, PA
    2017 Tacoma TRD Sport Blazing Blue Pearl
    I put more miles per year on my motorcycle than my Tacoma. My truck is primarily there for winter and foul weather use and as such sits for weeks at a time. My commute to work is 10 miles one way. I've actually had to make a concerted effort to drive it over the summer so it doesn't sit for too long. I dealt with that with my last truck, a Ford F-150, and know just how harmful that can be to just let it sit.
    I try to drive the truck now at least once every 7-10 days for no less than 20 miles. That seems to be sufficient to warm up all the fluids and burn off moisture and make sure the tires don't flat spot. Recently I've been forced to drive it more as construction in front of where I work has the road so torn up I don't want to take the bike to work. Hoping they're soon finished.
    Sinister184[OP] likes this.
  7. Nov 29, 2022 at 6:36 AM
    #47
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I know this is anecdotal but I've owned my Mustang for over 20 years and at some points the car has sat for 2 years without being driven. I've let the battery die more times than I can count. I just put my second battery in the car (3 total now) so I average about 10 years a battery. I usually have it on a tender though.
    My alternators do tend to last about 30K miles but that's thanks to Ford for putting it right next to the exhaust manifold. In the time I've gotten flat spots on my tires, had a fuel pump fail and the AC discharge. This was all well after the car was 15 years old though. Luckily AC took a charge and has held for over 2 years now. Car has been fine other than that, no oil leaks, etc and always fires right up. It is garage kept though.
  8. Nov 29, 2022 at 6:45 AM
    #48
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    L.O.L.
    Careful of G.W. protesters...
    :rolleyes:
  9. Nov 29, 2022 at 6:49 AM
    #49
    stftaco
    That'll make all the difference.
  10. Nov 29, 2022 at 6:51 AM
    #50
    Vmax540
    Chuck
    Clarion PA.
    https://community.fmca.com/topic/11489-tires-parked-for-months-on-cement-is-there-a-problem/
    There are a variety of things that can be used as parking pads to protect tires and extend their life. There are special pads for this purpose, I've used wood and now I use cutting boards, inexpensive ones from Walmart will do. Whatever you use should be large enough to support the entire footprint of each tire.
    To reduce the flat spot, inflate your tires to the maximum pressure given on the tire and the rim. Do not exceed the lesser of those two pressures. An alternate would be to put the jacks down to relieve the weight being supported by the tires. You could also put the coach up on blocks as another alternative.
    If parked outdoors, the tires should be covered to protect them from UV rays of the sun.
  11. Nov 29, 2022 at 9:25 AM
    #51
    Quien es?
    Quien es? Well-Known Member
    Central TX
    2020 DCSB SR 4x4
    Armrest cushion, Glovebox divider, Toolbox
    I'm in a similar situation as the OP- I only drive once a week and not usually very far. This past week, I had to get on an Interstate that is about 5 miles from my house. I had to accelerate pretty quickly to get from 10mph to 75mph--- and there was a cloud of white smoke behind me for the whole on-ramp. I think it was condensation that had built up in the exhaust- but who knows? It hasn't done it again since then, but it lends credence to the point that vehicles need to move for long enough for everything to be warmed up and moving.
    stftaco[QUOTED] likes this.
  12. Nov 29, 2022 at 9:28 AM
    #52
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    OP, I drive about as much as you and have zero worries. My truck has been idle for as much as 3 months with no visible issues. Boats, motorcycles, snowmobiles, etc. sit idle for many months at a time. I’m pretty sure that driving your truck puts a lot more wear on it than letting it sit, with a few caveats already mentioned in the thread.
    CherylJane and Sinister184[OP] like this.
  13. Nov 29, 2022 at 11:11 AM
    #53
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    Keep up with the maintenance. a manual trd or with super low mileage would be worth like $100k in 20 years
    Sinister184[OP], Junkhead and stftaco like this.
  14. Nov 29, 2022 at 11:25 AM
    #54
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Good post. Years ago had a rat chew on a power cable. I think their tastes lean toward PVC wire insulation but not exclusively lol.
    CherylJane and hiPSI[QUOTED] like this.
  15. Nov 29, 2022 at 12:04 PM
    #55
    stftaco
    I try to avoid just a quick trip to the corner store and back (total about 2mi). I will drive a few extra miles before returning home. I don't want to play unfair with the CAT converter. I will do this sometimes even if all I'm doing is re-arranging our car and the truck if/when we are expecting company that need to park closer to the house. Old habits die hard.
    Quien es?[QUOTED] likes this.
  16. Nov 29, 2022 at 6:11 PM
    #56
    Sinister184
    I always floor it in 2nd up to redline at least one when I go out for this reason. I bought an 84 351 Bronco in early 2000s from an old man who just used it around his farm. It took months for it to stop billowing carbon smoke under heavy throttle. I had to floor it everywhere for months to get it the clear up.
  17. Nov 29, 2022 at 6:13 PM
    #57
    Sinister184
    Let's hope! :thumbsup:
