How much do I need to spend on rock sliders 2024
Discussion in 'Armor' started by soggyBottom, Apr 23, 2024.
  1. Apr 23, 2024 at 8:00 PM
    soggyBottom
    soggyBottom [OP] Well-Known Member
    I've seen bolt on rock sliders go between $700 and almost $2000. How much do I really need to spend? What am I really getting for the increased cost?
  2. Apr 23, 2024 at 8:21 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    The same failure points. Go weld-on
  3. Apr 24, 2024 at 5:56 AM
    soggyBottom
    What's the deal with the failure points? I'm considering making my own
  4. Apr 24, 2024 at 9:14 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    Bolt on are not as strong as welded to frame. Some of the cheapy bolt ons you see on Amazon are barely strong enough to work as cab steps
    Post some examples of what's $700 vs $2000. I got some weld on 4xInnovations for a few hundred and they serve the purpose.
    SH10151 likes this.
  5. Apr 24, 2024 at 11:33 AM
    kyle11863
    kyle11863 King of the BS
    Kyle
    Big Bear, CA
    1990 Toyota 4Runner SR5 V6 4x4
    Doug Thorley long tube headers and lots of mud
    All depends on the build of the slider. Take Coastal offroad for example, they use a lot of square tubing for the main tube and the legs which makes the slider considerably stronger. They also use 3/16" frame plates that run the length of the cab and brace the bottom of the frame too. Not to mention the huge gussets they include as well. So you're getting considerably more steel and engineering to make these strong rock slider than you are for one of those cheap Amazon sliders that use HREW tubes for everything.
    If you're interested in checking them out we have this group buy running which can save you some money on their products with this group buy
    https://www.tacomaworld.com/threads...ders-skids-group-buy-all-makes-models.829531/
  6. Apr 24, 2024 at 11:43 AM
    BirchyBoy
    BirchyBoy Well-Known Member
    ‘20 Tacoma SR DCSB
    Think about how much you’re going to be testing the sliders:
    If you’re going to drive on the road mostly and maybe go on a trail infrequently, a lesser set would likely be sufficient. The lesser sets will be made from thinner steel and the attachment to the truck won’t be as robust. Anything that attaches to the underside of the cab, not the frame, won’t give much protection and may cause more harm.
    If you’re not planning to go and beat the heck out of it but will encounter the occasional rock or tree, you can safely use some mid-range sliders that are bolt on. There are lots of good options out there between $900 and $1,300 and shipping costs will likely be extra.
    if you’re going full rock crawling, spend as much as you can because you’ll be relying on them very often. A dollar spent now will save a lot more later.
    A good set adds quite a bit of weight unless they’re aluminum. My RSG’s are bolt on and weigh about 200lbs for the set.
    slinkz419 likes this.
