How much does a 1st gen, 5spd tranny weigh?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Moco, Apr 10, 2013.
  1. Apr 10, 2013 at 12:53 PM
    Moco
    Moco [OP] Well-Known Member
    Eric
    NoVA
    96 Regular Cab 4x4 5spd
    My clutch is starting to make some funky noises when I engage it (the noise goes and comes). This is sounding like I will need to replace the clutch at some point not in the too distant future.
    I've never pulled a tranny or done a clutch in any car/truck before, but think I'm up for the job for this truck. My main concern is the physically manhandling of the tranny - I will be doing this job on 3 ton jackstands. I'm figuring the money I will save on labor will more than offset the $80 cost to get one of these:
    For you guys that have pulled transmissions in these trucks without a lift, what tips and tricks did you pick up? Is handling a transmission possible with one person? Whats the weight of the unit?
    Also, apparently there is a need to resurface the flywheel? I know Eric the Car Guy has his own homemade method that he claims works pretty well for him using sandpaper. Any thoughts on this?
  2. Apr 10, 2013 at 1:03 PM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    I've had my trans out 2 times now.
    The trans with transfercase unit is probably around #110.
    My truck is about 4-5" higher than stock and that floor jack worked fine.
    I borrowed that one from my buddy last time.
    I'm 5'8" and #150 and can wrestle the trans/ tcase without issue.
    Resurface the fly wheel no matter what.
    Go for it, if you're handy with a wrench its not a hard job. Just tedious.
  3. Apr 10, 2013 at 2:10 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    2 moderately strong guys could hold each side and drop it out without much struggle. The hardest part will be the lack of space to move around.
  4. Apr 10, 2013 at 4:41 PM
    Slodgetto
    Slodgetto Über Posre
    Silas
    x2
    I've dropped/reinstalled my auto (which I think is heavier than the 5 speed), I used that exact jack and did the job myself. Totally doable.... just tedious like Scuba said.
  5. Apr 10, 2013 at 7:36 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    HA! You KNOW that auto R&R is a pain in the ass, def. easier doing the manual..:)
  6. Apr 11, 2013 at 5:20 AM
    Moco
    Eric
    NoVA
    Sweet!
    Thanks guys for the input. I'm planning on doing this in the summer, when I have a bit more free time. I may just do a DIY writeup if the situation presents itself as I didn't see one here on this board.
    Thanks again.
