How much does your Tacoma *WEIGH*?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Key-Rei, Oct 22, 2020.
  1. Oct 22, 2020 at 11:06 AM
    Key-Rei
    Key-Rei [OP] Well-Known Member
    Key
    Florida
    Had to run some stuff to the transfer station, they weigh before and after you drop off and it got me wondering.
    How much does your Tacoma WEIGH?
    Sorry if this thread exists, didn't find a specific one with a quick search.
    With a full tank of gas, ARB front bumper, All-Pro Off-Road Swingouts rear with spare (34" tires) sliders, front skid, and the gear I regularly haul scale says my truck is a surprising:
    5200 lbs! :eek:
    Right on the dot but I think the scale is only accurate to about ≈10±.
    How heavy is yours?
  2. Oct 22, 2020 at 11:08 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Add about a thousand pounds to that for me...
  3. Oct 22, 2020 at 11:11 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    @nudavinci64 I think will hold the crown. I think his truck is almost 7000lbs. I would say mine is around 4000lbs.
  4. Oct 22, 2020 at 11:12 AM
    Key-Rei
    Key
    Florida
    :ohsnap:
    You solid axle swapped on 37's or something?
  5. Oct 22, 2020 at 11:13 AM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Largely stock 2010 RC 5-lug automatic; Stock weight somewhere around 3,100 pounds, and I’m guessing that the stereo components and slightly beefier tires add a few pounds...
  6. Oct 22, 2020 at 11:14 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    With you in it? Jeez you guys drive some heavy pigs. ~4,900 for mine. DCSB V6 4x4 w/ 285 weld on sliders/hybrid bumper, skid and winch and tow package
  7. Oct 22, 2020 at 11:15 AM
    YF_Ryan
    Kent, WA
    My buddy's weighed over 7K BEFORE the GFC.
    dpf88101 and rob1208 like this.
  8. Oct 22, 2020 at 11:17 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    And that's static weight? That's crazy.
    ridefreak and whatstcp like this.
  9. Oct 22, 2020 at 11:17 AM
    YF_Ryan
    Kent, WA
    NOPE. OEM sized tires.
    Key-Rei[QUOTED][OP] likes this.
  10. Oct 22, 2020 at 11:29 AM
    YF_Ryan
    Kent, WA
    I decided to pull the Hot water heater, propane, water cans, and mounts off just last night. Didn't want the heater to get damaged if it froze, and not planning any camping for awhile. Crazy how things add up so fast. Had 80lbs for water and cans, 25 for the propane tank and mount, another 30 or so for my hot water system, and whatever the dual jerry basket weights. Prolly took 135lbs or more off.
    Key-Rei[OP] likes this.
  11. Oct 22, 2020 at 11:44 AM
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    ~6450 with a full tank of gas, drifter (485# with 2x frontrunner doors, fan, and 6ft awning), steel front (hybrid) and rear bumpers (dual swingout), 1/4" bamf steel skid trilogy, bamf sliders, kbvoodoo side rail caps, full sized spare 33" tire, ADS suspension all around with 700# springs up front and upgraded deaver stage 3 leaf pack, bbk, fridge, and two passengers. I'm slightly heavier now since I upgraded to 35" MTs (geolandars).
    My truck is a pig and needs to go on a diet but even without the drifter, I was ~5900 before installation.
    dpf88101 likes this.
  12. Oct 22, 2020 at 12:06 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The GVWR on most 2nd gens is 5450 lbs. That is supposed to include all passengers, cargo and modifications. If true you're overloaded by 1000 lbs. My 4X4 F150 Supercrew is right at 6000 lbs.
    My Tacoma is right at 4500 lbs including the fiberglass cap.
  13. Oct 22, 2020 at 2:13 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    yah shit the other guy at 5300 and has a lot of the same stuff. still trying to figure out where all the weight is. but yah 7,000 crazy talk.
  14. Oct 22, 2020 at 2:17 PM
    nudavinci64
    Robert
    yah were almost identical. the 35's prob are what put me close to the 7k that and the 1/4 BAMF setup that I also have.
    rob1208[QUOTED] likes this.
  15. Oct 22, 2020 at 2:20 PM
    nudavinci64
    Robert
    yah most of the expo rigs you see out there are over the GVWR for sure. When I was talking to someone about Deavers they would not recommend anything and said it would come from Deaver. They pretty much said the same but said they would get it taken care of but shedding 500lbs will be major. I am getting a wedge camper setup soon so as I pull my shell will pull things like slide, tire, gas etc and see how much I can get the truck down and try and pin point anywhere I can drop weight. going from 1/4 BAMF to a 3/16th setup will save prob 100lbs on its own. I was going to look into a hybrid but most of the hybrids seem to weigh more than the Pelfrey plate bumper (not sure how i feel on that).
    rob1208 likes this.
  16. Oct 22, 2020 at 2:32 PM
    rob1208
    Rob
    SF Bay Area
    fully agreed. I want to shed weight but for the type of wheeling I do and the bad lines i end up on, there isn't much area to lose weight short of stripping the interior and what not.
    1/4" bamf steel skid triology = ~150 pounds is my guess
    steel bumpers with swingouts = ~few more hundred pounds
    bigger tires = ~100 more pounds over stock
    sliders = 62.5# each
    just that alone is probably ~600-700 pounds into the 1k payload capacity of the truck without any camping / recovery gear and no passengers.
    to be able to safely run rubicon / slickrock and similar trails out here in the sierras, not sure which of the above I'd be willing to remove (though I have thought about removing my swingouts and just strapping the spare tire in the drifter). I think once I'm ready to no longer run hard trails, I can start to reduce weight and switch out to aluminum armor. If I can find a way to remove the drifter easily and store it at home, I'd do it since I'd much prefer driving around daily and on wheeling day trips at a much lighter weight.
    With all of that being said, the rear frame of my truck is boxed, upgraded big brakes in the front, better pads all around, ss brake lines, stronger leaf pack and springs make the truck drive and stop pretty good and I try to drive like grandpa everywhere.
  17. Oct 22, 2020 at 4:07 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I was hauling rip-rap in mine a few years ago so if I recall correctly, mine was right at 4,400 lbs, mostly stock. The only weight adder I have is a set of sliders.
  18. Oct 22, 2020 at 5:36 PM
    wiggler
    wiggler Well-Known Member
    HILO
    2013 OR AC 6MT & 1998 4Runner sr5 auto
    4400ish last time I went to the transfer station scale. Was like 4640 or something and I weigh 150. Access cab and only things heavier than stock are 285/55’s and aluminum Thule bed racks.
  19. Oct 22, 2020 at 7:06 PM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    This should just be the “how to make an MPG pig even worse” thread.
    Tiberius, mic_sierra, Knute and 2 others like this.
  20. Oct 22, 2020 at 11:09 PM
    nudavinci64
    Robert
    Still confuses me though that your truck is lighter. We have almost identical setups except I have a Leer shell and you have the difter yet I am running roughly 4-500 more (unless the new weight is closer) The boxed frame I assume adds some weight which I dont have. I picked it up all up similar as I need to have some beefy stuff with what we tend to have access to but man its heavy.
