How much does your truck shake while idling?
Discussion in '1st Gen. Tacomas (1995-2004)' started by beedoola, May 24, 2012.
  1. May 24, 2012 at 9:14 AM
    beedoola
    beedoola [OP] Well-Known Member
    San Francisco, CA
    01' Tacoma PreRunner 2.7
    Now when I mean "shake," I do mean like crazy, driving over speed bumps shake, rather a little vibration. I'm asking cause mine kinda shakes while idling and I want to know if perhaps there is something I need to address.
    My taco is a 2.7 4 cyl
    140k, I got it at 130k, replaced the spark plugs, belts, transmission fluid, done two oil changes since then.
    Should I attempt the Seafoam treatment?
  2. May 24, 2012 at 9:16 AM
    blitzburgh99
    blitzburgh99 Well-Known Member
    Houston, TX
    1999 Tacoma TRD 4x4
    239,600 (as of 7-20-13 and counting)original owner miles
    Depends on how big the girl I am on top of is!!!
  3. May 24, 2012 at 9:23 AM
    boshak
    boshak Well-Known Member
    Tony
    Southern California
    2003 Manual 4x4 5VZ-FE
    OME 881's, Wheeler's 5-leaf pack, Bilstein 5100's
    How many RPMs at idle?
    Suggest cleaning your MAF and TB.
  4. May 25, 2012 at 10:15 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    These are good ideas to fix rough idle. Seafoam works, I haven't had problems using it on a couple of 3.4l motors.
  5. May 25, 2012 at 10:16 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    if it's an auto a little shake is normal when in drive.
  6. May 26, 2012 at 8:56 AM
    beedoola
    San Francisco, CA
    the line below 1000rpm - so guessing thats indicating 750-800. Some times it will drop a little lower and then back up. Are there any tutorials/guides on here for MAF and TB cleaning?
  7. May 26, 2012 at 9:35 AM
    boshak
    Tony
    Southern California
    When it drops, does it go below 600? And is that when you feel the shake most?
  8. May 26, 2012 at 8:31 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    San Francisco
    2001 prerunner doublecab limited
    2001 with; cat-back twin exhaust,elbow mod, Westin bullbar with Hella550's, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Just a thought-the 4-banger in these trucks has a kinda radical pulsing at idle that often can trigger a harmonic vibe in the exhaust system-I discovered this in my stepson's '99 reg cab Tacoma. His was vibrating the frame at the hangar near the middle of the truck. I grabbed a pair of lockjaws and bent the hangar a little sideways and the vibe disappeared.
