How much downtravel do you have after the lift?
Discussion in 'Suspension' started by DTacoms, Nov 15, 2010.
  1. Nov 15, 2010 at 12:17 PM
    DTacoms
    DTacoms [OP] Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    I have ICON extended travel coilovers and TC UCAs. The coilovers are cranked to achieve 3" lift (ground to fender is 38.5" or wheel hub to fender is 23.5").
    The downtravel right now is:
    Driver side: 1.5"
    Passenger: 2.25"
    Btw, I measured it by getting the difference of the distance from tip of tire to fender while the tire is on a level ground and off the ground.
    I think it is stiff on highways.
    What do you think of the downtravel? Is it bad? Should I suspect that the coilovers have sagged now?
    I need your inputs please. Also, please post your setup, the downtravel and quality of ride so we can compare.
    Thanks.
  2. Nov 15, 2010 at 12:23 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Well stock travel is what 8". So you lift it 2" your down travel is down ~2". You lift it 3" downtravel is ~1"...am I right or am I wrong? I would imagine thats how it goes roughly :confused: You can also gain a little travel by removing the sway bar
    johnnytwotimes likes this.
  3. Nov 15, 2010 at 12:24 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    correct!
  4. Nov 15, 2010 at 12:29 PM
    DTacoms
    Frisco, Texas
    05 4x4 DC LB BSP
    So it looks like the ICON extended travel and TC UCA allows me more travel then?
  5. Nov 15, 2010 at 12:29 PM
    08pretaco
    az
    Thats why they are called EXTENDED travel :thumbsup: lol just messing around a little man
  6. Nov 15, 2010 at 12:34 PM
    DTacoms
    Frisco, Texas
    05 4x4 DC LB BSP
    Thanks for your input man.
    ICON said that I need to have 2" of downtravel to have better ride (just like stock!). So now, I need to find a way to get 2" of downtravel in the driver side. Do you think by adding a spacer and reducing the preload will gain me more travel? Is this advisable?
  7. Nov 15, 2010 at 12:36 PM
    08pretaco
    az
    I would not change out preload for a spacer because the 2 dont work the same. Hmm to gain that extra .5" maybe just remove the sway bar! Easy solution that will give you more travel on both sides!
    Oh and also pairing with the Uniball UCA and coilovers will yield a little more travel than the stock ball joints
  8. Nov 15, 2010 at 3:13 PM
    DTacoms
    Frisco, Texas
    05 4x4 DC LB BSP
    For now, I won't remove the swaybar for the extra travel.
    I hope someone with similar setup will chime in so I can compare. I just think my coilovers are sagging now.
  9. Nov 15, 2010 at 3:14 PM
    PLC721
    Patrick
    Chandler, Az
    i removed mine and love it
  10. Nov 15, 2010 at 3:18 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Remove your sway bar. I have the same set up as you.
  11. Nov 15, 2010 at 5:31 PM
    DTacoms
    Frisco, Texas
    05 4x4 DC LB BSP
    How much travel did you have before?
  12. Nov 15, 2010 at 5:34 PM
    1337Taco
    Kevin
    NorCal
    2015 4X4 Manual
    No idea what I had before, but after it was:
    hub to fender on both sides = just under 24.5"
    When it was jacked up = 27"
  13. Nov 15, 2010 at 5:39 PM
    jandrews
    '09 FourDubDee TRD OR
    Extended travel ICON COs here and TC UCAs. I have about 4" of droop from ride height, which is 38" ground to fender in the front, 23" from hub to fender. Also, my swaybar is off.
    FYI, 38.5" ground to fender is about a 3.5" lift...watch your CVs...
    Ride for me is fine, but that's cause my COs aren't way cranked up. A little stiffer on the road, but takes big hits much better.
  14. Nov 15, 2010 at 6:56 PM
    DTacoms
    Frisco, Texas
    05 4x4 DC LB BSP
    I saw a post here that 38.5" is 3" lift. I don't have a stock measurement, so I just followed them. Anyway, here are some photos of my passenger CV. Does it look alright by the look of the boots? The photos will not show the correct angle though.
  15. Nov 15, 2010 at 7:12 PM
    jandrews
    Those posts are wrong. Go to any dealership lot or any stock 2nd gen Taco you can find and measure hub-to-fender. It's always 20 inches, give or take a quarter inch. Stock ground-to-fender is 34 inches, give or take a 1/4".
    Your inner boots are way tight in that photo. If you're lucky they won't eat themselves. I myself wouldn't take the chance. How long have you had the COs on in front?
  16. Nov 15, 2010 at 7:42 PM
    DTacoms
    Frisco, Texas
    05 4x4 DC LB BSP
    I have it for a year but it was only yesterday that I cranked it 38.5". It had been at 38" but I thought it sagged because it's rubbing cab mount more. I might crank it down a little bit.
    Thanks for the input.
  17. Dec 20, 2010 at 11:32 AM
    DTacoms
    Frisco, Texas
    05 4x4 DC LB BSP
    I added a Toytec 1/4" in the driver's side on top of the coilover and then cranked down the coilovers at both sides. With the added spacer, I was able get equal amount of thread (2 inches) showing in the coilovers. With this, I measured 23" inches from hub center to fender (38" from ground to fender). Downtravel at both sides are 2.5". The fins of the CV boots are not touching anymore. I don't have differential drop.
    I'm loving the ride; it feels like stock. And oh, I got rid of the cab mount rubbing at full turn with caster set at 2.8.
  18. Dec 22, 2010 at 8:28 PM
    S.S.T.
    S.S.T. Well-Known Member
    Torrance, CA
    07 TRD Off Road Access Cab
    Icon 2.5 Extended Travel Coilovers, 5100 rears, Icon Progressive 3 leaf AAL, Hankook Dynapro ATM 265/75R16, 16x8 Renegade 6 wheels, AFE Pro Dry S air filter, BHLM.
    What size are your tires? Larger tires will skew the ground to fender measurement. Hub center to fender is more accurate while measuring lift.
  19. Dec 22, 2010 at 8:32 PM
    1337Taco
    Kevin
    NorCal
    2015 4X4 Manual
    This. ^
    I have a "3 inch lift" but my measurements ground to fender are above 40".
  20. Dec 22, 2010 at 8:38 PM
    jandrews
    You may note the 285 tire size listed in his signature...
