How much fluid does an empty A340F take?
Discussion in '1st Gen. Tacomas (1995-2004)' started by treyus30, Jun 29, 2023.
  1. Jun 29, 2023 at 7:05 PM
    treyus30
    treyus30 [OP] 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    I just did a 4x4 swap (no front diff yet) with the transgo reprogramming kit. I have no Reverse gear and Drive is half responsive. I've poured over a gallon into the pan but the dipstick still is pretty dry (just the edges show fluid). The owners manual shows only 2 qt needed for a drain/refill, but how much for a full refill? Have I overfilled it?
  2. Jun 29, 2023 at 7:18 PM
    Bishop84
    Bishop84 Well-Known Member
    6 liters, or 6ish qts. It really varies.
    Keep adding one by one and checking.
    TnShooter likes this.
  3. Jun 29, 2023 at 7:19 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Alright, reassuring, I'll go grab some more before they close, thx
  4. Jun 29, 2023 at 8:28 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    That ended up being the issue, along with the transfer case being in some kind of limbo state... I had to crunch some gears then everything started working normally
    Bishop84 likes this.
  5. Jun 29, 2023 at 10:10 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    When we did mine a few weeks ago, it took at least 6 or 7 qts to top it off. It would have been even more if the torque converter started out empty. Mine wasn't.
    IIRC, the FSM for '03 says there is a 10 qt capacity for the A340F.
