How much fuel left when you get the "gas low" light?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Stoic, May 8, 2012.
  1. May 8, 2012 at 6:32 AM
    Stoic
    Stoic [OP] But I'm not bitter
    Clearwater, FL
    2004 PreRunner SR5 V6 3.4L
    My just purchased '04 3.4L V6 (PreRunner 18.5 gal tank) just had the light go on after only 260 miles. I'm going to fill it up to see how much fuel was left. I'm hoping at least 2-2.5 gals otherwise this thing is going to be a pig on mileage. It was about 75/25 city/highway.
    Maybe a tune-up will help.:facepalm:
  2. May 8, 2012 at 7:27 AM
    Madjik_Man
    Colorado Front Range
    If you really want to be diligent with fuel economy, sign up for fuelly.com (it's free). After a few months of tracking my mpgs I began to change habits, etc... and now I'm averaging 22 mpg (non-winter gas)
  3. May 8, 2012 at 7:28 AM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    you have about 4 gal left after the light comes on. for me at least.
  4. May 8, 2012 at 8:34 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I would not make it a habit to run the tank low and over heat the fuel pump.
  5. May 8, 2012 at 9:17 AM
    AK Taco
    AK Taco Well-Known Member
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    20% tint on all windows, Deckplate mod, satoshi-ish grille, blacked out and/or body matched emblems, rattle canned rims, red l.e.d. interior lights, bilstein 5100's and OME 881 coils , deaver 8 leaf pack, 1.5" lift shackle, alpine sound system, 55w HID lightforce 140 and 170 fogs
    I try not to run that low on gas but there have been times when ive put 16-16.5 gallons in my tank and the gas light wasn't on.
  6. May 8, 2012 at 9:24 AM
    Madjik_Man
    I understand the mechanics of the pump and all, but I honestly have been filling up with less than 1/4 tank left for 13 years.
    No problems *knock on wood* so far.
  7. May 8, 2012 at 1:30 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    well coming from a ol' timer, 1/4 tank is fine, its making it a habit of running it that low that the fuel light comes on is where you can have a problem.
    I remember some points on this from popular mechanics.
    1, when the tank gets that low, with stop and go traffic, you can expose the pump even if its for a second its not good for it.
    2. after any car/truck as age on it you run the risk of having some trash in the bottom of tank and that can get sucked in.
    3. leaving a tank that low for long periods can cause the tank so sweat on the inside, and over the life of a vehicle it can build up.
    I am not saying this will happen, it could happen.
    and remember, it always easier to fill up the tank these day when its half full, instead of empty, so you don't pass out!
    and remember, on most cars, and I believe it is the same on the truck, you have two fuel filter. the main one protects the injectors, engine, you change. the second is part of the fuel pump, that is the one that can get clogged with water, trash, when the tank is low to dry, and this is what will starve and over heat or put stress on the fuel pump.
  8. May 8, 2012 at 7:17 PM
    Stoic
    Clearwater, FL
    I normally fill up my other cars at about 1/4 full but I wanted to get a reading on the mileage on the truck. Went out this morning to Costco to fill up and it took 16.5 gals so my light comes on with 2 gals left. I figured that gave me about 300 miles per full tank. I had a '92 Toyota 4X4 manual transmission that gave me better than that after 200K miles so I'll be looking into any way to make improvements. Still, I won't be doing any long distance driving in this. This will be my local hauler.
  9. May 8, 2012 at 7:20 PM
    Madjik_Man
    FWIW at 1/4 tank I am usually at 300 miles driven.
    Try using cruise control as much as possible, obviously only when it's safe.
    I use it almost 80% I'm driving.
  10. May 8, 2012 at 7:21 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Approx. 2 gallons.
  11. May 8, 2012 at 7:24 PM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    yes but are you a 2.7 4 cyl or a 3.4 v6?
    I drive like a stole it with a lift and larger tires and get 260 before my light comes on. or like 16-18 mpg.
    The 4cyl ones get an average 5 mpg better.
    I usually fill up at 1/4 tank or less.
  12. May 8, 2012 at 7:37 PM
    Madjik_Man
    3.4L V6 5-speed
  13. May 8, 2012 at 9:28 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    My light comes on when I have about 2 gallons remaining.
    260 miles on 16 gals of non-winter formula gas sounds low. I get about 20MPG on non-winter gas and about 17MPG on the winter garbage, for an overall average of about 18-19MPG or ~300 miles before the light comes on.
  14. May 8, 2012 at 11:15 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I believe its 2 gallons left when the light comes on. And FWIW, I get 230 miles before my light comes on...which has been right around 15mpg the last few tanks. It sucks.
  15. May 8, 2012 at 11:46 PM
    htuong95
    htuong95 Have a nice day
    Sacramento
    2001 Tacoma 4x4
    Full OME suspension, Level 8 Tracker 16" wheels, BFG T/A KO 285/75/16, etc., work in progress...
    I get at least 300 miles before my light comes on. Base on my receipt at the gas station, two gallons left in the tank sounds about right.
  16. May 9, 2012 at 12:27 AM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    Mmm 2 gallons seems around the area think a little more.
    I've driven the needle down below the top line in the letter E . Was not fun driving home at 2am on the freeway .Think I just made it don't home, don't know if I imagined the truck being sluggish.
    Next morning I changed the fuel filter and transfered gas from my motorcycle
  17. May 9, 2012 at 4:54 AM
    Stoic
    Clearwater, FL
  18. May 9, 2012 at 5:53 AM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    On my 2000 I have about 2-3 gallons left when the light comes on.
  19. May 10, 2012 at 9:10 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I too, have about 2 gals. left after the light. Usually at 240-250 miles. i wish I got some of you guys mileage. 3.4,5-spd. lifted. I usually avg. 15-16 hwy. I drive 80-85mph.
  20. May 10, 2012 at 11:39 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    You wish you did? Then why are you driving 85mph? :confused:
    Try 65mph. Huge difference in mileage, especially in a pickup or suv. :)
