How much fuel left when you get the "gas low" light?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Stoic, May 8, 2012.
  1. May 10, 2012 at 11:51 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    OP mentioned about 75% is city driving - that will mess up your mpg big time. I use an ultragauge so I can track real-time mpg. In the 3 miles from my house to the interstate I get 12 - 13 mpg because of red lights and stop signs. Then in 15 miles on the highway I get 20 mpg most of the time, which is acceptable, but because of a few accelerations on the highway to overtake and then the 3 miles city driving, my average is always at 16 mpg.
    Long road trips at 75 mph I get consistent 20 mpg, because it is just highway.
  2. May 10, 2012 at 11:56 AM
    Boerseun
    Ferdie
    Sarasota, Florida
    Very true. I do a fair amount of driving for work, in a Ford Explorer, 4.0 V6. I have done some comparrison testing on long highway trips (same route, different days)
    55 mph = 29 mpg±
    65 mph = 25 mpg±
    70 mph = 20 mpg±
    75 mph = 16 mpg±
    80 mph = 13 mpg±
    (Doing 55 mph on an interstate sucks - the average speed of the majority of traffic around here is 75 to 80)
  3. May 10, 2012 at 12:29 PM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    I use the Ultragauge as well and have it calibrated to within about 1-2% of what I get when I fill the tank and do the math.
    I have a V6 5-speed 4x4 with 31x10.5's at 35 PSI and consistently get 21 MPG going to work which is about 4 miles of city driving and 12 miles of highway driving. However, I drive 65 MPH on the freeway.
    I estimate that my 'highway only' mileage is about 22-23 MPG at 65 MPH. I bet I could squeeze 24 out at 55 or 60 MPH.
    I experimented with faster and slower highway speeds and the difference was amazing (I don't have that data in front of me right now but I think it was a 10% difference). What does not seem to make a significant difference is using the a/c or overinflating tires. I went from 35 to 45 PSI in the front tires and noticed less than a 1% difference in MPG.
    I also tried a tank of premium fuel and it made zero difference in my MPG. I just had to try that because my boss swears that premium fuel increases your MPG 10%. :D
    When my commute to work was exclusively city driving (5 miles) I got 14.5 MPG consistently.
    EDIT: Just found my data...60 MPH bumps me up to 23.8 MPG and 80 MPH dropped me to 18.0 on my work commute.
  4. May 10, 2012 at 12:39 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    I had my truck since new and it has NEVER came on. I filled up 14 gallons and still no light. i guess the 95 to 97 wasnt done? Tho it has the wiring for it and in the cluster it has a lamp and lamp is good. Im guessing toyota didnt put s signal forward on low on my year or i have a bad sensor from the factory and never knew it.
  5. May 10, 2012 at 1:05 PM
    Madjik_Man
    Colorado Front Range
    Slow down and use cruise control as much as possible
  6. May 10, 2012 at 3:12 PM
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    1) Not possible, I drive like I'm racing in the "Watermelon 500" :eek:
    2) Not possible, my truck does not have it! :mad:
  7. May 10, 2012 at 6:03 PM
    Stoic
    Stoic [OP] But I'm not bitter
    Clearwater, FL
    2004 PreRunner SR5 V6 3.4L
    I think the Mythbusters tested this and found that keeping a/c on or off didn't make a bit of difference.
  8. May 10, 2012 at 6:05 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I'm in a hurry (laughes). Really Cossing half my state in each trip takes forever at 65 and people are zipping by at 85 and 90. Put it this way, sometimes I just top it out and back off a bit. Like a boat.
  9. May 10, 2012 at 6:16 PM
    Stoic
    Clearwater, FL
    Before I bought my Tacoma I was using my RAV4 and a Honda Fit. Those little cars are so maneuverable and peppy I got into a lot of bad habits. Today I was out in the truck and started slooooooowing down and not trying to beat everyone to the next light.
    I'll see if that makes a difference the next time I measure the mileage.
  10. May 10, 2012 at 6:17 PM
    Gooch
    Orange County CA
    I think they did a/c versus windows down, but I'm not sure.
    Maybe I'll debunk the tailgate myth next...
  11. May 10, 2012 at 6:30 PM
    Stoic
    Clearwater, FL
    Yeah, it was that...http://youtu.be/ZRt20C6NL-c
  12. May 10, 2012 at 6:32 PM
    Gooch
    Orange County CA
    Using the Ultragauge I've found that the biggest MPG killer is using the brakes. Think about it...each time you use the brakes you convert your kinetic energy into heat, which is wasted. When you drive in a way that minimizes brake usage you save a lot of gas. I do that a lot but try to balance that with not pissing off the driver behind me.
    Also, coasting in neutral or with the clutch in going downhill saves a lot over staying in gear. You may have to use the brakes to avoid going too fast, but I still think you come out ahead with the money you save on gas versus premature brake wear (I'm still on my first set of rear brake pads with almost 100K miles on them).
    Another myth is that your best mileage is in your top gear. That is true at certain speeds, but I can get in the high 20's in 3rd or 4th gear in the 30 MPH range. So, driving in slow traffic may actually boost your mileage if you're not constantly hitting the brakes. Speed truly does kill.
    Another thing I'm testing now is the effect of hard acceleration on gas mileage. So far, it doesn't seem to make a differrence. The days that I floor it from 0-65 MPH when I get on the freeway (we have meters out here that stop you before you get on) versus the days where I accelerate gradually give me the same MPG.
    Another myth I debunked (at least for me and my truck) is that cruise control increases MPG. It didn't for me. Now, if you find your self going 10 MPH over the speed limit and then completely coming off the gas to where you're slightly engine braking and you do this a lot, I can see how it would help. But if you stay within +/- 3 MPH of your target and don't make radical adjustments to the throttle it doesn't seem to matter.
    My Ultragauge has probably paid for itself two or three times already because of how much it has changed my driving habits. It's a great little device.
    As with everything else, YMMV!!!
  13. May 10, 2012 at 6:39 PM
    Stoic
    Clearwater, FL
    LOL
  14. May 10, 2012 at 8:29 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I agree with much of this, with a couple of notable exceptions:
    - Hard acceleration kills my mileage
    - Cruise control definitely improves it, though not dramatically
  15. May 10, 2012 at 8:37 PM
    #35
    Madjik_Man
    I don't have an ultragauge or the likes but my Subaru had a built in "real time MPG" sensor, and every time I engine braked it would go up to 99.9 mpg. But if I got on the brakes it would only rise moderately (to like 40-45 mpg)
    As for cruise control, I've been tracking my fuel economy on Fuelly for over a year now (almost 14,000 miles) and noticed a 2-3 mpg increase when I committed to using it as much as possible. Winter gas withstanding of course.
  16. May 10, 2012 at 8:43 PM
    #36
    RMAN808
    RMAN808 S)(AKALO)(AWAII
    Reid
    Pearl City, Hawaii
    '17 TRD OR 4X4 Quicksand
    Sweet deals my man! I just signed up :p I think I'm getting bad mpg's :eek:
  17. May 10, 2012 at 8:44 PM
    #37
    Gooch
    Orange County CA
    My hard acceleration experiment is probably not a good one since I do it once on a 16 mile-trip. It's quite possible that it gets averaged out over the trip and becomes statistically insignificant.
  18. May 10, 2012 at 8:54 PM
    #38
    Gooch
    Orange County CA
    BTW cruise control will definitely increase your MPG if it helps you maintain your target speed and without it you tend to 'go over' a lot. Again, speed kills.
    I think it doesn't help me because I hold 65 MPH so tightly that the cruise control can't do it much better than I do.
  19. May 11, 2012 at 9:31 AM
    #39
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Anyone compare with ECT on and with ECT off?
  20. May 11, 2012 at 9:54 AM
    #40
    Johnnie
    Johnnie Well-Known Member
    I.E. SoCal
    Feds
    I have an '01 preruuner, 2.7l, 4.56 gears which is rare. I think the '01 2.7 is the only prerunner that has 4.56 gears. I'm wondering if the '01 has a smaller gas tank. I've read our tanks have 18 gallons but recently I filled up when the gas light came on once or twice. I filled up with 13.34 gallons. I'm wondering if my tank is 15 gallons.
