How much gas does the alternator take to run?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoma.Rovirosa, May 20, 2021.
  1. May 20, 2021 at 7:23 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
  2. May 20, 2021 at 7:34 PM
    Clearwater Bill
    Billy
    Largo Florida
    He lied.
    Alternator technology has been pretty consistent since the mid 60s when they became common as replacement for generators.
    If there were 15% MPG lost in the alternator, the OEs would have been all about a more efficient technology to get 5-10% improvement.
    hiPSI likes this.
  3. May 20, 2021 at 7:44 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    SERPENTINE BELT DRIVE SYSTEM
    Here’s a list of the items that the serpentine belt covers:
    Power Steering Pump Pulley
    Crankshaft Pulley
    Idler Pulley for Automatic Tensioner
    Water Pump Pulley
    Belt Idler No. 2
    Air Conditioning Compressor Pulley
    Alternator Pulley
    Belt Idler No. 1
    Lots of stuff to move!
    Remember the old days when the fan didn’t have a clutch? Now some cars use an electric fan to further reduce drag.
  4. May 20, 2021 at 7:59 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    If you really want to save fuel, take the fridge, tent, shovel, hi-lift, propane grill, jerry can, and whatever other unnecessary dead weight that you call "overlanding gear" and leave all of that shit in the garage.
    That's guaranteed to save far more fuel than bypassing the alternator.
    :cookiemonster:
  5. May 20, 2021 at 8:00 PM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    It has changed though. A lot of cars charge while the engine is in decel and not using gas. So they basically charge the battery with energy that would have otherwise been wasted. BMW claims a 4% decrease in fuel consumption.
    Kev250R likes this.
  6. May 20, 2021 at 9:51 PM
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    OP, I suggest you go to an auto parts store and turn an Alternator there. They all spin pretty freely so the amount of drag on the engine is going to be minimal. Drag from the A/C Compressor (when it's engaged) and the P/S pump will be much greater. I think that's the reason why a lot of models are using electric P/S now.
  7. May 20, 2021 at 10:05 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    How much blinker fluid do you use a month.
  8. May 20, 2021 at 10:09 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    https://www.rapidtables.com/convert/power/Watt_to_BTU.html
    There are only so many BTUs in a gallon of gas.
  9. May 20, 2021 at 10:10 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    You’re talking about hybrids. Not straight gas.
  10. May 20, 2021 at 10:12 PM
    VTCAL
    2021 Sport
    Curious would be the typical "moderate speed Horsepower consumption of the tonka trucks RELATIVE to electrical consumption (at night)
  11. May 20, 2021 at 10:26 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    The math is easy, calculating the load accurately is the hard part. Convert the load in watts to HP and you can get a very rough idea of how much energy from the engine is used to generate electricity. Don't try to figure it out to any sort of real fuel consumption numbers, though, because there are too many variables that change engine efficiency that you could never really know how much power is going to electrical energy generation and how much is going to other energy use. A ballpark percentage is probably the best your can get.
  12. May 21, 2021 at 2:02 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    EVs and Hybrids use regenerative braking. In gas engines the alternator is always running as long as the engine is running and thus it is always charging. Without it the engine would likely be only running on the battery and you wouldn't be getting very far. Unless of course there's some wizardry I'm not aware of, I believe alternators are relatively simple systems.
  13. May 21, 2021 at 2:05 AM
    Strostkovy
    Strostkovy Well-Known Member
    Alex
    White 98 Tacoma
    I think some charging systems reduce the alternator output at high throttle and maximize it at low throttle. So you are slightly draining the battery as you get on the gas but it holds out with the hope you'll let off and slow down again. At a certain point it obviously needs to charge the battery no matter what, and I don't think these systems cycle the battery very deeply.
  14. May 21, 2021 at 6:36 AM
    Gutentight
    Gutentight Well-Known Member
    IL
    2021 Cement Off-Road 4x4 DCSB 3.5L AT
    Generally speaking the alternator sucks less fuel than the added drag of solar panels on top.
  15. May 21, 2021 at 7:01 AM
    #35
    RX1cobra
    19 OR
    Always spinning (I think some may even be clutched like the AC) yes but that doesn't mean its producing power. The amount of power it takes to spin the alternator is directly related to the demand placed on it. So if it's not being told to create power its only friction you have to overcome. If it's being told to produce full power it takes more power to spin.
    The computer knows the state of charge of the battery and when its supplying fuel to the engine. So it will do it's best to only run the alternator when no fuel is being supplied to the engine. Of course it will turn it on no matter what if the battery starts to get low.
    0xDEADBEEF likes this.
  16. May 21, 2021 at 7:04 AM
    #36
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    Prime example of someone who should never have purchased a truck to begin with LOL
  17. May 21, 2021 at 7:07 AM
    #37
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Lets take a look at Max power consumption of the alternator running at 130A compared to the Max power of the 4.0L
    2.5*100/278 = 0.9% (max alt load at max engine power). Less than 1%.
    Be generous to say the Tacoma get 20 mpg. The alt is consuming about 0.2 mpg (at full load)..........
    Where is the nit harvester?????
  18. May 21, 2021 at 8:14 AM
    #38
    Sharpish
    Brian
    So you’re saying there’s some kind of electric clutch on the alternator pulley? I’m sorry but I’m not buying it.
    An alternator is just copper wire windings spinning around magnets. There’s no intelligence to it. If it’s turning, it’s outputting 14.5 volts, and that’s that.
    beergeek likes this.
  19. May 21, 2021 at 8:33 AM
    #39
    RX1cobra
    19 OR
    So you think its going full bore all the time? It's not and it never has been that way. That would overcharge the battery. The voltage regulator controls how much or little energy the alternator creates (and consumes). The difference is now that is regulated via the computer and can be done at times the energy would have otherwise been wasted.
  20. May 21, 2021 at 8:37 AM
    #40
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Alternators have regulators in them that vary the output based on the load. They have had this for a very long time. Typically they just shoot for a specific voltage on the output and regulate current to hit that. But there's no reason you couldn't slap a chip in it and have it communicate with the ECU to optimize further.
    If they were completely unregulated and spinning all the time making power for the rpm, things would fry - energy doesn't just disappear.
    hr206 and Loco_Barbon like this.
