how much horse power stock?
Discussion in '1st Gen. Tacomas (1995-2004)' started by devilsalmostfree, Feb 20, 2009.
  1. Feb 20, 2009 at 9:15 PM
    devilsalmostfree
    devilsalmostfree [OP] Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    what kinda horse power did the 2.7 ltr engine come with stock? what r some cheaper things to do, to get a bit more out of it? also, what would be the best headers for these engines? thanks!
  2. Feb 21, 2009 at 6:32 AM
    chamuco12
    chamuco12 Active Member
    so cal
    2004 taco, 4cyl. 4x4
    k&n intake, flowmaster exhaust, 2.5 fabtek coilover lift,...
    i have a 2.7 4x4 and they seem to have decent power stock. I have a k&n intake kit, flowmaster exhaust and this morning i am about to install some doug thorley headers on the puppy...ill let u know if it feels any different afterwards...oh and i already purchased an electric radiator fan for it its on back order...the less belt drag on the engine the better...any little bit helps. (the manufacturer also says it will help on fuel efficiensy as well). up to 10%. not much but enough to convice me....i am currently buying this stuff from advancedspecialties.com check em out for more info
  3. Feb 21, 2009 at 6:38 AM
    chamuco12
    so cal
    im not exactly sure what the horsepower on your engine is...i have a 2.7 as well. I love it. the only mods so far are a k&n intake kit, flowmaster exhaust"custom made" to sit snug up against the body instead of hanging about six inches below the body(stock). also im about to do my first header install on this puppy...ill let youknow how it goes...
  4. Feb 21, 2009 at 6:39 AM
    chamuco12
    so cal
    if you can let them know that chamuco refered you there...thanx
  5. Feb 21, 2009 at 8:23 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    The 'official' (factory spec) 1999 3RZ ratings were as follows:
    HP (SAE Net): 150 HP @ 4800 RPM
    Torque: 177 lb.-ft. @ 4000 RPM
  6. Feb 21, 2009 at 8:26 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    My 2000 2.7 (same as yours) dynoed at 105 h.p. to the tires. North West Off Road makes an AWSOME header (Try-Y) that really wakes up the engine. Also, Alpine makes a bolt on supercharger for that motor. I installed the Alpine supercharger, NWOR headers, and an exhaust, and I dynoed 168 h.p. before any real tuning. Best things I did for that engine. :)
  7. Feb 21, 2009 at 8:28 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    ^ Forced Induction FTMFW!!!!!
  8. Feb 21, 2009 at 8:40 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2!!!
    I never ran my truck on the dyno after I had it tuned, but with 105 octain, my buddy ( road racer) couldnt shift out of first before the engine hit the limiter! :D That little truck could burn 32's thru second gear, and I could get a 60 mph chirp in 3rd!
    My favorite pic at Joshua Tree, CA. Second gear 5000 rpm maybe going 10 mph:
  9. Feb 21, 2009 at 8:43 AM
    dually
    dually Low and slow
    Hahahaha thats awesome!
  10. Feb 21, 2009 at 8:45 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thanks! You can see my tracks in the snd from the first run I did, and this dude came up to me wanting me to do it again so he could take a pic. SO, I had to do it again. :D
    Only thing that sucked, was I had my window down, so I got about 80# of sand on my lap. :eek:
  11. Feb 21, 2009 at 2:21 PM
    devilsalmostfree
    Carl
    Loudon, Tn
    cool man, i appreciate the help. i was just interested in knowing what they were stock!
    im interested in getting a header, not exactly sure what to get, or when ill be able to get 1!
  12. Feb 21, 2009 at 2:26 PM
    devilsalmostfree
    Carl
    Loudon, Tn
    yeah man, let me know on the header install. i will check out that web site, & be sure to mention u! thanks man.
  13. Feb 21, 2009 at 2:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Header install is pretty easy. The ONLY snag you will have is the EGR collector (not sure exactly what its called) is on the rear of the engine. I had to use my Wifes (Girlfriend at the time) little mirror to see behind the engine so I could disconnect the bolt. I would like to recomend the NWOR Try Y header for your truck, as the gains were very impressive. It felt like I was in 4th gear when I was actually in 5th.
    http://www.northwestoffroad.com/parts/triheaders.html
    If you deside on a header, be sure to buy the OEM Toyota gaskets. Even if the header manufacture says "No gaskets required" its BS. You need the gaskets. And some Copper RTV. :)
  14. Feb 21, 2009 at 2:45 PM
    devilsalmostfree
    Carl
    Loudon, Tn
    cool, thanks for the help. im not getting a header yet, but im going to check that egr collector out!
  15. Feb 21, 2009 at 4:45 PM
    chamuco12
    so cal
    my question is ....do you need the EGR or whats it for?
  16. Feb 21, 2009 at 6:17 PM
    dually
    dually Low and slow
    It recycles exhaust gases. Completely useless and gets your intake manifold SOOOOOO dirty, its sickening. I eliminated mine and soddered a 10k resistor in the EGR plug.
  17. Feb 21, 2009 at 6:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What Dually said, but I kept mine for emission reasons. Didnt notice any loss of power.
  18. Feb 21, 2009 at 6:25 PM
    dually
    dually Low and slow
    Yeh, if we had emissions testing it wouldnt have been removed, but the turbo mani has no flanges to bolt it too. If you dont have to, dont remove it.
  19. Feb 22, 2009 at 12:31 AM
    chamuco12
    so cal
    my headers dont have anywhere to connect it to..so what...how is it eliminated. this is frustrating..and its supposed to be an easy install.
  20. Feb 22, 2009 at 6:50 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What headers do you have?
