How Much HP Can A 4.0L Push?
Discussion in 'Performance and Tuning' started by ToyotaTacoma4Ever, Oct 1, 2012.
  1. Oct 1, 2012 at 10:00 AM
    ToyotaTacoma4Ever
    ToyotaTacoma4Ever [OP] Get Boosted
    Eric
    Alberta
    Supercharged Tacoma Sport
    Check Out The S/C Build
    Hello Everyone
    Ive pretty much have my truck all TRD'ed out (engine wise, because of warranty);The engine is the 4.0L with TRD Supercharger, TRD Cold Air and TRD Cat Back Exhaust. I really dont know where HP stands right now but my guess may be around 315? The taco itself is a 2011 with 65,000 and had all its routine maintance done.
    One concern is how much more power can the engine take with it completely stock without destroying anything? lol Since i woud like to jump horsepower just a little higher but not quite sure how, would you be able to tune the engine at all?
    Thanks!
    All is welcome to say their opinion
  2. Oct 1, 2012 at 10:17 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    From what I've read on XRU stock internals ok up to ~400 hp. After that you should start upgrading internals. Throw on the URD 2.85 pulley and I'm sure you will be happy with the added ooomph!
  3. Oct 1, 2012 at 10:29 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You should check out XRUnderground for some ideas on how to keep upgrading your engine. URD sells a tuner, MAF calibrators as well as aftermarket S/C pulleys and Non-Stop Tuning sells some other goodies like lightweight pullies, flywheels and I believe clutches. Aftermarket headers and a y-pipe would open it up a bit more also. Search for Toon or Torspd (there are others but those 2 come to mind quickly).
  4. Oct 1, 2012 at 1:03 PM
    Darthyota
    Darthyota Well-Known Member
    Alberta
    Blown BSP X-Runner
    TRD s/c @ 9lbs, Unobtanium Welding 321SS Full Race Exhaust, B&M s/s, TRD 1st Gen CAI, sittin sic track ready drop, TSW Tanka's with 275/40/18's all the way around, 4300k hid's in headlights and fogs, with more to come
    he is from Canada so that 65000 is in km not miles which is only about 40000miles. do you have the first or second gen trd intake? as mentioned you can do a smaller pulley although if you do headers and y-pipe with the trd cat back it will sound like poo. and dont expect to find a plug and play tuner as your truck is newer than 2009
  5. Oct 1, 2012 at 1:17 PM
    Pugga
    Massachusetts
    Damn... just realized that URD's UCon system doesn't work past 2008. Sucks for you guys with newer trucks!
  6. Oct 1, 2012 at 5:16 PM
    ToyotaTacoma4Ever
    Eric
    Alberta
    Tha's good to know that engine internals are good till 400, im not really the one to tear apart the engine a whole lot lol
    Will the URD pulley fit on the TRD S/C?
    haha i meant to say 65,000 KM and its still alot for a truck thats a year and a half old
    I took a quick look at URD, sent them an email and no response back, so i dunno?? lol il look into XRUnderground see if they can help, lightweight pullies may be an idea and im steering more towards of a tune more then anything but il keep the ideas though!
    Yeah i may take into consideration a pulley but same as above. Ive got a second generation tacoma, did look for somekind of flash tuner but no luck after doing some searching i found nothing for this year anyway :( lol
    Ouch well that suucks lol hopefully they can come up with something?
  7. Oct 1, 2012 at 6:03 PM
    Darthyota
    Alberta
    Blown BSP X-Runner
    Not your cold air intake is it the 1st Gen or 2nd Gen the first Ben looks the same as the afe stage 2 si
  8. Oct 1, 2012 at 6:40 PM
    ToyotaTacoma4Ever
    Eric
    Alberta
    Oh? the cold-air is this one here (didnt know there was a 1st or 2nd generation of a C.A.I): This is the exact same set up that I have (this is a different tacoma, not mine)
  9. Oct 1, 2012 at 6:49 PM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    Super Werty is another member that was into boosting the Taco if you hadn't stumbled onto any of his posts.
  10. Oct 1, 2012 at 6:57 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    would a y-pipe really do more than duels with an x-pipe?
  11. Oct 1, 2012 at 6:59 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Eh... When boosted probably not. Max flow is key when boosted
  12. Oct 1, 2012 at 7:06 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That is the second gen TRD intake. Made by K&N I believe. (Little rumor I heard).
    The first gen is known to flow/perform better than the second gen. It was made by AFe. But, was not CARB legal, since it removed the carbon filter.
    URD is working hard to have something ready for the '09+ models, as far as their UCON goes.
    Currently, there are only two companies that have plug n play harnesses for the '09+. Unichip, and ProEFI. ProEFI is very recently added to that list.
    Small factoid, the plug on the '09+ Taco, are the same used in the ISF. o_O. Toon recently stumbled across that fact. ;)
  13. Oct 1, 2012 at 8:08 PM
    Darthyota
    Alberta
    Blown BSP X-Runner
    I thought the second Gen intakes were made by aem
  14. Oct 1, 2012 at 8:12 PM
    ToyotaTacoma4Ever
    Eric
    Alberta
    I'l look him up and send him a message thanks!
    Oh right on, i never seen the first generation then wish i heard about it before i got this one lol Are you sure those two companies actually make a reliable plug in and play? ive seen alot of "chips" in advertisements and from what ive seen on this site that their junk, its has me kinda skeptical about it now lol but im glad somone knows about it
  15. Oct 1, 2012 at 8:22 PM
    ToyotaTacoma4Ever
    Eric
    Alberta
    oooooooh i see, lol seems as if ive a bit more learning to do with these ECU's lol
  16. Oct 1, 2012 at 9:03 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I think I read somewhere Gadget saying that it was. Don't quote me on that because i could very well be wrong.
  17. Oct 1, 2012 at 9:10 PM
    Darthyota
    Alberta
    Blown BSP X-Runner
  18. Oct 1, 2012 at 9:17 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    This man is correct. The UniChip is a piggy back ecu. Been around a long time. Used to be extremely popular in the states. Very popular in UAE right now. Limited as far as ability goes though, and can only be tuned by an Authorized dealer.
    ProEFI EMS' are Standalone. Just like other top brands, AEM, Motec, Vipec...etc.. They all have the ability to completely control everything. However, that comes with a higher price tag. Motec usually being the most expensive.
    ProEFI recently overcame the plug availability for the Lexus ISF, and that is why they have the plugs for the '09+, or will in the very near future. They have two units available, but have yet to get the chance to map out the CAN system of the Tacoma. Should be done when i get mjne back up and running... So there are still bugs, such as CEL's, until that time comes. Unless someone else can get it done before me.
    The UCON, is an inline, and in most cases the most user friendly. Plug it in, and don't worry about it. It usually comes pretuned, pretty close to how it needs to be. Major plus.
    Just, have to wait until the plugs are finalized and URD has the ability to make them fit the '09+. It will happen, and most likely in the next few months.
    In my opinion, the UCON is by far the best chose for you OP. Just keep your eyes peeled for its release for your year model. :thumbsup:
  19. Oct 1, 2012 at 9:33 PM
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
    Isnt a guy on xru running a garret turbo pushing 500-600 hp on stock internals? Cant remember his name... maybe in the morning
  20. Oct 2, 2012 at 3:40 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    No sir. There is not. There are a handful of owners on XRU which have a tad over 400 whp, with URD's MKII or MKIII kits. That is it.
    Toon has a GT3582R on a custom front mount. Not making those numbers though. He is making about 450wtq
