How much is this Tacoma worth?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nisno, Oct 27, 2019.
  1. Oct 27, 2019 at 4:59 AM
    nisno
    nisno [OP] Well-Known Member
    I'm not a Tacoma owner, but I'm trying to help a family member sell theirs. I did a lot of looking, and it seems the prices are all over the place. Obviously I know that they keep their value better than most vehicles, but I'm also looking to price it slightly below the norm so that it will actually sell easily. Someone will likely get a good deal in the process. What is the range something like this would sell for?
    2008 TRD Sport Access Cab 4x4 V6 Manual Trans
    Only 90k miles
    It's not in "perfect" garage-kept condition visually, because it was used by someone who did light wheeling. With that said, the undercarriage looks quite good and the paint doesn't have that many scratches as one would expect. The suspension is tight and feels like a brand new vehicle to me. One thing I want to ask is about a faint "chattering" when in neutral and off the clutch, I searched and saw people say it was quite common, and it sounds like throwout bearing to me. The clutch is very good in it so does the bearing just wear fast in these trucks? I bought a new battery but the tie-down doesn't fit, it's the "right" battery but it's too tall for the tie-down. The tire warning light is the only other thing "wrong" and it just never went away after the tire going flat and being pumped back up. I appreciate the help.
    edit... one thing I forgot to mention is that it has I think 2 cracks in the windshield. I will reflect that in the price though to make up for it.
  2. Oct 27, 2019 at 5:03 AM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    What state are you in, and what color is truck? Is it stock?
  3. Oct 27, 2019 at 5:04 AM
    nisno
    I'm in NC. As far as I can tell the truck is stock. It's Silver.
  4. Oct 27, 2019 at 5:05 AM
    IvanhoeTaco
    Eastern NC
    90k miles on an 08 is going to be at least 12k to 15k depending on condition
    Where in nc?
  5. Oct 27, 2019 at 5:07 AM
    nisno
    Right outside Raleigh, on the southeast end.
  6. Oct 27, 2019 at 5:20 AM
    nisno
    Is there anyway I can look up the spec sheet for all the options it was ordered with like on a Jeep? or does the TRD Sport package not really have much left to add to it?
  7. Oct 27, 2019 at 5:32 AM
    IvanhoeTaco
    Eastern NC
    I do not know that. Not really alot of things that truck can be ordered with from the factory anyway.
  8. Oct 27, 2019 at 5:38 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    xxTacocaTxx likes this.
  9. Oct 27, 2019 at 5:46 AM
    nisno
  10. Oct 27, 2019 at 5:48 AM
    nisno
    If you know anyone looking send me a message. I have to clean it up outside and inside, then I'll likely post it up on here anyways. It will be sold on the lower end of the price range so it will be a steal for someone.
  11. Oct 27, 2019 at 5:50 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Tire pressure reset button under the steering wheel on panel - press and hold 3 sec then after driving it should reset the dash light could take 50 miles.
    cleats50 likes this.
  12. Oct 27, 2019 at 5:51 AM
    nisno
    on the price... mainly because the tires have seen their better days and the truck was quite dirty inside and out. the outside has already cleaned up nicely, gonna see what I can do on the inside.
  13. Oct 27, 2019 at 5:52 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Use this site, plug in the info and get a pretty accurate value based on your zip code. There could be $3000+ difference in value between NC and Michigan or California. You can get private party value, trade value, or what a dealer would ask for it.
    www.kbb.com
  14. Oct 27, 2019 at 5:53 AM
    nisno
    Ok thanks. I think I didn't hold it down long enough or drive it far enough after.
  15. Oct 27, 2019 at 6:05 AM
    IvanhoeTaco
    Eastern NC
    Please post pics, a 4x4 trd in any condition will likely sell within a week if the price is good. 90k is super low miles as well. Good luck with sale brother
  16. Oct 27, 2019 at 6:23 AM
    muddog321
    FL
    FYI additional info:
    Truck should be running and after depressing reset the dash light should blink 3 times then and go off or stay on solid till driving.
    If it blinks on starting and not touching the reset the TPMS sensors are battery powered and one may be dead (cannot change battery in it requires new TPMS and dealer load into ECU).
  17. Oct 27, 2019 at 7:36 AM
    nisno
    It should work, when I originally did it I didn't have the truck running, just accessories on, and I didn't see any blinking.
  18. Oct 27, 2019 at 8:06 AM
    Muddinfun
    Muddinfun Well-Known Member
    Be sure to check the air in the spare. There's a TPMS sensor in the spare.
    Look for this to see if it has the factory tow package. That's an extra selling point if it does.
    '07-'08 are great years for access cabs due to having the fold forward rear seats and no head gasket problems.
  19. Oct 27, 2019 at 8:44 AM
    nisno
    It does have the tow package, I saw that on the VIN lookup. Not to mention it still has the factory receiver cover with the Toyota logo.
    Muddinfun[QUOTED] likes this.
  20. Oct 27, 2019 at 10:07 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
