How much is too much?
Discussion in 'Recovery' started by William H. Bonney, Apr 13, 2023.
  1. Apr 13, 2023 at 7:07 PM
    William H. Bonney
    William H. Bonney [OP] Well-Known Member
    2016 TRDOR
    I actually have a couple questions here. I’m a first time winch owner. I installed a Zesuper 13000 pound winch on my truck. My intention was to use it to aid me in some very odd tree damage that occurred during a storm. I was skeptical at first because it was a cheaper winch, but it has surprisingly been quite pleasing to use. But how much pull is too much? This thing will damn near lift the back tires off the ground and drag the truck! Should I be worried about any suspension component damage? Damage to the E brake? And also I noticed the synthetic line almost looks flattened and melted in 2 spots, but the winch was still cold after the pull. Is this something to worry about?
  2. Apr 14, 2023 at 8:45 AM
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    13K isn't too much IMHO. Remember, each winding on the spool reduces the pull capacity anyway. As far as the synthetic winch line appearing to be melted in two spots, did you pinch the line at that point and push it together, to see if the individual strands would still separate and were pliable?
    Zuba Gooding Jr and TacoSR523 like this.
  3. Apr 14, 2023 at 10:09 AM
    William H. Bonney
    2016 TRDOR
    No but I’ll definitely do that. Hopefully I didn’t mess it up
  4. Apr 14, 2023 at 10:29 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    People slap a block on, doubling their pull, all the time. 13K is WAY below what that would get you on a 9000lb winch.
  5. Apr 14, 2023 at 10:34 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
  6. Apr 14, 2023 at 10:38 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    Unpopular opinion, ditch the synthetic cable and get a steel cable.
    "Too much pull" would be pulling your winch off the mounting bracket / bumper lol.
  7. Apr 14, 2023 at 10:40 AM
    YF_Ryan
    Kent, WA
    The Gods must be Crazy?
    All-bran Taco’s, BKinzey and jackn7 like this.
  8. Apr 14, 2023 at 11:02 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Correct!
  9. Apr 17, 2023 at 6:56 AM
    T-TOWN1000
    T-TOWN1000 Well-Known Member
    Thomas
    2012 Tacoma Dcab 4x4 TRDOF
    Why do you prefer steel cable? Just trying to get both sides of the argument. I personally don’t have a winch yet. Asking for educational purposes
  10. Apr 17, 2023 at 7:23 AM
    ToyoTaco25
    North Carolina
    It's just my preference. I've been in a multiple instances where someone else's synthetic cable broke when winching. I've never been in a recovery attempt where a steel cable broke (not saying it won't happen).
    It sucks to be stuck. But it really sucks to be stuck and have a winch, but a broken winch cable.
    The difference in weight is not of my concern. I've never had a problem with kinking or rusting. I don't have an issue with throwing on a pair of gloves if I need to for handling the cable. Take 5 minutes after each recovery to unwind, respool and lube the cable as required. (should always unwind and respool after a recovery, regardless of steel or synthetic)
    They both have their pros and cons. I rarely use my winch, but when I do, I don't want to wonder if the cable is the weakest link.
    Either way you go, just do your research on safe recovery methods and practices. Recovery situations can be dangerous.
    All-bran Taco’s likes this.
  11. Apr 17, 2023 at 8:46 AM
    T-TOWN1000
    Thomas
    the biggest plus for the synthetic cable to me is if it broke it’s less likely to take your head off. I know people with steel cable put a weighted blanket or something in the cable for that reason though right?
    All-bran Taco’s and SR-71A like this.
  12. Apr 17, 2023 at 11:45 AM
    ToyoTaco25
    North Carolina
    Yeah, exactly. Also, shouldn't be in the cable path to begin with.
  13. Apr 17, 2023 at 11:59 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Counter point: Its very easy to splice and repair synthetic on the trail.
    To OPs question, Im not sure if there is really 'too much' winch. But some things Id consider:
    -How is the winch making all that torque?
    --Really low gearing (slow line speed)
    --Or a massive motor (really big amperage draws on the electrical system)
    -Overall weight vs a conventional 9.5 or 10k winch
    -Cost
    Personally my 9500 has done everything Ive ever asked it to. A snatch block or recovery ring and you've just doubled the capacity sacrificing only line speed. I think at the end of the day the knowledge to use whatever gear you do have is the most important thing you can take.
  14. Apr 17, 2023 at 12:19 PM
    ToyoTaco25
    North Carolina
    If it broke once...
  15. Apr 18, 2023 at 7:49 AM
    SR-71A
    Zack
    Southern Maine
    Then you found the weak point and now can repair it (and buy a new line when you get home). Most synthetic line seems to have a 3 or 4x breaking strength. So if you broke it simply because you overloaded it, you might need to rethink your equipment :rofl:
    1996landcruiser likes this.
  16. Apr 18, 2023 at 7:56 AM
    ToyoTaco25
    North Carolina
    Lol, sounds like a great plan. Buy something only to have it break so you can “repair” it and buy another one later. I guess you enjoy buying disposable products.
    I’d rather just buy a steel cable and not have to worry about it breaking, ever. And most likely never have to replace it.
    I’m just speaking from my experience of using steel cable and others using and breaking synthetic cables.
    Your opinion and money, do what you want with it.
    Grey 2015 likes this.
  17. Apr 29, 2023 at 12:36 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    it took for longer to reinforce the tree then the simple lift.
    I hope no one gets any dumb ideas.
