How much lift from 1 ton leaf spring mod?
Discussion in 'Suspension' started by jpfunk21, Feb 11, 2014.
  1. Feb 11, 2014 at 2:01 PM
    jpfunk21
    jpfunk21 [OP] Well-Known Member
    Josh
    Colorado
    05 dclb trd sport 4x4
    Just as the title says, my leafs are shot and was looking at going with the expo pack and well theres a junk yard down the road so why not try and save 5 or 6 hundo right? The truck has weight on it and will be getting more when it can take it and a lift for bigger tires so i was gonna try and build the leaf pack to get as much lift out of it as i can so 1 ton i guess? But how much lift will I get and can my stock shocks handle that till i upgrade? Any help or insight would be great thanx guys!
  2. Feb 11, 2014 at 2:05 PM
    foxhead
    foxhead Well-Known Member
    Andrew
    Colorado Springs, CO
    2016 DC Tundra
    First, make sure that the specified leafs will work in our suspension. Second, you need new rear shocks with any amount of lift. And the amount of lift you get is determined by the arch of the leaves, the thickness of the leaves and how many of them there are. Best of luck!
  3. Feb 11, 2014 at 2:06 PM
    jpfunk21
    Josh
    Colorado
    thanx I see most ppl using chevy so was going to see what the yard might have
