How much lift needed for 04 Prerunner
Discussion in '1st Gen. Tacomas (1995-2004)' started by prophet, Jan 18, 2009.
  1. Jan 18, 2009 at 11:41 AM
    prophet
    prophet [OP] Member
    Peoria
    PreRunner SR5
    I've got an 04 Prerunner with some Cooper 265/75/16 S/T's. The tires are about 1" taller than stock and the front rubs on sharp turns, the back only when compressing one side like over a curb or something. I've heard of people raising the front 1" higher than the rear because of the OEM's dropping the front for aerodynamics.?.? We're not looking for a monster truck, just something compatible with the tires.
  2. Jan 18, 2009 at 11:46 AM
    mpreiss
    mpreiss Attack Life.
    Capon Bridge, WV
    07 D.cab 4x4 w/3" Lift
    3" Pro comp Suspension Lift Fog light Mod. Tinted Front windows 15% (match rears) Tonneau cover Halo head lights K&N filter.
  3. Jan 18, 2009 at 1:36 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    dude what i would do and did do is this. have your buddy get in your truck turn it on and crank the wheel all the way to the left. look at where the driver side tire is rubbing up against the inner wheel well and chalk an outline on the plastic rubber whatever to cut it out. do the same for the passenger side tire. then get a knife and cut the piece that the tire rubs against out. problem solved. cant even tell on my truck that it was even cut.
  4. Jan 18, 2009 at 7:37 PM
    prophet
    prophet [OP] Member
    Peoria
    PreRunner SR5
    I can see where it rubs...however It would be a perfect place to blow road salt right into a body cavity through the hole...no need to cause a rust problem when $100-250 would solve the problem depending on the parts I'd need.
  5. Jan 19, 2009 at 12:10 AM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    just put a 2 inch spacer lift in the front and problem solved.
  6. Jan 19, 2009 at 12:14 AM
    Tacoma02TRD
    Tacoma02TRD Well-Known Member
    Walla Walla WA/ Klamath Falls OR
    02 Tacoma TRD
    3inch Revtech lift,Flowmaster Muffler, K&N cold air intake, 33x12.5 Maxxis Bighorns, TRD stock locker, Hella 500 Fog lights, Scanguage II, 6k HIDs, Painted Black Rims
    I would op for a 2inch suspension lift or leveling kit;)
