How much lift w/ TSB and 1.5" blocks in rear ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gabe911, Jan 25, 2012.
  1. Jan 25, 2012 at 5:07 PM
    Gabe911
    Gabe911 [OP] Well-Known Member
    FLORIDA
    10 PreRunner MGM
    Debadged, Rear TSB, Blue LED dome and Bright White Map Lights, Hard Top Tonneau Cover, OME885 coils (no top plate spacers)OME shocks and struts, 1.5" AAL for TSB Rear,285/70/17 Trail Grapplers, 17x9 XD Addicts with 4.5 bs, Black 4" exhaust tip, Bed pocket lights, rear diff breather Mod
    And will it be level with 3" coilovers up front??
  2. Jan 25, 2012 at 5:16 PM
    Large
    Large Red
    Probably have a rake. TSB & 1.5" block is close to 2" of rear lift.
  3. Jan 25, 2012 at 5:26 PM
    Gabe911
    FLORIDA
    10 PreRunner MGM
    Rake with the front or rear higher...I want rear higher..thanks
  4. Jan 25, 2012 at 5:33 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
  5. Jan 25, 2012 at 6:03 PM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    well i have 3" up front and a 2" in the back and I'm half an inch high in the front, without the TSB, so you've got .5 (TSB)+.5(stock height)+1.5" blocks=2.5" of lift so the front might be a bit high
  6. Jan 25, 2012 at 6:21 PM
    Gabe911
    FLORIDA
    10 PreRunner MGM
    Well from what I've read on these threads (which is alot of reading) with a 2.5" up front and 1.5" lift rear is what gets you close to level...so I am assuming with the full 3" up front 1.5" block with the tsb giving arounf .5 lift should sit pretty close to level. there is a member "notty" on here who is running this set up and looks good with rear being a lil higher
  7. Jan 25, 2012 at 7:54 PM
    Toy Yoda
    Garrett
    06 DCLB
    alright man, i don't have the tab so good luck!
  8. Jan 27, 2012 at 1:14 PM
    Gabe911
    FLORIDA
    10 PreRunner MGM
    Well I got my rear TSB done today at my local dealership...Lipton was awesome. i got bout an inch of lift like most said I would...the ride is good ..no complaints ...just got to do the rear...my before and after pics of TSB is in gallery
