How much LSD additive are you having to use?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sloppyjoe, Feb 9, 2011.
  1. Feb 9, 2011 at 7:00 AM
    sloppyjoe
    sloppyjoe [OP] They are more like guide lines.
    All Over
    Silver and simple
    Non
    Just curious of the amount others here are using in their rear diffs with LSD equipped? I have read on here that the diffs we have end up chattering very easily, if that is the case have any of you added more than the reccomended amount to combat this issue? If so what is the amount you run (ie 5,6,7 oz's)? Thanks!!
  2. Feb 9, 2011 at 7:04 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    There is no recommended amount :notsure: Toyota forgot to put that into FSM.
    Amount will also depend on additive. I have almost 8 oz of GM additive with Mobil Delvac synthetic and no chatter. System works np since I did "one wheel climb test"
  3. Feb 9, 2011 at 7:08 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  4. Feb 9, 2011 at 7:13 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I believe I used two 4oz. bottles of redline friction modifier if I'm not mistaken.:rolleyes:
  5. Feb 9, 2011 at 8:40 AM
    sloppyjoe
    All Over
    Silver and simple
    Non
    RP is what fluid I used but I still added some friction mod to it.
  6. Feb 10, 2011 at 5:38 AM
    sloppyjoe
    All Over
    Silver and simple
    Non
  7. Feb 10, 2011 at 5:40 AM
    wired_af
    wired_af Well-Known Member
    Alex
    Colorado Springs, CO
    '07 DC TRD Sport S/C, Rivian R1T
    If you use Redline you don't have to add any friction modifier :eek:
  8. Feb 10, 2011 at 7:38 AM
    sloppyjoe
    All Over
    Silver and simple
    Non
    You are not using any with an LSD and your not getting any chatter? I hear that is hard to get from others here. I have seen several that claim to have LSD but I still add it though
  9. Feb 10, 2011 at 7:59 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    1 - 4oz amsoil additive with the Amsoil 75-90 severe gear fully syn here, with no chatter 15k+ miles
  10. Feb 10, 2011 at 6:41 PM
    wired_af
    Alex
    It has the friction modifier built in. It's the only oil that's worked for me so far - all the other oil & friction modifier combinations I tried eventually started chattering... Wasted a lot of money on gear oil....
  11. Feb 17, 2011 at 9:48 AM
    sloppyjoe
    All Over
    Silver and simple
    Non
    So anyone else have numbers on how much they have had to use?? I have read alot about chatter and such but not much response here?
  12. Feb 17, 2011 at 10:33 AM
    Janster
    Jandy
    Lancaster, PA
    Did you look thru this post?
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/93117-beware-changing-lsd-lube.html
    Depends on what oil and friction modifier you use. Put in the standard amount first - do some tight 8 turns in both directions to 'stir up' the modifier..... then ...If you get chatter, put more in.
    Simple as that (or read the above thread)
    Oh wait...did't I just mention this back in post #3?? Hello??
    (sorry...just had to say it)
  13. Feb 17, 2011 at 6:21 PM
    sloppyjoe
    All Over
    Silver and simple
    Non
    I am not asking anywhere in this post^^^ how much I need to run. I was trying to see the variation of what others have had to use to keep "chatter" and such out of the LSD. BUT thanks for the response.
  14. Feb 18, 2011 at 7:46 AM
    Tacozoid
    Tacozoid Well-Known Member
    Terry
    Katy Texas
    White Tacoma Pre-runner
    Billsteins,Texas tint. Blue Dash mod. Console mod. in Blue, Customized grille
    Like just enough to give the Taco a good buzz dude.
